brakes for a 13' scamp - Fiberglass RV
Old 05-14-2009, 02:58 PM   #1
Thumbs down
I am in the market for a 13' scamp, and have been seeing a lot about brakes on travel trailers. Do they all come with brakes, and if not, what is the reason to get them?
Thanks in advance, Kara
Also, I am assuming i will need a different hook-up at the hitch for this????
Kara P. is offline   Reply With Quote
Old 05-14-2009, 07:24 PM   #2
Pete Dumbleton's Avatar
Most trailers now come with brakes, however that was not so in the past. As long as the axle has the brake flanges, you can add the brakes later (The brake flange is a square piece of metal inside of the wheel with four holes drilled through it).
Why brakes? It really does make a difference in stopping -- I was pulling my 13' Scamp with a 1/2 ton Dodge pickup and the before and after was quite a change.
Ford adds this note "The vehicle brakes are designed to stop the GVWR, not the GCWR", which means "stop the tow vehicle but not the towed vehicle".
Also, six braked wheels on the ground is clearly better that only four!
Old 05-14-2009, 07:29 PM   #3
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
This will give you an idea of what is involved in adding brakes.
http://www.flickr.com/photos/76boler...7604792637096/
kevin61 is offline   Reply With Quote
Old 05-27-2009, 07:28 PM   #4
Roy in TO's Avatar
Typically yes,
you will most likely need to change from the four pin flat to a 6 or 7 pin round connector, plus add a few other goodies.
Description here for adding a brake controller etc.
Old 05-27-2009, 07:46 PM   #5
Vic&Kathy's Avatar
Trailer: Trail Mite
We put brakes on our beloved '72 Trail Mite before our '08 trip across the USA and back. What a difference! Mountain descents are much easier and safer, and those inevitable "[b]oh $#!+" moments are much less heart-stopping.
Either get an egg with brakes, or add them. You'll be safer and more confident.
Vic
Vic&Kathy is offline   Reply With Quote
Old 06-30-2009, 04:20 PM   #6
Trailer: 1978 Trillium 4500
I am attempting to retrieve my Trillium 4500 (15 ft.) from California to Texas - most likely on a drive alone.
Your postings here on brakes and the excellent photo guides are very much appreciated. I will find an RV center in Cali to install before the haul.
The brochure for my old Trillium says they are not really necessary, and my TV is a 96 Suburban for now, but I just made a "go for the brakes" decision after reading here - thanks so much
sadie10023 is offline   Reply With Quote
brakes, scamp
How do I adjust Scamp electric brakes? Bryan L. Problem Solving | Owners Helping Owners 4 09-22-2009 05:48 AM
13' Scamp brakes Jeff Larsen Towing, Hitching, Axles and Running Gear 4 08-09-2009 08:56 PM
New Axle w/brakes for 13 ft Scamp in SF Bay Area KenTorke Classified Archives 0 05-30-2008 09:43 PM
Brakes for 16' Scamp davidwrench Towing, Hitching, Axles and Running Gear 3 05-24-2006 06:48 AM
Adding brakes to Scamp Quint Care and Feeding of Molded Fiberglass Trailers 27 01-26-2006 07:07 AM
