Check Your Hitch Ball ! - Fiberglass RV
Old 09-08-2007, 10:14 PM   #1
Trailer: 2007 Trillium Outback / 2007 Toyota Tacoma
Just returned from a great 7662 km trip to Fairbanks. When getting close to Dawson City and going over some frost heaves heard a clunk in the back. Lots of stuff in the back of the truck so didn't think too much about it. Little further down the road it became a Clunk Clunk which got my full attention. Found the ball had come loose, the lock washer was doing nothing and the nut was now "finger tight loose". It all happened quickly.
A reputable shop had put the ball on and I had greased the ball but I obviously had the clamp too tight. Was a bit of a shock as I've spent most of my life with wrenches in my hand. Temporary repairs were made and now carry a good sized pipe wrench.
Brian T is offline   Reply With Quote
Old 09-08-2007, 10:27 PM   #2
Gina D.'s Avatar
West Coast USA
My very first ball had a cotter pin in the threads, run right through the center, below the nut.
I have not been able to find one since.
Next best thing.. a nylock nut, but I can barely get a #10 on a bolt.. I can just image what one the size of the ball bolts would take to get on!
My small one for my sway bar has a nylock, but Mr. Macho welder instaled it.
Old 09-08-2007, 11:10 PM   #3
Trailer: 2000 17 ft Casita Freedom Deluxe
U-Haul carries them
Ted
Ted Tuchsen is offline   Reply With Quote
Old 09-09-2007, 07:48 AM   #4
BobB's Avatar
I had the nut on the coupler ball come loose the last trip out. Noticed it when I unhitched at the campsite. Obviously, I didn't get it tight enough! My second mistake was I didn't remove the sway control before backing in, and in this case I had a lot of difficulty getting the trailer backed in due to a narrow opening with trees and rocks. The nut on the coupler ball needs to be tightened to at least 200 ft-pounds, something that can't be done with a crescent wrench (maybe a 400# gorilla could). It's also recommended that there are 3-4 threads showing when the nut is tightened, something I don't have. So now I'm looking for a longer ball shank and a better wrench! I also need to have the plate for the sway control welded to the ball mount.
Old 09-09-2007, 09:26 AM   #5
I always drill a hole through the nut and bolt and insert a pin.
Old 09-09-2007, 07:57 PM   #6
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
I just bought a Reese $10 wrench at Wal-Mart to get my new 2" ball attached to my new 50# WDH. I can't imagine the ball coming loose after tightening with this 16" long wrench. If I had another 1" nut I would double up.
PS - Five days to Casita time.
Patrick M. is offline   Reply With Quote
Old 09-10-2007, 03:34 AM   #7
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
I also can not believe that the ball could come loose!
I had to change the ball from my 1 7/8 to a 2 inch to haul a buddies trailer and upon takeing the ball off I had to use a 16 inch wrench with the both arms pushing against it.
The lock washer left a 1/16 inch grove, in the step down, where it was doing it's job locking the nut.
I would think if my trailer had enough pull to loosen that it would probably shear off any cotter pin and as far as the nylon lock nut forget it.
Gerry the canoebuilder
Old 09-10-2007, 05:49 AM   #8
Mike Watters's Avatar
Trailer: Amerigo & Trailmanor (popupish)
Indiana
Same thing happened to me last trip out. The nut was loose and the ball was quite floppy. I hand tightened it as much as I could and stopped at a WallyWorld to get a hitch wrench to finish the job.
I'm very fond of the nylock nuts too! I use them whenever possible on every trailer I've had. Ultimately, what I like about them is that even if they start to loosen - once loose, they'd just sit there. With normal nuts (even with lock washers), once they are loose - they just freewheel and vibrate further down.
Mike
Mike Watters is offline   Reply With Quote
Old 09-10-2007, 06:11 AM   #9
I replaced the 1-7/8" ball for my Scamp last year. Went to U-Haul and purchased a 5,000# ball. A nice fella mounted it on the stinger for me, he used a torgue wrench. I didn't see how many foot/pounds it was set for, but it was considerable. Also used a nylon washer. He did tell me if I ever took the ball off to be sure to replace (not reuse) the nylon washer. The total cost was less than $10.
Old 09-10-2007, 12:00 PM   #10
The major mistake many make is the reuse of the lock washers. They R met to be tightened only once and never to be un-tightened and/or reused.
I use the lock washer and I still drill a hole through the nut and bolt and insert a pin that can not b removed because I have had nuts loosen in the past.
It is not susposta happen however it just does. Go figure.
Old 09-10-2007, 06:30 PM   #11
Brian B-P's Avatar
Those lock washers may look like they're working, but I agree with Mike - self-locking nuts (such as Nylock) are much more effective. I think if you look at the critical fasteners on a car, or an aircraft, you'll find various locking methods, and none of them will be split lock washers. I've got a split lock washer on the ball used to tow my Boler, but I certainly don't think it's the best locking device; I would have much more confidence in a drilled or castellated nut and cotter pin.
I assume that the nylon washer used on Donna's setup is the crush washer sold by U-Haul: when sufficient clamping force it reached (because enough tightening torque has been applied), parts of the washer visibly split and burst outwards. It then just acts as a slightly soft washer, and you need a new one next time to watch for the splitting as an indication that the nut is sufficiently tight.
Old 09-11-2007, 07:35 PM   #12
Pete Dumbleton's Avatar
Brian, you're right! The washer isn't really a washer but a torque indicator (by crush as you described, kinda like PlastiGage) and UHaul provides two of them with a new ball, as well as the cotter pin for the hole. I was surprised at how much torque it required with a pipe wrench and a pipe over the handle to get the proper crush!
Old 09-12-2007, 04:29 AM   #13
Maine
Lets look what caused the problem in the first place....
The hitch on the camper was too tight and it acted like a clamp, loosening the ball instead of being able to swivel around.
I realize the latch needs to be tight but there are scare stories out there the other way too about the latch being too loose and comeing off so there in lies the problem...to fnd the proper tightness of the hitch so it will not bounce off yet not be so tight as to clamp the ball and unscrew it from the nut...
That is it the nut is not turning off but it is the ball is turning off the nut.
I can lift the rear end of my Blazer with the tounge jack but the thing swivels fine while moveing...I do not use grease as this collects dust which in my opinion can ruin the inside of the hitch .
I made sure the inside of the hitch was free of burs nicks and catches on the latching system as not to be able to catch the ball in any way and I have had a new shinney ball put on and after a 100 mile journey saw not even a scratch on the ball anywere.
So in conclusion do not tighten it so tight your clamping the ball.
These are my thoughts on the issue.
Wonder what others think?
Old 09-12-2007, 06:05 AM   #14
New tip I've heard is to use a sheet of the dry "Swiffer" sheet on the ball. I haven't tried this, but it makes sense.
Help! My hitch and ball are grinding and gouging Ron Stewart Towing, Hitching, Axles and Running Gear 16 10-09-2009 12:45 PM
Burro hitch ball Lee Senn Towing, Hitching, Axles and Running Gear 6 04-19-2009 01:39 PM
removable hitch ball Sandra Lair Towing, Hitching, Axles and Running Gear 22 04-18-2009 08:57 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
Ball Hitch size for '82 Burro Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 08-15-2003 09:39 AM
