Bulldog Coupler - Page 2 - Fiberglass RV
Old 02-18-2015, 08:03 PM   #15
Now, can you run the same conditions, with the same tow and trailer so you can compare how the bulldog performs?
Never mind. Good anecdote.
Old 02-18-2015, 09:43 PM   #16
paulw's Avatar
Trailer: Escape
I replaced the damaged coupler on by 16' Scamp with a Bulldog. Was very happy with it, but you do need to watch for the pinch...
paulw is offline   Reply With Quote
Old 02-19-2015, 12:24 PM   #17
Trailer: '95 17ft Bigfoot
One thought for using a Bulldog hitch. I do not like to sleep overnight with the trailer hooked to the truck. Disconnecting from a standard coupler requires blocking the jack cranking up the trailer high enough to clear the ball, move the truck ahead then lower the trailer to level again. The Bulldog looks like it could simply be unlatched. If someone decided to steal the truck I think it would break loose in short order. All you would have to do is remember to relatch it in the morning.
stillwater is offline   Reply With Quote
1982 Burro Frame welded, new coupler installed MikeCM Modifications, Alterations and Updates 2 09-29-2009 07:21 PM
coupler height cyndi H Towing, Hitching, Axles and Running Gear 18 05-04-2008 05:52 AM
Boler Hitch Coupler A. Robert Reed Problem Solving | Owners Helping Owners 2 08-14-2007 05:46 PM
Coupler Concern Chris73 Towing, Hitching, Axles and Running Gear 7 07-30-2006 03:26 PM
coupler height cyndi H Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
