Brakes on Lil Snooze - Page 3 - Fiberglass RV
Old 09-15-2013, 02:23 PM   #29
Brian B-P's Avatar
Same for rental cargo trailers - lots of us have towed them with surge brakes through mountains - in my case the Okanagan valley to the Edmonton area. I didn't have any problem, but I didn't check their temperature. I don't think they were as effective as my Boler's electric brakes, but that might just have been wear and maintenance (rental U-Haul equipment tends to have lots of wear and little maintenance).
Old 09-15-2013, 03:31 PM   #30
Trailer: Not yet
I towed a Uhaul with my daughters furniture from S. Fl to Colorado and we went through the Ozarks to do some scenic routes. That trailed fine but I don’t recall if it had brakes or not. It was a double axel Uhaul.
Flharleycop is offline   Reply With Quote
Old 09-15-2013, 05:41 PM   #31
MCDenny's Avatar
Trailer: Lil Snoozy
I towed my LS 9000 miles last winter, twice through the high hills - low mountains going thru Tenn on I65. Not exactly the Rockies but the trailer was zero problem.
I'm perfectly comfortable with surge brakes. They don't give you the ability to work them independently on the car but are idiot proof as you don't have to do anything. No electrical components either.
I thought the surge brakes were a plus feature. I had a trailer built awhile ago (not snoozy) and the builder wanted an extra $250 for upgrading from electric to surge. If you are paying someone to install a brake controller in your car you are probably looking at another $200.
MCDenny is offline   Reply With Quote
Old 09-15-2013, 07:48 PM   #32
carlkeigley's Avatar
NE Oklahoma
9000 miles............time for an oil change.
Old 09-15-2013, 07:56 PM   #33
SusieinNC's Avatar
Trailer: 2012 Lil Snoozy #151
Surge brakes
We have had our Snoozy 9 months and have not had any problems with the surge brakes. We have traveled through several states with mountains, but not as much as McDenny.
SusieinNC
SusieinNC is offline   Reply With Quote
Old 09-15-2013, 08:06 PM   #34
Brian B-P's Avatar
Originally Posted by Flharleycop View Post
I towed a Uhaul...
Among recent U-Haul trailers, particularly the enclosed cargo trailers, single axle trailers are under 3000 lb GVWR and do not have brakes, while tandem (double) axle trailers are over 3000 lb GVWR and have surge brakes... so that one likely had surge brakes.
Old 09-15-2013, 08:55 PM   #35
Trailer: Not yet
Thanks
Old 09-15-2013, 08:56 PM   #36
Trailer: Not yet
Great info thanks
Old 09-16-2013, 06:18 AM   #37
Melanie B in NC's Avatar
Trailer: Lil Snoozy "Marigold"
Alabama
Let me turn turn this brake question aside a bit from the Snoozy - can some of you who have other brands (Park Liner, Casita, Scamp, etc.) tell us what kind of brakes (electric vs surge) are standard on your campers? I guess every manufacturer has made a determination what they want to use and I would be interested to see what they decided. Thanks.
Melanie B in NC is offline   Reply With Quote
Old 09-16-2013, 06:37 AM   #38
honda03842's Avatar
Name: Norm and Ginny
Melanie,
Parlkliner, Scamp, Casita, Escape and Eggcamper all use electric brakes. The one advantage of electric brakes is the driver of the tow vehicle can operate just the trailer's brakes, a potentially valuable ability in an emergency.
The primary advantage of surge brakes is they do not require a brake controller, in my view an incrementally small cost.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-16-2013, 01:21 PM   #39
Brian B-P's Avatar
Essentially every North American travel trailer with brakes has electric brakes, except for units built for rental use. I've never heard of hydraulic surge brakes on a non-rental travel trailer, except the Lil Snoozy. The T@b had (may still have?) mechanical surge brakes, using European "overrun" type hardware, because it is a European design (although built in the U.S.). Overrun brakes are the standard for recreational trailers in Europe.
Since electric brake wiring is common in North American tugs, and the portion of the brake system on the trailer is much cheaper and simpler in the electric version, the choice is obvious for trailer manufacturers. Some large high-end units use disk brakes, which are not available in electric, so they use hydraulic brakes and an electric-to-hydraulic converter mounted on the trailer.
Old 09-16-2013, 03:59 PM   #40
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
We pulled a car trailer with surge brakes through the mountains. We almost got down from the mountain a hell of a lot quicker than we planned on. I had to buy my buddy a set of brakes after that. Never again. I remember the horrid of trying to back another surge brake trailer uphill. I had to back one over a curb and couldn't lock it out, had to take a 20 mph run at it to do it, because the brakes locked up solid going slow.
Also, keep in mind you should change brake fluid every 2-3 years, hoses every 5-10, and then there's the master cylinder and wheel cylinders to possibly deal with. Electric brakes…4 bolts, 2 wires, and a $30 loaded backing plate.
With the exception of trailers that get submerged, and rentals towed by idiots, I see zero benefit to surge brakes.
Out of curiosity, what does the little snoozy frame look like? Is there any chance it IS a boat trailer?
Old 09-16-2013, 04:04 PM   #41
NE Oklahoma
It IS a boat trailer Jared.
So we don't have to worry about moisture
when we back our trailers into the lake.
Old 09-16-2013, 04:09 PM   #42
Jared J's Avatar
Kansas
Well, that explains the surge brakes.
brakes
Brakes Rick Mooyman Modifications, Alterations and Updates 7 02-08-2012 05:13 AM
Ready to Crooze in the Snooze earlejk Hi, I am.... 8 01-26-2012 08:20 PM
Brakes Roger C H Towing, Hitching, Axles and Running Gear 9 01-12-2012 07:44 PM
Brakes JasonWesterman Towing, Hitching, Axles and Running Gear 3 12-04-2011 02:04 PM
Brakes Roger Kimble Towing, Hitching, Axles and Running Gear 18 12-04-2011 08:58 AM
