09-08-2013, 09:28 AM
Trailer: Lil Snoozy "Marigold"
Alabama
Brakes on Lil Snooze
This is probably in the wrong Forum, but I seem to have trouble getting the system to recognize me and allow me to post. Probably is my fault. But, anyway, I have a question and maybe a Snoozy owner can help me. We are considering buying one - planning a trip to SC to actually see one of these units. But I see conflicting advice about surge vs electric brakes. I sent an email to Snoozy asking which kind they have - no answer yet (just sent it Friday evening). We have never owned an RV (ages 70 and 68), but are seriously considering trying this adventure before the rocking chairs completely claim us. I have many questions before we take the leap. So - any advice from Snoozy owners or anyone else about pros and cons of the two types of brakes.
When coming down the mountain from Boone, NC - which type is safest (the thought of this already scares me - 2000 lbs pushing my car!!!). Got to get some courage from somewhere!!!
09-08-2013, 10:21 AM
Trailer: Former Escape 19 owner
Virginia
The Snoozy has surge brakes - very common on boat trailers. someone will come along shortly to give you the pros and cons.
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off the bowlines, Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
09-08-2013, 10:28 AM
Trailer: 93 Burro 17 ft
Well, I'm probably the one who has posted the most about my preference for electric brakes vs surge brakes. Snoozy comes with surge brakes, standard equipment. But when I ordered my Lil Hauley (empty Snoozy shell) for cargo, I told Alan I had to have electric brakes on it. They ordered in a different axle with electric brakes, and wired it up with a 7 pin harness to plug into my tug. So they are able to do it, if you specify it.
Electric brakes can be applied without hitting your tow vehicle's brakes, which would be a good safety feature IF you ever had the trailer start to sway uncontrollably (not too likely if you keep a decent tongue weight on it). Surge brakes work ok, but for my cargo hauling needs the Hauley changes weight by over 1500 lbs from loaded to unloaded status, so I wanted the ability to adjust my trailer brakes from inside the cab-- something one could not do with surge brakes.
09-08-2013, 11:50 AM
Another characteristic of surge brakes is that they apply whenever the tug pushes back on the trailer while moving forward, even if the tug's brakes are not applied. That means that if you use engine braking to hold the trailer back and control speed down a long grade, the trailer brakes will drag all the way down. This doesn't seem like a good idea to me, since it could overheat the trailer brakes; however, I don't know how much of a problem this is in practice.
I wouldn't worry about adjusting to load, because surge brakes are inherently self-adjusting: more trailer weight means more pushing against the tug, which produces more braking action. In addition to their use on boat trailers, surge brakes are very commonly used on rental cargo trailers, which of course vary greatly in load on every trip.
09-08-2013, 12:08 PM
NE Oklahoma
to the Forum Melanie.
I made a photo shoot of mine when I got it home.
I post this when anyone may be interested to have a photo view.
I think the question about surge and non-surge sometimes depends
on what you are pulling with. I have a 2010 Tacoma crew cab V-6.
I've seen no problems with the surge brakes on mine.
Like Mike says, if it is a concern you can order the trailer with the other.
These Snoozy's sit on a boat trailer and most boat trailers have surge brakes.
Backyard Photo Shoot
I also have a rear bumper and outside shower on mine.
These were not on the option list but they installed them for me.
09-08-2013, 12:49 PM
NE Oklahoma
Brake Unit
Brake Drum
09-08-2013, 12:52 PM
NE Oklahoma
Axle view of Brake Drum
09-08-2013, 01:05 PM
Name: Norm and Ginny
In every day situations there may not be much difference between Surge and Electric brakes however, I want the ability to activate the trailer's brakes independently of the tow vehicle's brakes, a relatively easy way to halt sway in an emergency.
Additionally the ability to add a break away switch is relatively easy with electric brakes. Is this ability available on the Lil Snoozy's surge brakes?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
09-08-2013, 01:09 PM
NE Oklahoma
Thanks Norm,
Yes, there is a break away cable on the Snoozy.
I'll have to remember that the next time I take pictures.
09-08-2013, 03:15 PM
Yes, a breakaway feature is available in all trailer brake systems, and should always be included.
