Breakaway Switch - How to wire it in - Fiberglass RV
Old 11-16-2012, 06:51 PM   #1
Hello all
I'm puzzling out the wiring on my Boler 13. I'm rewiring from scratch. An axle with trailer brakes is on the way. Right now I'm trying to figure out how to include a breakaway switch into the system. I have a 6 wire connector between tow vehicle and trailer. I will also have a 12volt battery onboard the trailer (possibly 2 golf cart batteries). I'm towing with a Subaru Forester, and have a Tekonisha P2 controller.
I'm planning to wire as recommended in this image (courtesy etrailer.com):
http://www.etrailer.com/Merchant2/gr...043_aa_600.jpg
Question: I have a Hopkins trailer breakaway switch. There are 3 wires on the switch. One is ground. That one is easy. The other two I'm not sure how to wire. How do I wire it in to the above diagram?
Derek
glamourpets is offline   Reply With Quote
Old 11-16-2012, 07:06 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
The breakaway switch has one lead connected to the blue brake wire and the other lead connected to the wire that goes to the fused battery lead (red/black in the diagram).
http://www.hopkinstowingsolutions.com/doc/20050.pdf
Old 11-16-2012, 07:21 PM   #3
Yes, there is an indicator led on the switch.
Let me see if I understand: if the pin is pulled the switch will complete a circuit between the red/black and blue wires. This will effectively tell the trailer to lock the brakes. When the pin is in place, the brakes will be activated by the blue wire which is connected to the brake controller.
Do I get it?
Derek
Old 11-16-2012, 07:25 PM   #4
Thomas G.'s Avatar
Originally Posted by glamourpets View Post
...........Do I get it?
Derek
That is how it works.
Old 11-16-2012, 07:36 PM   #5
Thankyou!
Old 11-17-2012, 07:39 AM   #6
Raz
Raz's Avatar
Vermont
You want the positive side of the battery connected to the blue brake wire when the switch is closed ( pin pulled). A caution: I read somewhere that you should not test the switch with your brake controller connected. Apparently you can damage some controllers this way. Unplug first, then pull the pin. You should hear your brakes magnets energize. If you jack up the wheels first, they should not spin. Be aware, you are draining your battery when you do this. Raz
Old 11-17-2012, 08:04 AM   #7
Thomas G.'s Avatar
.... A caution: I read somewhere that you should not test the switch with your brake controller connected. Apparently you can damage some controllers this way. Unplug first, then pull the pin. ....... Raz
So I guess the lesson is to have the breakaway cable just a little longer than the wiring harness.
Old 11-17-2012, 09:08 AM   #8
Raz
Raz's Avatar
Vermont
... and your insurance paid up.
Breakaway Switch Lawrence W Problem Solving | Owners Helping Owners 10 10-03-2010 01:35 PM
Breakaway switch cable snapped paulitzlee2 Towing, Hitching, Axles and Running Gear 11 08-22-2010 09:22 PM
Breakaway switch - do I need one? can I even get one? Shelley Towing, Hitching, Axles and Running Gear 1 06-30-2010 04:03 PM
Scamp 16' installing breakaway switch Carol H Towing, Hitching, Axles and Running Gear 23 04-17-2007 05:49 PM
Breakaway brake switch Rich McCormack Problem Solving | Owners Helping Owners 7 04-22-2006 08:59 AM
