Can I do this? Scamp 5th wheel w/ Sierra 1/2 ton P/U - Fiberglass RV
Old 03-16-2012, 06:35 AM   #1
Steve M K's Avatar
Trailer: 17 ft Casita SD 2012(sold) looking again
I have sent two info requests to Scamp without response, I will call next. My question is whether I can pull the Scamp fifth wheel. I have a 2011 GMC Sierra half ton P/U regular cab, with standard bed. Max tow capacity is rated at 4700 lbs, I have the 4.8 liter V8 with 3.23 axle. I would think weight wise I am ok, but in the trailer towing chart for GM it says this vehicle is not rated for goose neck towing. Is the fifth wheel considered goose neck towing and if I did would I be violating the law and putting myself is some sort of liability. We love out little 13 footer, but need more room as we move into extended camping stays, and thought this might be a way to go.
Steve M K is offline   Reply With Quote
Old 03-16-2012, 09:49 AM   #2
Roy in TO's Avatar
Historically, Scamp is not known for responses to emails. Phoning is best.
Does the trailer towing chart say your vehicle is OK for 5th wheels?
If so what does GM say?
I received a PM from Brian B-P with respect to another thread on the Scamp 19. If I understand him correctly the hitch is "oddball" as it is not a true gooseneck nor is it a true 5th wheel.
Old 03-16-2012, 02:06 PM   #3
Steve M K's Avatar
Does not say I can not pull a fifth wheel, on the chart for max weights it just says gooseneck trailer N/A. So I am assuming that they do not want this truck pulling a fifth wheel. That being said I think the Scamp fiver is quite a bit different from the conventional fifth wheel.
Old 03-16-2012, 02:15 PM   #4
We pulled the Scamp 5r with a Chevy S10, V6 with no problem. With your larger truck it should pull like a dream.
Old 03-16-2012, 02:26 PM   #5
Steve M K's Avatar
That is good to hear that a S10 was able to handle this unit. Does anyone have pics of what the Scamp fiver hitch looks like?
Old 03-16-2012, 02:37 PM   #6
It does not look professional at all. Looks homemade and not finished off. Side plates bolt to the inside of the fender wells and the floor and a beam spans from one side plate to the other with the Ball in the center. Mine had sloppy welds, weld splatter and sharp corners.
Old 03-16-2012, 03:08 PM   #7
Sounds like the kind of welding I do !
Gorilla welds! Super strong, but really ugly!
Old 03-16-2012, 04:53 PM   #8
nikljones's Avatar
Trailer: 2012 Lance 1885
They now have a new hitch which is a commercial product. Still not a standard gooseneck or 5th wheel hitch but looks to be more substantial and better built. It also allows you to easily remove the hitch when not needed so you have full use of you truck bed. If you're on Facebook they have a picture of it here: https://www.facebook.com/media/set/?...6801610&type=3
Actually it's a public post so you should be able to see it anyway. I'm going to have it installed for my 5er when I pick it up on the 28th.
It is $350 though. They'll throw their version in for free.
Nick
nikljones is offline   Reply With Quote
Old 03-16-2012, 07:23 PM   #9
Greg H's Avatar
Trailer: 72 Boler American
Indiana
1/2 ton trucks are grocery getter's in the truck world. 3/4 and 1 ton trucks are for work and can pull or carry more. The Scamp 19'er will work fine with your 1/2 ton because it will not be that heavy.
Old 03-16-2012, 08:04 PM   #10
peterh's Avatar
That hitch is much nicer than the hitch I got with my (used) 5er.
Old 03-16-2012, 08:36 PM   #11
IllAnnoy
For many years, Scamp has used a 3.0L Ford Ranger to deliver 5ers.
Old 03-19-2012, 06:25 AM   #12
Steve M K's Avatar
Thanks all for the responses, It looks as if I will have no problems pulling a fiver. My next step as suggested on another post on the forum is to attend a rally to get a view of a fiver up close and personal. I hope to be able to make a more informed decision after actually seeing one.
Thanks again
Old 03-21-2012, 11:54 PM   #13
Roy in TO's Avatar
Steve,
I know there is a 5'r in Ypsilanti (sp?), where in MI are you?
Old 03-22-2012, 12:17 AM   #14
Thanks again
You should also give Escape trailers a call to see if they know of one of their 5th wheels in your area that you could go see, so you have something to compare the Scamp to.
Scamp 5th wheel or Escape 5.0 or other small 5th? Linda Gaudet Wanted: Molded Fiberglass Travel Trailers 16 04-27-2012 09:21 PM
Scamp 5th wheel in CA Camilla Referrals: Molded Fiberglass Trailers 3 10-26-2011 07:40 AM
SCAMP 5TH WHEEL ROBERT HYSER Wanted: Molded Fiberglass Travel Trailers 2 11-08-2008 10:31 AM
Looking for a Scamp 5th wheel Opal Wanted: Molded Fiberglass Travel Trailers 11 07-09-2007 10:28 AM
Anyone towing 5th wheel with Chevy Crew, 1/2 ton? Renee Problem Solving | Owners Helping Owners 1 03-04-2007 06:00 PM
