Changing Axle Bearings on a '74 Ventura - Fiberglass RV
Old 06-25-2013, 11:52 AM   #1
Trailer: 1974 Ventura
Saskatchewan
Question Changing Axle Bearings on a '74 Ventura
Hi Everyone,
My Wife and I just picked up a 1974 Ventura on the weekend and I just joined this forum. Looking to get it ready for a big trip out to BC from SK here in Canada. I have no idea what maintenance has been done to this trailer and I have a couple weeks so I'm trying to go through and replace a few things.
I'm looking to change out the axle bearings and grease them up. Has anyone ever done this? How often should it be done? I'm considering seeing if Princess Auto has a kit to do it. Just looking for some advice. Also, my tug is a 2011 Jeep Wrangler Rubicon. I doubt I'll have any issues pulling it.
One other question. Has anyone ever used a single bed (bench seat) for a small child? Trying to figure out options for my 8 mo. old little girl so we won't fall off the bunk while sleeping. She stands up in her crib already but doesn't walk if that helps. Suggestions? Greatly appreciated!
Dave Ventura is offline   Reply With Quote
Old 06-25-2013, 12:26 PM   #2
IllAnnoy
Originally Posted by Dave Ventura View Post
Hi Everyone,
Clean and inspect the bearings, replace only if there is a problem..( damaged cage, rust, spaulding etc.) If you buy new bearings inspect them as well. It is commonly considered prudent to replace the races with the new bearings as sets.
For the bunk...
A frame with a web material like the sides of a pac&play, or maybe you could modify one of those "baby gates".
Old 06-25-2013, 02:28 PM   #3
Saskatchewan
Thanks Floyd! Ya, I might bring it in to work tomorrow and have a look at it in our welding fab shop. I think I might mod the back bumper as well by welding on a 2" receiver so I can insert a metal framed basket or bike rack. Just picked up a single holed faucet because the 39 year old plastic one busted, and some new marker lights for her too.
Also, the pac n' play type frame with mesh idea is what I've been thinking. Just need to find something inexpensive to make work. Might just end up putting her on the floor on the mat for sleeping anyways. Just have to move her when we wake up due to space constraints.
Old 06-25-2013, 03:11 PM   #4
Roy in TO's Avatar
Well if you are going to Princess Auto, have a look at the mesh bungee things for ATV's - they might just work for the sleeping barriers.
Old 06-26-2013, 06:51 PM   #5
Hi Dave, I see you're new to FiberglassRV so We're glad you're here
Old 06-26-2013, 07:54 PM   #6
If it's still the original bearings there is a good chance that some of the rollers will be cracked or burned. I always start a new trailer out with a new set of bearings and races as well as new seals.
Take out an entire set and take it to your auto supply shop for them to match them.
Not to scare you, but some of the older trailers (i.e. Hunter's) can have obsolete seals that may be hard to find.
Good Luck
Old 06-27-2013, 10:27 AM   #7
Saskatchewan
Thanks Donna. This seems like a great site with lots of info and people with a wealth of knowledge that are enthusiated about the fiberglass camping/living world.
And Roy,not a bad idea but I'm sure my kid will just get tangled. She's quite busy. ha.
I'll try that out Bob, thanks. Still have a week before our big trip and lots to do before then!
Old 06-27-2013, 11:19 AM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Since you're a professional I s'pose you already know this, but for others reading the thread who may not:
Do make sure to add trailer frame reinforcements sufficient to support such a mod- even bigger conventional trailer bumpers aren't able to withstand such loading without additional support.
Francesca
Old 06-27-2013, 01:09 PM   #9
Saskatchewan
Welding Modifications
Francesca
Yes Francesca, you are correct. Anyone wanting to do any modifications by means of welding needs to understand the integrity of the stress being put on the material under load. The bumper on the back of my Ventura is basically a thin walled C-channel. When I put on my 6x2" receiver, I'll be adding some backing plate and 1/4" fillet welds all around it. If there's any questions about the integrity of the weld, a magnetic particle inspection may be used only for peace of mind sake to ensure there are no weld defects. Also, keep in mind that fiberglass RV's don't weight very much either so don't put too much heavy stuff on the back because you still need tounge weight. I'm not a welder but a welding inspector so if anyone has any questions welding/metal related please let me know if I can help!
Old 06-27-2013, 02:20 PM   #10
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
....... If there's any questions about the integrity of the weld, a magnetic particle inspection may be used only for peace of mind sake to ensure there are no weld defects. ......
Which isle is that device stocked in at the Harbor Freight store?
Old 06-27-2013, 03:54 PM   #11
Brian B-P's Avatar
I wouldn't worry about the welding in this case, but even if it is perfect the hitch load is still all on that bumper. The usual solution to the bumper twisting under load is to extend the receiver tube forward to the next crossmember.
I would fall over in shock if I heard of any RV manufacturer using NDT to examine weld quality.
Old 06-27-2013, 04:14 PM   #12
Brian B-P's Avatar
I'm looking to change out the axle bearings and grease them up... Just looking for some advice.
Even if you don't have a Dexter axle, I suggest downloading the maintenance manuals from Dexter Axle. You will hear a lot of advice regarding bearing maintenance procedures, and some is just wrong (no problems with what has been posted in this thread so far!).
Old 06-27-2013, 06:50 PM   #13
frank_a's Avatar
Trailer: 2012 ParkLiner #006
The way I test bearings is I see if my fingernail catches anywhere in the cup with the cone out. If so, I change cups and cones. A lot of times I will do that scratches or no just for peace of mind. You'll need new seals and cotter pins.
Often, bearings and seals for standard size axles are readily available as kits. I find NAPA has a good selection, but I imagine any auto parts retailer could help you get the right stuff.
Good luck!
Frank
frank_a is online now   Reply With Quote
Old 07-01-2013, 11:04 PM   #14
Saskatchewan
Thanks everyone. Good suggestions. I will look into it.
axle, ventura
Changing user name bkboler General Chat 8 04-14-2012 12:18 PM
pre-trip check: axle/wheels/bearings/tires Tom Byron Care and Feeding of Molded Fiberglass Trailers 1 08-06-2010 02:13 PM
Pro's and con's of changing axle height Kent I Towing, Hitching, Axles and Running Gear 4 11-28-2009 11:02 PM
do i need to pack axle bearings on scamp '13 Dan Vang Care and Feeding of Molded Fiberglass Trailers 3 08-28-2009 09:59 AM
Changing Username Booker B. Forum Admin, News & Announcements 4 03-14-2008 08:56 PM
