Brakes install stalled out! - Fiberglass RV
Old 05-26-2014, 08:41 PM   #1
Trailer: Previously owned a Scamp 13'
New Hampshire
Unhappy Brakes install stalled out!
Well... we were doing ok installing the first brake and hub assembly on our Scamp 13 (it did not have brakes, we are adding 7" electric brakes to it) until were adding the additional grease via the zerk fitting on the spindle. When we realized that we had added an entire tube of grease, we realized that we probably have a problem. Hubby has given up for the night, and he is dreading what he will find when he removes the hub.... a brake drum full of grease? Any thoughts anyone? Is it possible that you do need to add a full tube of grease to the EZ lube spindle? No, we thought not....
Doghaus is offline   Reply With Quote
Old 05-26-2014, 08:46 PM   #2
FTTRV's Avatar
Trailer: tp
It sounds like the inner grease seal was pumped out from to much grease. You might clean things up and reinstall the seal. Bearings should have enough grease.
Chuck
Old 05-26-2014, 08:58 PM   #3
If you did fill the brake drum make sure you use a brake cleaner before putting them back on.
Old 05-26-2014, 09:06 PM   #4
Euwww... If there is grease on the shoes don't even bother to clean them, new ones are the safest answer to lubricated brake shoes, but at least they won't squeak.
But do let us know that actually happened. Just yesterday someone told use that it couldn't happen, so you may be OK....
Old 05-26-2014, 09:11 PM   #5
The Minimalist's Avatar
Louisiana
On the Easy Lube spindles, make sure you are using a good double lip seal.
Old 05-26-2014, 09:44 PM   #6
IllAnnoy
The typical brake kit comes with a useless rubber coated seal. go to a real parts store or a marine supply and get the correct seals.
I recently had the same experience... The seal lip did not fail in my case.
The entire seal simply fell out. not only was it not precise, it wasn't metal to metal in the hub leading to an imprecise fit without a proper friction fit.
I cleaned up the mess and reinstalled an old seal. This will have to do until I find a flanged double lipped seal from a reputable manufacturer.
The flange is not absolutely necessary, it is simply a far superior design which virtually eliminates the likelihood of installation error.
Old 05-26-2014, 09:55 PM   #7
Louisiana
The flange isn't necessary. Just cover the seal with a clean piece of 2x4 and wang away this everything is level.
Old 05-26-2014, 10:18 PM   #8
IllAnnoy
If the following is that to which you refer, then you have sorely misstated the facts as to what was said....
"E-Z lube axles are designed to be used just as you say not to.
Used properly, an EZ-Lube hub can not be over filled, in fact it is designed to push the old grease out into the chamber where the zerk is located."
A faulty seal or an improper application is not a fair indictment of a good design...Full is full. A port is provided to vent any excess grease.
Of course care must be taken when using a hand grease gun which can produce thousands of PSI. The same admonition applies to impact wrenches, air compressors, and just about any other tool.
Almost anyone who has ever attempted to change just the shoes on a 7" brake, would opt to clean them.
Old 05-26-2014, 10:21 PM   #9
IllAnnoy
As I said...
"The flange is not absolutely necessary, it is simply a far superior design which virtually eliminates the likelihood of installation error."
Or splinters!!
Old 05-27-2014, 04:03 AM   #10
New Hampshire
ok, thanks, yep, the kit came with rubber seals.
Old 05-27-2014, 05:14 AM   #11
I don't have any statistics for "Almost Anyone" when it comes to who cleans grease contaminated brake shoes, but for the nominal cost of new shoes or pads I, among many others mentioned on line, would replace them....period.
When "Joe the Home Mechanic" is doing brake work, he is not just risking his own families health and safety, but also that of all of us on the road with him. Now, if a person were an experienced and qualified brake mechanic, that answer might be different.
In looking on different sites it sounds that overfilling bearing buddy hubs is a lot easier than one would think. But if everyone was an expert mechanic this really shouldn't be a problem... right?
Murphy's Law #4 applies, "If something can be used improperly, it will be used improperly", hence my earlier warning and concerns.
Old 05-27-2014, 07:04 AM   #12
Trailer: Casita 17 ft DLX SD
Clarification
[ Quote Bob Miller>
"In looking on different sites it sounds that overfilling bearing buddy hubs is a lot easier than one would think. But if everyone was an expert mechanic this really shouldn't be a problem... right?"
I was led to believe that "Bearing Buddies " and "EZ Lube" were two totally different animals . Floyd's description of the EZ Lube system matches what I saw reading the literature from Dexter . I was never a fan of Bearing Buddies so I am hoping there not the same !!!
Old 05-28-2014, 07:10 AM   #13
Trailer: Aliner folding & Weekend Warrior toy hauler
Ohio
Originally Posted by steve dunham View Post
I was led to believe that "Bearing Buddies " and "EZ Lube" were two totally different animals....
They aren't the same. About the only thing they have in common is the zerk.
Bearing Buddies should never be used on a spindle that has brakes.
Shopping for a fiberglass TT
Currently own;
2009 Pontiac Vibe pulling a 2009 Aliner Sport = 22 MPG
1998 Ford E150 pulling a 2006 Weekend Warrior toy hauler = 8 MPG
beemerphile1 is offline   Reply With Quote
Old 05-28-2014, 08:10 AM   #14
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Boy, I wish I lived close enough to come over and help. First of all, on these kind of spindles, you always need a new seal everytime you take the hub/drum off. When you install new seals, they must be installed correctly so that they match up with the hub and bearings inside. I use over half a full tube of red grease when I repack both my EZ Lube bearings, but they're 10" brakes if that makes any difference.
Best of luck to you!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
brakes
When it's cold out and you're sitting out, how do you keep warm? rgrugg General Chat 40 02-22-2012 07:56 PM
checking out a scamp in albert lea MN? and cost to install heater? sdsjdo General Chat 23 12-04-2011 09:43 AM
Flat Panel TV Mount Install efawcett Modifications, Alterations and Updates 10 07-23-2009 04:59 PM
Car Stereo Install efawcett Modifications, Alterations and Updates 0 07-18-2009 03:17 PM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
