Can you over greese an easy lube fitting? - Fiberglass RV
Old 03-01-2019, 11:20 AM   #1
This has to have been covered before, but I don't see it. Can you over grease an easy lube fitting? I would think the grease would spill out through the rear seal and then get on the break linings causing all kinds of problems such as rendering the brakes useless or possibly even causing them to seize. Are these fittings worth anything? I've always packed by hand method every several years any trailer I've owned. I've never dealt with these things. In one video, I saw someone pump grease into the fitting until it came out clean around the fitting where the gun was attached. Isn't this a bit much and isn't this a potentially dangerous procedure that could lead to brake failure?
ae6black is offline   Reply With Quote
Old 03-01-2019, 12:08 PM   #2
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
Yes you definitely can over grease an easy lube system. Just as you indicated, if you keep pumping grease into the hubs it will have to go somewhere. That somewhere is out past the rear seal and onto the brake shoes.
When brake shoes get grease on them, first they slip, and then they start grabbing and will lock the wheel with very light application of the brakes. You will begin to notice that one wheel is locking up which makes the trailer pull to one side and skids the tread off the tire.
Bearings do need service occasionally, but they do not need repeated lubing, such as on every trip.
If you re-pack in the conventional way, you clean the bearings which removes bearing metal that is in the grease, you adjust the preload on them and you replace the rear seal. It's more work, but it is a better method than just pumping in more grease.
Raspy is online now   Reply With Quote
Old 03-01-2019, 12:12 PM   #3
You can't really over grease IF you do it right.. tire off ground, rotating, not too cool or too fast, etc.. the grease will just come out the front. However its really easy to do it wrong and have the grease blow out the rear seal as John described. I have elected to ignore the grease fitting on my spindle and repack the bearings the way it has been done successfully for decades.
Old 03-01-2019, 01:44 PM   #4
Originally Posted by ae6black View Post
... I would think the grease would spill out through the rear seal and then get on the break linings causing all kinds of problems such as rendering the brakes useless or possibly even causing them to seize. ...
BTW, kudos for adding that they might seize. Most people (and myself at one time) think that grease on the brake linings would cause them to lose friction and not stop as well if at all, but in fact sticking brakes is a common symptom of grease on the brakes.
Old 03-01-2019, 05:41 PM   #5
Name: John & Gloria
Trailer: Bigfoot 21RB
I have had Easylube spindles on my boat trailer for years with no trouble but they definitely can seem like a headache if serviced wrong. There are lots of different ideas about how to use them and I made mistakes and learned what works for me.
First of all we are assuming your spindle seal surface is good. Given that the next thing is you must have good quality seals such as Timken, SK or such. Be aware that many of the old standby names have developed two different qualities of products to compete with the Asian Invasion. Just verify that you are installing seals made in the USA to be sure they aren't going to lose their tension after a year. When you start pumping grease do so with a hand gun and not an air powered one. The grease has time to come through the in side bearing without putting excess pressure on the seal that way. As the grease starts showing movement all around the outer bearing by your grease zerk you have enough grease. At that point use your pinky finger and dig all the grease you can out of the area just inside the Easylube rubber seal. This gives a little room for grease as the hub warms up. If you pump grease in till that void is full, then when things expand as they warm up, the rubber plug can be blown out or grease forced by the inside seal. Anytime you walk by and see one of the rubber covers bulging out, pull the edge of the cover back just enough to burp the air out. When you do this and instead of a burp of air you get a burp of grease, then remove the cover and clean the excess grease out with your pinky again. Usually this will only happen after a bearing job. Once you don't see the rubber cover bulging after running for awhile you will be good for a long time. After a few months or a year pull the rubber plugs off and using your pinky dig what grease you can out of the space and wipe it on a rag. Is it the equivalent of 3 pumps on the grease gun? 2 pumps? 4 pumps?...what ever you get don't pump in any more than what worked out. You can continue doing this for years with no problems.
If you decide you want to "flush" the old grease out, that is fine, just keep pumping till you see fresh grease showing around the outside bearing. Be aware though if you do this "flushing" then you will have to be vigilant and go through the bulging rubber cover and burping air and extra grease again till it gets happy again
Travelin2 is offline   Reply With Quote
Old 03-02-2019, 07:08 AM   #6
I think that the EZ lube system is great myself. Can it be abused?
The answer is yes it can just like Bearing Buddies and traditional hand greasing.
