cost to have 7 wire rv plug installed in tow vehicle? - Fiberglass RV
Old 08-10-2009, 08:42 PM   #1
Hi,
What do most rv places or mechanics charge to install a 7 wire rv plug in a tow vehicle (in my case a Suzuki Vitara/Chevy Tracker) without factory wiring.
What is reasonable charge for this?
Is it a full day job?
I have the 4 wire utility trailer plug installed, thus need the 4 wire to 7 wire plug converter, a brake controller, and a trailer wiring harness, assume blue brake wire must be run from back of vehicle to brake controler, and battery wire run from back of vehicle to battery.
Thanks for your guestimates what this should cost
Brian1 is offline   Reply With Quote
Old 08-10-2009, 09:29 PM   #2
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester/ 2012 Toyota Highlander
Burnaby Hitch in Vancouver quoted me a price of $350 to add a controller (Prodigy) and 7-way connection to my 2003 Forester which is not prewired. This includes parts and labour. This company was recommended to me by a Scamp owner, and I have been impressed with this company. You may also want to consider adding a transmission oil cooler which Burnaby Hitch can also do, for about $200.
Brian
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 08-10-2009, 10:01 PM   #3
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
Another option, depending on how handy you are is to do it yourself.
this link will give you some guidance as to what is involved.
http://www.flickr.com/photos/76boler...7604792637096/
If your vehicle already has a 4 way plug it is simply a matter of mounting a 7-way/4-way adapter plug on to the back of your vehicle and plugging the 4-way in to it.
http://www.etrailer.com/pc-A~30717.htm
If your vehicle does not have a 4-way plug then it may be a simple matter of purchasing the 4-way vehicle specific wire harness and plugging it into your existing vehicle wire harness.
http://www.etrailer.com/c-T1.htm
The brake controller is mounted on your dash.
http://www.etrailer.com/pc-BC~90195.htm
This is a good controller and a good price. They usually have a $5 shipping special to Canada.
In my vehicle I had to drill a hole through my firewall to run the wires. Your vehicle may have an access hole.
The blue wire on the brake controller will connect with a heavy 10 gauge wire and then be run through the firewall to the rear of the vehicle and inserted in the proper location in the 7-way plug.
http://www.etrailer.com/faq-wiring.aspx
http://www.etrailer.com/pc-trw~10-1-1.htm
The black and white wires will run from the brake controller via large 10 gauge wire, through your firewall, directly to your battery positive and negative posts, using the appropriate circuit breaker just before battery positive. (20 amps usually for a trailer with two brakes}
http://www.etrailer.com/p-9506P.htm
The red wire from the brake controller will be "tapped" in to the cold side of your brake switch which should be located just above your brake pedal.
http://electrical.hardwarestore.com/14-46-...ces-601407.aspx
A quick email to Tekonsha, letting them know the year and make of your vehicle, will provide you with the colour of the wire you need to tap. Here is their contact info.
Danny Dunn
Technical Service Coordinator
Cequent Performance Products, Electrical Division
101 Spires Parkway
Tekonsha, MI. 49092
(888) 785-5832
dedunn[at]cequentgroup.com
kevin61 is offline   Reply With Quote
Old 08-18-2009, 01:27 PM   #4
Dan Vang's Avatar
Trailer: 2005 13 ft Scamp
I have a four pin factory install on my TV. I bought from walmart a plug that does both four and seven pin so I can also tow my boat and had my Toyota dealership install it. Cost was about $180 for them to install the plug.
Dan Vang is offline   Reply With Quote
Cost of axle GenM Care and Feeding of Molded Fiberglass Trailers 118 05-18-2011 11:02 PM
how much is a bathroom cost? Alexandra B General Chat 0 03-26-2009 10:51 AM
What will this cost me? Karen T Problem Solving | Owners Helping Owners 21 02-04-2009 11:52 PM
Cost to reupholster Dan Simon Modifications, Alterations and Updates 26 03-30-2006 06:33 PM
Replacement window cost Rob S. Problem Solving | Owners Helping Owners 7 12-06-2005 02:11 PM