09-08-2013, 03:30 PM
Alabama
Mr.Keigley, Apparently you are comfortable with the surge brakes. I keep reading about the trailer brakes overheating coming down a mountain (visions of smoke and having to run off onto those truck ramps!). Am I overthinking this whole thing?
Also, Mr. Magee - I assume the electric brakes were an added cost. Was the cost significantly more than the surge brakes?
Thanks to all for your help on this topic.
09-08-2013, 03:45 PM
I raised that concern, but again I don't know how much a problem it is in practice. I rented a U-Haul cargo trailer - with surge brakes - and towed it (loaded) from the Okanagan valley in B.C. to the flatland of Alberta... which means over the Rockies and other mountains. No problem. I don't know how much the brakes were doing, but they didn't fail.
Electric brakes are generally cheaper than surge brakes, mostly because of the cost of the surge brake actuating coupler. This is especially true if you don't count the cost of the electric brake controller or wiring the tug for it, either because you already have those things or just because you're pricing the trailer and those things are not part of the trailer.
09-08-2013, 04:38 PM
NE Oklahoma
I used to be a cross country truck driver. One company I worked for a very short time rigged a trailer that was designed for towing a race car to haul a full load of product. It looked to me to be a home made surge brake on a goose neck. I was pulling it across some Arkansas up and down mountains (steep) and I could see smoke coming from the brakes. You could feel it jerking you most all the time. This was decades ago.
But I have no problem with these that are designed for the trailer. I haven't felt them at all except maybe just a little when just pulling from a stop light. Something I don't think the average fella would notice.
I don't expect to have to run off on a truck ramp.............lol
The only trouble I've had with swerve or fish tail is pulling a utility trailer that someone did not arrange a load correctly. If a tongue weight is too light it can toss you around fairly easily. My son now listens to me after losing it three times......lol
09-08-2013, 04:39 PM
Trailer: '98 BURRO 17WB
Delaware
What axle does Smoak install on the Snoozy, Carl? I looked at the gozunda view of the torsion arm and saw the threaded end of [? spindle] and the castellated nut and got a bit disoriented as I'm accustomed to seeing the same stuff inside the dust cap on t'other end. The torsion arm housing on my old Henschen doesn't look like that. Is it an arrangement allowing painless spindle replacement?
jack
09-08-2013, 04:44 PM
NE Oklahoma
I just went out to look at the brand Jack.
It's made in the USA by TIEDOWN Manufacturing.
I hadn't really paid that much attention but it looks like you're right.
A castle nut with locking pin. Looks like very easy disassembly.
http://www.tiedown.com/boemm.html
The Eliminator Torsion Axle is an industry first with its removable spindle. Gone are the days of sitting by the side of the road when the spindle/axle is damaged due to extreme bearing failure or due to an accident.
Torsion axles allow independent movement of each wheel, reducing shock transfer and dangerous trailer sway.
09-08-2013, 04:51 PM
NE Oklahoma
I don't know if you can see the outer end or not.
This is the only picture I have after I lost one of the rubber caps.
09-08-2013, 05:16 PM
Trailer: Not yet
Do you mind sharing what that upgrade cost? Did they credit the surge brakes back and then charge for upgrade?
09-08-2013, 05:19 PM
Trailer: Not yet
Yes break a way switches are done with a cable on surge brakes are are required by law in most states.
09-08-2013, 05:34 PM
NE Oklahoma
Here's the brake actuator.....
Tie Down Engineering
09-08-2013, 08:41 PM
No idea, sorry. I asked for a price quote for an empty trailer with electric brakes and 2 small windows and 2 interior lights. I have no breakdown of the pricing.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Brakes
Rick Mooyman |
7 |
02-08-2012 06:13 AM |
Ready to Crooze in the Snooze
earlejk |
Hi, I am.... |
8 |
01-26-2012 09:20 PM |
Brakes
Roger C H |
9 |
01-12-2012 08:44 PM |
Brakes
JasonWesterman |
3 |
12-04-2011 03:04 PM |
Brakes
Roger Kimble |
18 |
12-04-2011 09:58 AM |
