Compact Jr Spring Advise - Fiberglass RV
Old 05-03-2015, 11:56 AM   #1
Trailer: Compact Jr and Teardrop Trailer
I just picked up a 1972 CJR yesterday. It looks the drivers side spring has flattened out so I plan on replacing them. What size and weight capacity should I use?
Jeremy
rainjer is offline   Reply With Quote
Old 05-03-2015, 12:07 PM   #2
Trailer: 2010 Escape 17B
That's a cute one from Spokane area right, I saw it advertised.
Have you got more pics, looks great.
kootenaigirl is offline   Reply With Quote
Old 05-03-2015, 12:11 PM   #3
Yes, we picked it up yesterday. 650 mile and 15 hours round trip. I do have more pictures on my wife's phone. I will post them later.
Old 05-04-2015, 08:42 AM   #4
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
You might get by with a 2,000 lb axle, but I really recommend a 3500 lb. The peace of mind for a small cost difference is worth it. Dexter makes good axles in this range and the ones that go with springs are very reasonable in price.
Walt
Old 05-04-2015, 09:23 AM   #5
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
To add to Walt's points, now is the time to add brakes.
Old 05-04-2015, 09:23 AM   #6
Trailer: Shopping
Weigh it, add the expected weight of all your gear & fluids. Then add a good safety margin, at least 20%. 3500 might be good, or it might end up being overkill. Overkill is fine for support, but it will make the trailer ride really rough subjecting it to more abuse & impact than the right rated one.
Sent from my A0001 using Fiberglass RV mobile app
Fallon is offline   Reply With Quote
Old 05-04-2015, 09:31 AM   #7
WaltP's Avatar
SW Virginia
Fallon's point is valid. I just didn't think you'd wind up much lower than 2,000 lb and I think the next size up is 3,500 lb. And BTW, I added the Dexter shock absorber kit to my 3500 pounder for a smoother ride.
Depending on the state, brakes are required anywhere from 1,000 lb to 3,000 lb.
My 13' Casita didn't have brakes and I wouldn't do that again.
Walt
Old 05-04-2015, 09:54 AM   #8
Trailer: Shopping
Walt
Brakes probably aren't needed, until the one time they are. It only takes once when you need that extra couple feet of braking distance reduction or the ability to stop a fishtail to pay for them ten times over. I wouldn't ever replace an axle & not get brakes, regardless of what was on there before.
They don't cost that much or add much weight, but they can literally be a life saver. Well worth it.
Old 05-04-2015, 10:20 AM   #9
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I believe Jeremy was talking about replacing the leaf springs only, and wanting to know what spring rate to use, and not replacing the entire axle.
Old 05-04-2015, 10:59 AM   #10
Trailer: Shopping
Ah, was thinking of torsion axles where you have to replace the whole axle, not leaf springs.
Old 05-04-2015, 11:16 AM   #11
David B.'s Avatar
Trailer: Lil Snoozy
Jeremy
You can also just have the springs "re-arched" instead of replacing them.
Old 05-04-2015, 12:52 PM   #12
It turns out here are 2 different springs on the trailer so I be replacing them rigth away. I need to figure out what length I need also. You can see the angle of the rear hanger in this pic.
I am being tol the rear attacment sould be angled towads the back.
This is how mine are installed. Just not much angle.
Jeremy
Old 05-04-2015, 02:53 PM   #13
BTW - The axle may be done also. The ride hight is only 10". I need to raise it 3-4" if possible. I am going to try move the axle under the springs when I replace them to see how much I gain. If that does not work then I will order a straight axle with brake flanges for future use.
Jeremy
Old 05-04-2015, 03:33 PM   #14
Trailer: 2014 Escape 21
Virginia
Jeremy
If you want to raise the trailer I would go with a 2K straight axle,springs and all new hardware. Don't forget to order bushings for your shackle attaching point and springs. I just rebuilt a Trails West axle set up and spent a lot of time researching parts and in some cases had to use some of the old parts. Remember when you raise the trailer your coupler will also be raised.
My experience with these types of trailers is they tend not to ride as smoothly as trailers with the flex axles.
These axles are fairly inexpensive even when ordered from Dexter. When ordering from Dexter you can get exactly what you want as far as options.
Eddie
Need advise on new converter upgrade FredericL Problem Solving | Owners Helping Owners 9 05-14-2009 08:52 AM
Advise on Foam for cushions MikeCM Problem Solving | Owners Helping Owners 16 04-19-2009 02:54 PM
My '82 Burro needs floor fixed or replaced, I need advise MikeCM Modifications, Alterations and Updates 5 03-11-2009 04:28 PM
Spring Fever, Spring Cleaning BOBSMITH General Chat 0 02-20-2009 06:10 PM
Help! Need some advise Adrian W General Chat 1 02-27-2007 07:16 AM
