correct tire size for ECO - Fiberglass RV
Old 10-11-2015, 12:44 PM   #1
Trailer: Eco
What size tire should I put on my ECO?
jabo is offline   Reply With Quote
Old 10-11-2015, 02:09 PM   #2
An ECO13 most likely came with the equivalent of modern 155/80-13s.
175/80R13 is the most ubiquitous size now extant, which would work just fine for your application.
Old 10-11-2015, 05:56 PM   #3
Ian G.'s Avatar
Floyd is right on
The ECO was a franchised version of the Boler so it would have identical specification. The modern replacement for tires would be 175/80R13 ST
Old 10-13-2015, 02:46 PM   #4
Trailer: Eco
Tires
Thanks a bunch! I have ordered 3 new tires with white steel spoke rims. Missing the spare wheel and tire, I thought this was the way to go.
Old 10-31-2015, 04:19 PM   #5
Trailer: Casita & trillium
What is the trailer hitch ball size for a 13' eco
Ron1943 is offline   Reply With Quote
Old 10-31-2015, 05:22 PM   #6
Ian G.'s Avatar
I am not 100% sure but many of them use 1 7/8"
Old 10-31-2015, 05:47 PM   #7
Roy in TO's Avatar
Sorry for the delay, tire size is hard to say, I discuss it in this thread:
http://www.fiberglassrv.com/forums/f...tml#post168318
Originally Posted by Ian G. View Post
Floyd is right on
Ian, please get your history straight. The ECO evolved from the boler American which was franchised.
The ECO was a stand alone trailer that appears to have used some of the same molds. It was made by Century Manufacturing that was originally contracted to make the boler Americans for Elanor International aka boler American that only had an office in Wichita KS.
But I can't say they were the same molds for sure because both the Love Bug and Scamp modified the boler American molds. For the history buffs, the boler American was unique in that there was a depression in the street side wheel well to accommodate the gravity furnace. I don't believe that was carried over to any of it's successors.
Old 10-31-2015, 08:05 PM   #8
Ian G.'s Avatar
Thanks for the clarification Roy.
Old 11-09-2015, 07:47 PM   #9
Ian thanks for the quick response concerning the hitch ball size. I was preparing to pick up a 1973 ECO over 100 miles away. You were correct on the 1 7/8. I had to put new tires (175 80r 13) on it to get it home. My question now is the clearance on the inside of the street side tire. Because on the indention in the wheel well to accommodate the furnace there is less than 1/4"! Is this normal? It appears to have the original axel in it and it is shot and I am going to replace it. Do I need to address this clearance issue when I order a new axel? The tire rides on the old axle within 2" of the top of the wheel well. The new axle will drop the tire down and that will give more clearance on the inside but it will still be very close to the tire. What are your thoughts?
Old 11-14-2015, 10:56 PM   #10
Roy in TO's Avatar
Ron,
It is interesting to learn that the ECO carried over the indentation in the street side wheel well from it predecessor the boler American. I've sketched out a cross section of my trailer in this thread: http://www.fiberglassrv.com/forums/f...tml#post168312
I'm thinking the 1/4" sidewall clearance near the furnace might be normal for you and I. It might not be for those that do not have the indentation. Here is a picture of the furnace and indentation in mine.
Name:	Notched Wheel Well.jpg
You will notice the frame is offset ~1" towards the curbside. If you order your axle with the bolt on bracket kit, you will find the brackets are wider than your frame. When welding the axle on, you can then shift the axle about 1/2" to the street side which will give you a bit more clearance on that wheel well. You are essentially trying to center the hub faces under the body.
If you are going to try that, double check all your measurements before ordering an axle. And don't go by mine as I changed the axle direction.
I tried to order an axle with the brackets offset to center the wheels under the body but Dexter would not go for it, they said they would have to retool the production line.
Can you please send me a PM with the depth of your kitchen counter? I've got an idea I want to confirm.
Old 04-12-2018, 10:37 PM   #11
Johnny M's Avatar
Deep South
Roy my 1971 Boler has the recessed wheel well for the gravity furnace. I believe it was manufactured by Evelands when they were contracted to make the Boler American before they began producing Scamps. The tail lights look like a Boler or an Eco. Does anyone know if the Canadian made Bolers had the recessed wheel well street side?
1971 Boler 1300 - "Suite 13"
1987 Play-Mor II - "The Beach House"
Old 04-12-2018, 10:39 PM   #12
Johnny M's Avatar
Deep South
Mine also had the original Ingersol Rub R Ride torsion axle when I got it (since been replaced with a Dexter #9)
Old 05-21-2018, 11:30 PM   #13
Roy in TO's Avatar
Originally Posted by Johnny M View Post
Roy my 1971 Boler has the recessed wheel well for the gravity furnace. ... Does anyone know if the Canadian made Bolers had the recessed wheel well street side?
I might be wrong Johnny, I think the different wheel well under the sink was an American thing.
I would question your boler being a 1971. It may have been made in late 1971 for the 1972 model. Some went by manufactured date, some by model year, some by date sold. You might find this thread interesting:
http://www.fiberglassrv.com/forums/f...s-26760-3.html
eco
Source of correct size decals for older Scamp Mike L. Care and Feeding of Molded Fiberglass Trailers 0 02-08-2011 06:28 PM
Correct battery information for monitor DannyH Problem Solving | Owners Helping Owners 6 01-31-2011 01:02 PM
Correct size tires/wheels for 19 ft. Bigfoot pascualito Towing, Hitching, Axles and Running Gear 0 04-20-2010 10:52 AM
correct bulbs Flygal Problem Solving | Owners Helping Owners 10 04-18-2009 04:20 PM
