brakes or no brakes - Fiberglass RV
Old 08-12-2007, 06:28 PM   #1
Penney H. & Mike E.'s Avatar
Trailer: 2005 17 ft Escape ('Turtle')
I read with interest several discussions on brakes. What is baffling is our 1987 Burro does not, and apparently never did, have brakes yet some others with even older Burros say they do have brakes. My husband says it's okay to not have them and we really don't want to invest a lot in this trailer as we hope some day to get a 17'. Should we have brakes for some reason? We tow with a super charged 1995 Toyota Previa and it handles fine.
"A good traveler has no fixed plans and is not intent on arriving." -- Lao Tzu
Enjoy our travel photos at: Turtle Travels
Penney H. & Mike E. is offline   Reply With Quote
Old 08-12-2007, 07:24 PM   #2
Pete Dumbleton's Avatar
Generally, the need for brakes is set by state or province law; they vary from 1,000 lbs in NY to something like 13,000 in MA. Washington is either 3,000 or 4,000, I don't recall which right now
I was towing my comparable Scamp 13' with a 1/2 ton Dodge pickup and was tired of close calls at intersections because the 1,700# trailer was pushing the 4,000+ truck just a little too much for my comfort. It really made a difference.
BTW, it isn't the supercharged part that matters (except that it might get one into more trouble than one bargained for), but what kind of brakes, tires and suspension one has on the tow vehicle, plus its weight. What I would suggest is looking in the owner's manual under trailer towing; if it doesn't mention brakes, and you have a very comfortable towing capacity margin, then you should be all right.
Old 08-12-2007, 07:30 PM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
IMHO: Handling and stopping ESPECIALLY in emergency situations are two completely different needs. One can never plan for an emergency, just be prepared to deal with it. WHY risk the chance of doing some serious boddily harm OR worse yet cause the death of others not to mention yourselve because of not using/having trailer brakes???
The need/ necessity of brakes on a trailer (at least up here in Canada) is related to the overall weight of the trailer and the tow vehicle. Our Trillium has no brakes (from the factory) and I know towing it with our hot rod even with its 600+hp is pushing the envelope. The car has MANY times more than the power needed to pull the trailer as well as steer around possible obsticles, but emergency stopping is, ...well lets just say that when the torsion bar axle fails or shows signs of more wear, I do plan to get a new axle which will be equipped with brakes. These brakes MAY just be the surge type, but far better than our braking ability now....
Old 08-12-2007, 07:31 PM   #4
Doug Mager's Avatar
Pete, Yes, I agree!!!
Old 08-12-2007, 07:45 PM   #5
Trailer: Fiber Stream
Talking
What I would suggest is looking in the <Previa's> owner's manual under trailer towing; if it doesn't mention brakes, and you have a very comfortable towing capacity margin, then you should be all right.
I agree!
Link to what My 2003 Honda Odyssey's manual says.
Old 08-12-2007, 08:13 PM   #6
Brian B-P's Avatar
Pete and Doug have covered the rules and the reasons... so I'll comment specifically on the Previa. I would be very surprised if the restrictions in the owners' manual allowed towing any more than 1000 lb without trailer brakes. The current Sienna is a larger vehicle from the same manufacturer, and has a 1000 lb no-brake limit, which is very typical of anything lighter than a full-size pickup truck.
The brakes of a vehicle are intended to stop up to the Gross Vehicle Weight Rating of the vehicle (maybe 1000 lb more than the empty weight of a Previa), not the Gross Combined Weight of the vehicle and the trailer. In addition to any consideration of brake component sizes, the van doesn't have the traction needed to effectively stop the trailer, because its tires are not carrying the trailer's weight.
It seems that most 13' travel trailers do not have brakes, but with the exception of people towing them with large trucks, in most cases they should have brakes.
Old 08-12-2007, 08:34 PM   #7
Lance MacArthur's Avatar
Trailer: Boler 13 ft 1972
You only need em when you need em.
Believe me, if you travel much, you'll need em.
Lance MacArthur is offline   Reply With Quote
Old 08-12-2007, 09:13 PM   #8
Doug Mager's Avatar
ESPECIALLY here on the mountainous Wet Coast, LOL!!!!
