"Bucking" feeling while towing in-town (trillium 1300/volvo 245) - Fiberglass RV
Old 10-13-2011, 07:41 AM   #1
Trailer: Volvo 245 pulling '71 Trillium 1300
On our way home with the new trailer, the highway driving was really smooth, but when we got to the city, I had some really unsettling bucking on a not-so-great stretch of road leading into the city. I could feel the trailer pulling back and pushing forward on the car as we went over some bumps - but it was almost as if we were getting into a resonant frequency where it would buck a bunch of times in a row.
The trailer is gutted so should be fairly light. The previous owner put new tires/wheels/bearings.
I have towed my utility trailer all over town without such unsettling bucking. WHen empty, it just bounces over bumps and when full I can feel the weight but I never feel like the trailer is driving the car. Any tips for troubleshooting? I'd like to start with the easiest checks and move on from there :-)
Thanks!
coalminecanary is offline   Reply With Quote
Old 10-13-2011, 08:19 AM   #2
Alistair Camelford's Avatar
Trailer: Trillium 13 ft 1973
a set of Firestone air "helpers" in my rear coils really helped my Sienna van smooth out the Trill 1300's ride.
Likely a gutted trailer lacks the tongue weight needed for a smooth pull (10 to 15 % of trailer weight on the hitch)
I use shims and an after market tightener to keep my hitch bar snug in the cars receiver...stops clunks.
Good luck with your new rig
Alistair in The Road Toad
Alistair Camelford is offline   Reply With Quote
Old 10-13-2011, 08:36 AM   #3
Otto's Avatar
Trailer: 89 Scamp 16 ft
volvo
You just need some more tongue weight. I use "Airlift" spring bags in our 245.
Caution Brick towing Egg.
Otto is offline   Reply With Quote
Old 10-13-2011, 08:45 AM   #4
IllAnnoy
Thanks!
I'm betting the road surface was concrete. Rythmic bucking is often caused on short trailers by a lack of competence on the part of the paver operator.
Of course you should check the grip on the hitch and the tightness of the draw bar.
The trillium 13 is particularly responsive to a friction anti-sway device since it likes to perform a slight "duckwalk" even when loaded properly.
(More of a quirk than a flaw) You should see an improvement when the axle is supporting a fully finished and properly loaded trailer.
Pavement quality and type will often affect the trailer's ride and so effect the TV's ride, and often must simply be tolerated until better pavement is found.
Old 10-13-2011, 08:54 AM   #5
Thanks - that's good to hear about the tongue weight. I plan to raise and stiffen the 245 eventually. It's all a matter of time :-)
Old 10-13-2011, 09:23 AM   #6
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
Hi Larry,
Same thing happened to me. Our little 13 footer is smooth as silk on the freeway but in a construction zone or going over speed bumps the trailer jerks a bit. Nothing to be alarmed about. It's just a bunch of competing forces pulling and pushing different ways. Just take it slow and easy.
Of course a light, stripped down trailer will bounce on bumps more and all the advice about tires, suspension, load balance is right on. But the same thing happened when I pulled a 2 horse trailer fully loaded with a half-ton Chev pick up. It won't seem too bad when you're used to it.
Phil
It's not the size.....
reeves99 is offline   Reply With Quote
Old 10-13-2011, 09:24 AM   #7
Trailer: 1984 Scamp 13'
Maryland
Double check the nut on the ball. This can produce similar symptoms. I also 2nd the hitch silencers. Quiets it down, plus less wear and tear on the hitch.
-Jesse
Old 10-13-2011, 02:28 PM   #8
Our receiver is basically fused in with rust. I have to verify that the ball is tight and the hitch is tight to the ball. Thanks for the tips!
Old 10-13-2011, 02:42 PM   #9
Saskatchewan
defintaly check the hitch on the trailer, I had borrowed a 13ft trillium for a wedding and encountered the same issue over a particularity undulating section of highway. The trailer had previously managed a partial escape on the owners TV as the coupler was very loose. I gave the nut a few more turns and it helped a bit, probably could have gone a few more though.
Orcus79 is offline   Reply With Quote
Old 10-14-2011, 12:50 AM   #10
Roger C H's Avatar
We had the same problem, especially on concrete with the seams.
It turned out to be the ball was not torqued to the correct specification. I tightened it to 100 in-lbs.
Read this thread. I found the solution in post #24.
Jerking while towing
Old 10-14-2011, 06:25 AM   #11
Great thanks... It's hard to search for this stuff when the terminology is almost completely subjective (bucking, jerking, galloping...).
We won't be towing this little guy for a while yet so I suppose this issue isn't urgent but it's good to rack up a few solutions before it does become so :-)
Old 10-17-2011, 04:05 AM   #12
Roger C H's Avatar
Talking Oops
That is 100 ft-lbs, not in-lbs.
Darn Gremlins.
Old 10-18-2011, 11:59 AM   #13
I've found a few things that can cause this feeling.
Concrete roads when your speed and the expansion joints are in sync.
Tires under inflated.
Ball and hitch not the same size or not adjusted properly.
The last two you can fix, the first the only thing you can do is slow down. However slowing down can get you closer to in sync and make it worse. DO NOT speed up, loss of control is more likely to happen at higher speeds.
trillium
"Original" Trillium Factory KEY RING/CHAIN? Dave Baston General Chat 0 06-09-2010 04:53 PM
I am the proud owner of a "new" 1973 Trillium 1300 Rob L General Chat 7 11-04-2009 11:47 PM
1970's Trillium 1300 converted to "toy hauler" $700 Raya Classified Archives 0 08-31-2009 10:31 PM
My "new" 1977 Trillium 1300 jimliston Problem Solving | Owners Helping Owners 12 02-10-2008 10:21 AM
Anyone put 14" tires on 1300 Trillium? H. Fred Fuller Towing, Hitching, Axles and Running Gear 6 07-01-2007 09:06 PM
