Changing tire width 2003 Bigfoot - Fiberglass RV
Old 08-20-2017, 07:52 PM   #1
Tony Nowak's Avatar
Trailer: 2017 Escape 17
Mount Horeb, Wisconsin
Our current Tow Max tires 225/75/15 are long in the tooth and we need to replace them. The local Discount Tires has Goodyear Endurance in both 205 and 225 widths. We'd like to good with the 205s in that the 225s we have now are very close to the drivers side wheel well skirt and has even worn a way a bit of it. This seems to have happened after an axle change. I see the factory plate on the outside has 205/75/14 as a tire size and I'm sure the original owner did not change from a 14 to a 15. This suggests to me that a 205/75/15 would be OK. Thanks for any thoughts or input.
Tony
Tony Nowak is offline   Reply With Quote
Old 08-20-2017, 08:33 PM   #2
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Being narrower, it might sway a bit more. But as long as it's load rating is comfortably above the weight it will carry, it will be fine.
Get the highest quality you can instead of the normal cheap ones that are so readily available.
Old 08-20-2017, 10:36 PM   #3
The first number indicates the width of the tire at its widest point when it is mounted on the rim and inflated. A 225 -75-15 is 225 millimeters wide and a 205-75-15 would be 205 millimeters wide. (20 millimeters narrower) 1 inch = 25.4 millimeters
Old 08-21-2017, 10:26 AM   #4
Get the actual loaded weight on the tires, make sure the ones you get can carry that load. Adjust air pressure accordingly.
bigfoot
Bigfoot 17 awning width Jacqueline in BC Care and Feeding of Molded Fiberglass Trailers 12 06-28-2017 05:10 AM
What is the Entrance Door Width on a 17.5 Bigfoot and a 17 Foot Casita Paul_G General Chat 9 01-13-2016 10:18 AM
Butyl tape: What width and thickness to order? Raya Care and Feeding of Molded Fiberglass Trailers 9 08-21-2015 01:14 PM
Changing a tire Down the Road Problem Solving | Owners Helping Owners 6 10-23-2013 04:40 AM
shoulder width Peggy Problem Solving | Owners Helping Owners 9 03-28-2008 06:33 PM
