charging trailer with tug - Fiberglass RV
Old 06-01-2009, 11:41 AM   #1
Trailer: 73 Boler (modified)
hello all. going to kejimikujik national park this weekend, and i've got a new (to me) tug this go around. I've finished setting up my trailer lights and connection, but now i'm going to set up the 12v so that i can charge the trailer with the tug. the boler is already wired for that in the 7 pin round connector, I just never got around to doing it on my previous tow vehicle.
so, are people connecting their +12volt right straight to the battery (with fuse of course)? I had the idea to use a 2nd battery switch, or an isolator like this:
which is basically a heavy duty relay: when the key is in the run position, it' will turn the relay on, and connect the batteries to charge the accessory, or trailer. when the key is off, the current is disrupted so the tug battery cannot be drained by the accessory. I asked my father who's towed all his life - he has a stick built truck camper, with much the same amenities, but his charging wire goes directly to the tug battery.
i'm confused because nobody talks about this, but do people ever worry about not being able to start their tug in the morning? I know in my old van i had a dual batteries under the hood, and one was isolated in this fashion. is it overkill, or a good idea?
Nate is offline   Reply With Quote
Old 06-01-2009, 01:38 PM   #2
anybody? i suppose I'm going to go ahead and use the relay, as I have now got the wire from the battery to the rear bumper loomed, taped and cable-tied.
Old 06-01-2009, 02:01 PM   #3
The Hobo's Avatar
Trailer: 1976 Triple E Surfside
I have mine charging while driving only.
No relays ect ect.
Works perfect.
1976 Surfside Tripple-E
The Hobo is offline   Reply With Quote
Old 06-01-2009, 02:57 PM   #4
so what does that mean? does it mean you have a wire running straight from + on your tug battery straight to + on your trailer Battery? do you just disco the umbilical cord when you park?
Old 06-01-2009, 03:23 PM   #5
Greg A's Avatar
Trailer: 2015 Escape 19
We have a direct charging line running from the battery on the tug with fuse between to the 7 pin connector and then straight to the trailer battery when connected. Yes, the 7-pin connector is disconnected when we arrive, and some folks put a battery disconnect switch so they can disconnect that way and leave the connector hooked up.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 06-01-2009, 04:54 PM   #6
pjanits's Avatar
Trailer: 17 ft 1986 Burro
The relay will do the same thing, disconnect the battery on the trailer when then ignition is off. I have one but never wired it in because we just unplug the tow when we get there.
But if I forget I always have that handy jump-it.
Old 06-01-2009, 05:04 PM   #7
Trailer: Fiber Stream
Talking
I paid to have my charge line installed at Camping World. They installed blocking diodes near the Honda's battery which allow current to flow to the trailer's battery when the car is running but not when it is shut off. They used different hardware, but it does the same thing your setup does.
Old 06-01-2009, 05:21 PM   #8
Larry C Hanson's Avatar
Hello, Here is the setup I use with great success. I used it with my
last 13' Trillium keeping the battery charged up and allowing the
refrigerator to run on 12 VDC while traveling. With the isolator
there is no need to worry about disconnecting the trailer hookup
saving a fancy switch and some effort. When I stop for over an
hour I switch the refrig to propane.
Parts:
Sure Power Industries Multi Battery Isolator Model 9523A (95 Amp Max)
-- Note: The Model 9523A has an extra terminal "E" to use with GM vehicles.
-- A Model 952 would have sufficed for this application.
50AMP DC circuit breaker
# 6 wire - 30 feet (#6 instead of #8 for long run to rear of truck)
MISC: terminal lugs, heat shrink tubing, solder, etc.
The output of the alternator (RED) was disconnected and a New (RED) wire
run to the isolator input terminal A.
Isolator # 1 connection to (BLACK) wire that was hooked to the wire originally on
Alternator output going to vehicle battery.
Isolator #2 output goes to a 50 AMP circuit breaker and then #6 wire (WHITE) back to
battery connection on the trailer receptical.
Also, a #6 Wire was run from the alternator case to the frame rail in the
engine compartment and off the frame rail to Ground on Trailer connector.
This helps ensure a low resistance path for the ground, too.
Hope this helps some fellow FRG owners. If anyone has any suggestions
to help improve this setup, please post as I am looking for a new tug and
want a similar setup on it. Larry H
Old 06-01-2009, 05:29 PM   #9
ahhhhhh - it didn't occur to me that people unplug the umbilical cord. I always leave it connected which is why i couldn't wrap my head around a direct connection.
thanks to all that responded - I grew up with truck campers, it's a hassle to disconnect the umbilical cord so by force of habit i always leave it connected on my boler.
For what it's worth, i did end up using the dual battery switch, and I also ran a ground line from the neg on the tug to the back, grounding it to the frame, hitch, and right in to the 7-pin. boler taillights are brighter now...guess after 18 years, my toyota's grounds have fizzled a little!
Once I get the interior cleaned up a little, I'll throw some pics of my Boler up finally!
Old 06-01-2009, 06:34 PM   #10
Trailer: 2013 Escape 19
We use a Blue Sea automatic charge relay (ACR) as pictured. It senses the tow vehicle voltage and only switches on when the engine is running, triggered by the higher voltage present with alternator output. It may be overkill, but it has worked great for two years on two different vehicles. It just goes in series with the power lead to the house charging line and uses one short sensing lead to get the TV's charge system voltage. It's even adjustable, but I've never felt the need to change it. http://bluesea.com/category/2/productline/overview/386
Parker
Parker Buckley is offline   Reply With Quote
Old 06-01-2009, 06:49 PM   #11
Marv Watson's Avatar
Trailer: 1978 Trillium 13 ft
Great Lakes area-US
By "#6" do you mean 6 ga. wire? This may be the most important aspect of running from tug battery to camper. I paid a trailer hitch place to hook me up that way and they used 14 ga. wire, which later on I found out is not adequate to push the current all the way to the back end of my 13' Trillium where the battery is. So, now I'm faced with doing it right. Please confirm proper wire gauge or size. Thanks.
Marv. W.
marvonw
Marv Watson is offline   Reply With Quote
Old 06-01-2009, 08:26 PM   #12
By "#6" do you mean 6 ga. wire?Please confirm proper wire gauge or size. Thanks.
Marv. W.
Evening Marv... by #6 I meant 6 Guage. Larry H
Old 06-02-2009, 03:48 AM   #13
The Hobo's Avatar
We have a direct charging line running from the battery on the tug with fuse between to the 7 pin connector and then straight to the trailer battery when connected. Yes, the 7-pin connector is disconnected when we arrive, and [b]some folks put a battery disconnect switch so they can disconnect that way and leave the connector hooked up.
That's exactly what I have(right on the batterie box cover).
Old 06-02-2009, 09:59 AM   #14
Marv. W.
I used 8 gauge wire, as that was what was on the trailer from the batty to the tongue, so I met it with the same from the tug. 14 is awfully small for the task, i would'nt go any smaller than 8.
Battery charging paulitzlee2 Problem Solving | Owners Helping Owners 1 09-15-2009 10:12 PM
Charging with tug curtis c Problem Solving | Owners Helping Owners 13 07-15-2009 11:04 AM
Charging Battery from TV Tim Ryce Problem Solving | Owners Helping Owners 17 09-25-2008 07:58 PM
Battery Charging Chester Taje Problem Solving | Owners Helping Owners 4 08-01-2007 05:56 PM
Battery Charging JOE DRISSEL Electrical | Charging, Systems, Solar and Generators 23 01-08-2006 03:03 PM
