Concerned about new axle - Fiberglass RV
Old 04-27-2014, 02:55 PM   #1
Trailer: 1975 Boler
I finally got a new axle for my 75 Boler 13'. It took 5 weeks for the mechanic to finish it up. I did research on this site for my Boler when I thought I could tackle this. In the end I didn't feel confident in my welding abilities. So I paid someone else to do the whole thing for me. I told mechanic that I wanted a #9 Torflex axle 2200 with brakes and 10 degree down starting axle. Well I got my axle and this is what was ordered/installed: Capacity 1400 lbs
I really wish he would of consulted me about the change. I never heard anything about changing the axle weight rating.
Am I wrong about being upset? Did he do me a favor and order the right axle? Was I wrong about the 2200 lbs? My Boler paper still inside the cabinet says 900 lbs GVW but we all know this is not accurate. Plus with gear I may be close to the limit of the axle which I do not like at all. I'm concerned because the original axle was rated for 1200 lbs. My Fiberglass Rally in Moab in May is in jeopardy. Need advice. What would you do in this situation? I will tomorrow get a real weight of my trailer without my gear in it.
aznative is offline   Reply With Quote
Old 04-27-2014, 03:01 PM   #2
Roy in TO's Avatar
Sorry, can't read the stamped information beyond "EXCLUDING", what does it say?
My Dexter came with a paper sticker and more information.
Old 04-27-2014, 03:08 PM   #3
Trailer: 1975 Boler
CAP 1400 lbs. All the stickers also say max cap 1400 lbs
Old 04-27-2014, 03:52 PM   #4
David B.'s Avatar
You told him what you wanted him to do. He broke that contract without talking to you 1st. You are on the right track weighing your trailer empty, but you should also weigh it full of your gear & water as if camping for a week, to see if he actually did you a favor or not. Let us know the outcome.
Dave & Paula
Old 04-27-2014, 04:45 PM   #5
Roy in TO's Avatar
OK on a different computer screen I can see EXLUDING RIMS WHEELS in the picture, is there anything beyond that?
You are right in being upset about specifying 2200 lbs and getting 1400. Weigh your trailer and get a printout. Then weigh the spare (rim & wheel) add twice that to the 1400 and you should get your max weight. Then go back to the mechanic.
You should be OK for your May trip, considering the original was 1200. But the rating specs may have changed over the decades.
You can also print off the chart in this post:
http://www.fiberglassrv.com/forums/f...rld-43010.html
Keep in mind that the axle weight (capacity required) is not the trailer weight.
Old 04-27-2014, 05:02 PM   #6
Trailer: 1975 Boler
That's exactly what it says. Excluding rims wheels.
I don't understand exactly what you mean by "axle weight (capacity required) is not the trailer weight." What does this mean?
I see you have a 1972 Boler American what kind of axle do you have on it?
Old 04-27-2014, 05:29 PM   #7
Roy in TO's Avatar
Some of the weight of your trailer is on the axle, some on the tongue. From the looks of it your axle says how much weight it is designed to handle on the axle minus the weight of rims and wheels.
So if you drive your trailer onto the scale and weigh from only the trailer wheels while it is on the scale, and the tow vehicle it hitched to off the scale, you will get your axle weight. Some scales are split, so you can get your tow vehicle on one and the trailers axle weight on the other.
You will notice in the chart I referred to earlier, it shows the weights of the trailer on both the axle and the tongue. The total weight is the two added together.
The scale guys will help you figure it out if you ask.
I put a Torflex #9 rated at 2200 Lbs. I did a little re-engineering to reposition the orientation to a trailing arm configuration because I was adding electric brakes. My choice, some don't feel it necessary.
Link to my axle swap: http://www.fiberglassrv.com/forums/f...arm-37248.html
(Note to Moderators, Many of the cross referenced links I posted years ago are now broken)
Old 04-27-2014, 05:30 PM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
That axle is stamped "model 09R"...dunno what that means exactly, but it seems to me that since Dexter only makes ONE torsion axle for capacities from 1,000 to 2200 pounds- the #9- that has to be what you've got here. This assuming it IS a Dexter...
As to the meaning of that "1400 pounds"- have you asked the mechanic about it? Here's what I think may have happened:
Since all such axles are essentially "custom" jobs, it may be that this one was "derated" at the factory to something more in keeping with the original stated GVW of the trailer. This is a common practice among trailer axle suppliers- no change including a new axle can legally "change" a weight rating, so they'll often stamp the trailermaker's spec on a replacement axle.