Old 08-12-2007, 10:48 PM   #9
I find that my 13í Boler and 1/2 ton truck combination hasnít needed trailer brakes in the 5 years that Iíve been towing ......been coast to coast a couple times....in panic type situations the 4 wheel discs with ABS help, I suppose....also if Iím not mistaken, brakes are reqíd on all trailers, regardless of size in S. Dakota and Kansas......In Manitoba the limit for not needing brakes is 2006 lbs.....Benny
Old 08-12-2007, 10:58 PM   #10
Greg A's Avatar
Trailer: 2015 Escape 19
On our 13 Scamp it had brakes when we bought it, but with the gut and remodel I put off getting the controller till just recently. Pulled three trips in the AZ mountains without the brakes and then got the controller and fired up the brakes for the last trip to San Diego. Don't know about the technical mumbo jumbo, but just from what little experience I've had so far, I much prefer towing the Scamp with the brakes. Quite a difference in handling. Pulling with a Jeep Liberty.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 08-13-2007, 12:56 AM   #11
Trailer: 2002 13 ft Casita
Post
I have a 2002 13' Casita. It came with brakes. When I was leaving the campground at the end of the Oregon Gathering, One of the electric brakes engaged. My tug is a 2002 Dodge Dakota with the big V8 engine. I couldn't move the trailer with the pickup with only one brake engaged. I'm glad to have the brakes. I know I'm safer when I stop or even have to slow down. Thanks to the assistance of some gentlemen in the group I was able to get moving and get to Coos Bay for brake repair.
Kathy Davisson is offline   Reply With Quote
Old 08-13-2007, 07:05 AM   #12
BobB's Avatar
Most of the important points have already been covered. Trailer Life Directory has a section on Rules of the Road and Towing Laws. The trailer weight requiring brakes in WA state is 3000#. Scary! I don't think I would pull a travel trailer without trailer brakes, except maybe with a full-sized pick-up or large SUV.
Old 08-13-2007, 07:08 AM   #13
Joe Z's Avatar
New River AZ
I've seen far too many times large pickups (i'm guilty of this too) towing med. size trailers w/no brakes going down a very long hill on the interstate and when holding on the brakes they get what's called "brake fade"..... let that happen to you one time and you will be sure to leave plenty of clearance between you and that vehicle in front of you...... stopping quick should be fine but those long downgrades could be a problem, A lower gear and fan the brakes in that situation would help alot if no trailer brakes.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 08-13-2007, 07:09 AM   #14
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 2004 Airstream Interstate 22' B-van
Iowa
Truer words were never spoken.
If you don't have 'em, it's sort of like the trip down while falling off a tall building... "It's OK so far..." In that case, it's not the fall that kills you, it's the sudden event at the end. Trailering without trailer brakes is a pretty similar endeavor.
Roger
Old 08-13-2007, 09:31 AM   #15
Thank you all for your thoughts and good information on this topic. We will look into the cost of installing brakes and consider our usage. So far we have not had any problems with the trailer and we have had it all over the west, up and down mountains, but if we increase our travel opportunities and do not move up to a larger trailer in the near future we'd certain get the brakes. It is still a curiosity to me as to why some small Burros have them and others don't, but at different times Burro's were made different places. Ours was made in Sac City Iowa.
Old 08-13-2007, 09:56 AM   #16
Doug Mager's Avatar
as you've seen, sometimes people just upgrade to brakes just for the safety factor, I doubt if any smaller early eggs had brakes from the facory unless they were custom ordered.
Old 08-13-2007, 10:33 AM   #17
Roger H's Avatar
Iowa
The '87 Burro 17' widebody I had was also manufactured in Sac City and, believe it or not, didn't come with brakes. The axle was also woefully underspec'd for the trailer weight as well. I installed a much heavier (and appropriately spec'd) axle with brakes immediately after I bought it.
Roger
Old 08-13-2007, 02:35 PM   #18
Here's an interesting site for CA brake requirements:
http://www.rvda.ca/ProviBrakeReqts.asp
I think what has happened is that the RV manfs have become more safety conscious, for a number of reasons, and have gradually upgraded the trailers.
Scamp, for example, used 1 7/8" inch couplers on the 13' and 16', then put 2" on the 16' and now uses 2" on both. Axles on the 13' were 1,200#, then 1,600# and now are 2,200#. I believe Casita 13' brakes were an option and now have brakes as standard. Small Coleman pop-ups now come with brakes standard.
As someone (Brian?) pointed out a while back, regardless of what the tow vehicle and trailer are, six braked tires on the pavement are more useful than only four...
brakes
Brakes JasonWesterman Towing, Hitching, Axles and Running Gear 3 12-04-2011 03:04 PM
13' Scamp brakes Jeff Larsen Towing, Hitching, Axles and Running Gear 4 08-09-2009 08:56 PM
Brakes getting too hot Alexandra B Problem Solving | Owners Helping Owners 0 07-20-2009 10:33 AM
Old Brakes Lainey Care and Feeding of Molded Fiberglass Trailers 13 08-31-2008 02:32 PM
Brakes for 16' Scamp davidwrench Towing, Hitching, Axles and Running Gear 3 05-24-2006 06:48 AM
