brakes necessary for 1300? - Fiberglass RV
Old 09-29-2013, 06:12 PM   #1
Trailer: trillium 1300 - 1981
Indiana
Just bought trillium 1300, year approx. 1981. Do I need to hook up brakes to be controlled via car?
scanlanm is offline   Reply With Quote
Old 09-29-2013, 06:30 PM   #2
Hi Mark, to FiberglassRV, we're glad you're here
There are lots of kind and helpful people here on the forums, I'm sure some will be along shortly.
I'll give you the short answer..
Old 09-29-2013, 07:17 PM   #3
I have a 13' and I hooked up the brakes and have been glad I did. I don't need them for every stop, but there have been several times where I was very thankful for them.
ericw is offline   Reply With Quote
Old 09-29-2013, 09:00 PM   #4
Brian B-P's Avatar
The need for trailer brakes depends on the tow vehicle; however, they wouldn't hurt with any tow vehicle.
Mark, what does your car's owners manual say?
Old 10-01-2013, 10:42 AM   #5
David Tilston's Avatar
Do you have the flanges to mount breaks to? If not then a new axle is probably your best bet.
Old 10-01-2013, 10:53 AM   #6
Your question implies that there are brakes installed on the trailer, is that correct?
If so check the laws of the states you plan on visiting, Oregon requires that if brakes are installed on the trailer they must be connected and working.
If there is no brakes you might be able to get by without them. I would highly recommend installing brakes if possible.
Here's a bit of my experience. Last March I was coming through Las Vegas on a freeway when I came around a corner the traffic was stopped. I had jam on the brakes as hard as possible to stop before hitting the last in line stopped car. I glanced in the mirror as I slammed on the brakes and the trailer was starting to come swing out. It took a fraction of a second for brakes to catch on the trailer so the time looked it was safe and sound behind me. I'm sure without brakes the outcome would have been a lot different.
Old 10-01-2013, 11:16 AM   #7
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I lost brakes on a 2,000# trailer behind my 1/2 ton pickup, and it was obvious. I shake my head when people say their car is fine without them, towing these campers.
brakes
CANADA - Trillium 1300 - $1300 David Tilston Referrals: Molded Fiberglass Trailers 2 01-26-2016 12:34 PM
New Electric Brakes/hubs on '76 Trillium 1300 georgewa Problem Solving | Owners Helping Owners 45 05-18-2013 09:53 AM
? on brakes thunter Towing, Hitching, Axles and Running Gear 11 02-04-2012 05:33 PM
Trillium 1300 Axle Check, Fitting Electric Brakes Richard Hayes General Chat 2 08-23-2009 10:54 PM
Trillium 1300 - electric brakes Lloyd S. Towing, Hitching, Axles and Running Gear 4 07-05-2009 08:40 PM