The so-called "derating" involves no physical changes/downgrades to the axle itself.
Old 04-27-2014, 05:35 PM   #9
Roy in TO's Avatar
Unless Dexter has changed, they did not use the method pictured of indicating specs. I'm thinking it's another manufacturer.
Old 04-27-2014, 06:00 PM   #10
Trailer: Class A Motorhome
The weight rating is that of the axle, not of the trailer itself. I really doubt if an axle maker gives a rats patootie what it's being used on when rating the axle, especially one for an almost 40 y.o. trailer.
BTW: The wheels and tires are called "Unsprung Weight component" and are always excluded from the weight rating of an axle. But it's usually so little that it usually isn't even mentioned. If one is that close to the maximum rating they are to close.....
If you had a contract for a 2000 lb axle you mechanic has some questions to answer, maybe in small claims court.
Old 04-27-2014, 06:35 PM   #11
Again assuming the O.P's new axle is a Dexter, which so far he seems to believe to be true:
Dexter makes ONE torsion axle in this weight range- the #9. It's good for a range of 1,000 to 2,200 pounds. The next size "smaller" has a weight limit of 1100 pounds, as seen at this link. Clearly, this axle can't be the one we're looking at in the pic.
I continue to believe that this is simply a derating of a Dexter #9, as I said before a very common practice in the trailer axle world.
Old 04-27-2014, 07:01 PM   #12
Trailer: 1975 Boler
Maybe someone who has ordered from dexter and has received the torflex #9 2200 lbs axle can shed some light on the stamp portion. Here is another sticker left on the axle.
Old 04-27-2014, 10:54 PM   #13
I see by the pic that yours is definitely a Dexter axle.
If not satisfied with explanations given by the mechanic that installed the axle, my recommendation is that you contact Dexter directly with the serial number of the axle along with any questions you may have about it. Every replacement axle they put out is essentially a "custom job", and their internal registration will have all the details related to your particular axle.
Old 04-28-2014, 12:02 AM   #14
Roy in TO's Avatar
I agree, Dexter has a great customer service department. From the serial # they should be able to provide you with all the specs.
Somebody somewhere should be able to explain what happened. Were the wrong specs written down somewhere? Was the wrong axle delivered? Was the wrong axle installed?
In the meantime you can practice quoting Ricky Ricardo ... "you got some 'splainin' to do".
Old 04-30-2014, 04:36 PM   #15
Trailer: 1975 Boler
So My mechanic ordered the correct axle and Dexter verified the error is on their end. It took them a little over a week to build the first one. This one will only take 2 days to build and 5 days total to arrive in AZ. They are just sending the correct axle and the mechanic here has to deinstall/reinstall hubs and brakes. Then send underrated axle back to Dexter. So we should be good to go for Moab. Thanks everyone for your input.
Old 04-30-2014, 05:46 PM   #16
Trailer: Burro
Good work! Wish you guy would have stopped before the install and questioned the part before install. Hope he isn't looking to you for additional R/R items to be paid.
NEWFISHER is offline   Reply With Quote
Old 04-30-2014, 07:52 PM   #17
Roy in TO's Avatar
This is a prime example of paying the extra few dollars to get the bolt on brackets with a new axle if your trailer does not have them already. R&R the tires, 4 bolts and 4 wire connections and the job would be done.
Just wondering if you ordered the initial axle with brakes? If so, Dexter should be sending you the replacement axle with brakes pre installed on the hubs.
Old 05-01-2014, 08:53 AM   #18
Trailer: 1984 UHaul CT13
Gina, I'm glad the axle issue is going to be taken care of. Happy you can still make Moab.
keekers is offline   Reply With Quote
Old 05-01-2014, 10:57 AM   #19
Trailer: 2010 Scamp 16
Posted too late. Glad it was addressed.
axle
Looking but concerned abt ventilation Kelljk Hi, I am.... 12 07-25-2013 07:19 PM
17 Ft Casita tongue weight.....should I be concerned??? Karalyn Towing, Hitching, Axles and Running Gear 20 02-20-2012 03:57 PM
Concerned about wood and carpet in Scamp wet bath. Karalyn Care and Feeding of Molded Fiberglass Trailers 9 10-26-2010 06:08 PM
concerned about scamp 13' axle Rarebird Towing, Hitching, Axles and Running Gear 1 05-04-2008 02:00 PM
concerned about scamp 13' axle marjie s. Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
