Changing wheel hubs??? - Fiberglass RV
Old 06-01-2012, 11:04 PM   #1
Name: Eric & Stephanie
Trailer: currently without
Idaho
I have a 1983 Fiber Stream with twin axle. The current rims look original and have a 4 on 3 bolt pattern. It seems difficult to find replacements in this size. I'd like more options for rims and tires.
Has anyone with a Fiber Stream switched to a different hub, such as 4 on 4, or 5 on 4.5? If so, is it a do-it yourself job (I have a fair amount of mechanical aptitude) or should I take it to a pro?
Thanks for your feedback,
Eric
sanders3 is offline   Reply With Quote
Old 06-02-2012, 08:35 AM   #2
IllAnnoy
Eric
Since axles are generally manufactured by axle makers then spec'd and purchased by the trailer maker, it might be usefull to know who the axle maker was and what model.
Failing that, you would need to know the spindle size and whether it is straight or tapered.
Check the bearings, when clean, they have a tiny legible part number stamped into the inner race. Cross the number with those used on more commn hubs.
If you have brakes , or if the hub flange is large enough you might consider redrilling for the desired bolt pattern.
I'm betting that there is a direct fit hub or brake assembly available.
Be aware that straight spindles are commonly 1"(older) and 1-1/16"on the newer ones.
Hope this helps
Old 06-02-2012, 09:00 PM   #3
Idaho
Thanks Floyd, that's some good info.
Eric
Old 06-02-2012, 11:22 PM   #4
Trailer: Fiber Stream
The tire shop I use had no trouble ordering new replacement wheels for my '78. If you decide to replace yours, I like to buy your originals.
hubs h.mike Towing, Hitching, Axles and Running Gear 3 07-03-2011 12:14 PM
wires from hubs? Joe Steadman Problem Solving | Owners Helping Owners 5 08-23-2010 08:55 AM
Can I set my hubs/drums on wheel dollies? Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 06-14-2010 09:07 AM
Pressed steel wheel hubs Andrew A. Clark Care and Feeding of Molded Fiberglass Trailers 4 06-03-2006 04:30 PM
Oil filled Hubs Legacy Posts Towing, Hitching, Axles and Running Gear 4 10-29-2002 03:31 PM