The first thing to be aware of is that the grease should be warm and the pumping should be slow.
I have over 15,000 miles on my Flexi-Ride axle with EZ Lube and have greased then once.
One should be aware that high speed bearings cannot be full of grease and not overheat! The EZ lube system has the means to purge the old grease and then allow for the excess to be pushed out of the spindle.
Until the excess is pushed out the hub will run warmer than normal. Properly lubricated bearings will basically operate slightly over ambient temp assuming that the brakes were not being heavily used.
I check the hub temp with my hand at every stop out of habit and caution, The tires will run a little warmer and the one on the sun side a little warmer than the shady side.
Last year we made a tour of over 9300 miles and I greased the hubs before we left and I may regrease them this year again and then maybe not.
The hubs on you car were regreased when?????
With the sealed bearing cartridges on the front of FWD drive cars and the many many sealed bearing sets in use today it is very rare to hear of a wheel bearing failure and these sealed bearings actually have relatively little grease in them.
Most trailer problems are with boat trailer hubs that are immersed in the water and the contamination in this service is common and is actually the reason for the Bearing Buddies and EZ Lube in the first place.
My guess is that on most travel trailer bearing failures the root cause is a poor job of regreasing and over- greasing.
Perhaps attention to bearing temperature and benign neglect is a good choice?
Old 03-02-2019, 10:29 AM   #7
Trailer: 2016 -13' Scamp
Massachusetts
Thanks for all the great advice. I'm saving this information to give to my mechanic!
herons is offline   Reply With Quote
Old 03-02-2019, 12:13 PM   #8
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Thanks all for this info. We have our first trailer with EZ-Lube axles, so far have not added any grease. I think the old, "take-em-apart-wash-and-hand-pack" is best as it cleans out all the old guck, lets you inspect the bearings and seals.
Some places recommend new seals as you can't remove the old ones without damage.
You really don't want the cavity in the hub packed full.
I'll probably just take the ParkLiner to a trailer shop and have them do it.
Old 03-09-2019, 11:41 AM   #9
Red face Bearing solution
Aircraft routinely use sealed bearings to avoid the hassles and costs of bearing service entirely. Sealed bearings are available for some trailer axles that are warrantied for 100,000 miles without any service.
Stephen_Albers is offline   Reply With Quote
Old 03-09-2019, 11:54 AM   #10
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I almost totally agree except that if I have the time and the ambition, I do it myself!
CPW is online now   Reply With Quote
Old 03-09-2019, 05:15 PM   #11
vintageracer's Avatar
Name: To Infinity & Beyond!
Trailer: 2 - Uhaul VT-16 Vacationer's & 1977 Argosy 6.0 Minuet
Easy lubes are for BOAT trailers due to their submersion in water not RV trailers!
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"!
vintageracer is online now   Reply With Quote
Old 03-09-2019, 08:40 PM   #12
Raspy's Avatar
Bearing buddies are for boat trailers, Easy-Lube is for trailers that don't get submerged. Bearing Buddies allow one to add grease to raise the pressure in the hub so no water can get in while submerged. It keeps water out by being at a higher pressure. The grease gets added outside the bearings into the new "hub cap" that has a zerk on it and a spring loaded seal. These do nothing for lubing the inner bearing. Easy lube is a system that flushes the old grease out while adding new. But Easy-Lube will not prevent water intrusion very well, or reliably expel water that does get in. They are not designed for that purpose. Easy lube cannot be used to raise the hub pressure for water immersion.
Old 03-09-2019, 09:03 PM   #13
IllAnnoy
While some folks could destroy an anvil with a rubber mallet, the simple answer is...
No, EZ-Lube axles can not be over greased.
Old 03-09-2019, 09:08 PM   #14
Why I hate EZ Lube Hubs:
https://expeditionportal.com/forum/t...be-hubs.74631/
Yes I was confused with Bearing Buddies when speaking of boats.
Mike
EZ-Lube axles: Should you purge the grease that is inside the spindle? gordon2 Towing, Hitching, Axles and Running Gear 25 07-30-2017 06:10 AM
To lube or not to lube, THAT is the question... Doug Mager Care and Feeding of Molded Fiberglass Trailers 14 08-19-2011 06:26 AM
Eggs Over Easy, this morning!!! Doug Mager General Chat 2 10-11-2009 08:55 AM
Over easy ronsmith100 General Chat 10 08-20-2009 09:24 PM
