Changing from 6 pin to 7 pin on truck - how?? - Fiberglass RV
Old 07-26-2009, 01:24 PM   #1
Shelley's Avatar
Trailer: 1977 Triple E Surfside
My truck came with 6 pin wiring and the trailer is 7. How do I switch it over and how easy is it to add a brake controller...by myself....
Thanks!
Shelley is offline   Reply With Quote
Old 07-26-2009, 01:46 PM   #2
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
6 PIN SMALL ROUND SOCKET TO 7 PIN SMALL ROUND PLUG
$20.00
http://images.google.com/imgres?imgurl=htt...1GtbFmQfZquiOBA
Old 07-27-2009, 09:36 AM   #3
Thanks!
this should help!...
http://www.etrailer.com/faq-wiring.aspx
Old 07-27-2009, 02:03 PM   #4
Shelley's Avatar
The wiring diagram is great!
Is adding a brake controller doable for a newbie or should I try a hitch shop?
Old 07-28-2009, 10:45 PM   #5
There are 4 wires that go to a brake controller... Black, White, Blue, and Red...
Black is positve battery voltage and should be run to the battery through a 20 amp auto resetting circuit breaker.
White is ground and should be run directly to the negative batt terminal
Blue goes to the 7 pin for the brakes,
Red connects to the brake light switch....
Hope this helps....
Bob
Bob Elder is offline   Reply With Quote
Changing rims on 13' scamp DavidS Towing, Hitching, Axles and Running Gear 3 08-08-2009 06:55 PM
Changing Username Booker B. Forum Admin, News & Announcements 4 03-14-2008 08:56 PM
changing tires cyndi H Towing, Hitching, Axles and Running Gear 8 09-17-2007 12:27 AM
Changing LP regulator Legacy Posts Problem Solving | Owners Helping Owners 10 07-02-2003 08:04 PM
