cushioned tow bar - Fiberglass RV
Old 06-05-2011, 11:26 AM   #1
cpaharley2008's Avatar
cushioned tow bar
I purchased one of these to eliminate the noise associated with the receiver clanging inside the hitch while towing. I also hope that the cushion will have similar effect as shocks and my trailer will not be as frazzled after a tow.
I have used it once and it seems to work very well.
http://www.etrailer.com/Ball-Mounts/...ll/CAB-UM.html
Old 06-05-2011, 01:39 PM   #2
Mike and Sarah K's Avatar
Trailer: 1979 Trillium 13 ft
New Brunswick
Convert-A-Ball Dual-Cushioned, Adjustable Ball Mount - 7" Rise to 9" Drop - 5,000 lbs Convert-A-Ball Ball Mounts CAB-UM
They do work very well, for those that are alittle more frugal, I use a cedar shim about 1.5 inch wide and some electric tape to hold it in place. htis may not be the most ideal way but certainly is cheap.
Mike and Sarah K is offline   Reply With Quote
Old 06-05-2011, 01:52 PM   #3
South Carolina
That's what I'll be doing the next time I pull ours.It tows really smooth and quiet as long as your on the road,but when going slow through parking lots or campgrounds it clangs around alot.
Brian Bran is offline   Reply With Quote
Old 06-05-2011, 03:19 PM   #4
This is what I use for the anti-rattle
Anti-Rattle Device and Lock for 2" Trailer Hitches Tow Ready Locks,Hitch Accessories 63232
but this set up is supposed to cushion the trailer somewhat also by putting rubber cushion for vertical and horizontal movement. I guess the ideal setup would have both.
tow bar and base plates rmac Classified Archives 1 08-26-2008 04:33 AM
FOR SALE Tow bar and base plates FOR SALE rmac Classified Archives 0 07-31-2008 05:25 AM
FOR SALE Roadmaster tow bar and base plates rmac Classified Archives 0 07-29-2008 01:54 PM
Round Bar vs. Trunion Mount Flat Bar WDH ? bobinyelm Problem Solving | Owners Helping Owners 11 07-06-2007 08:43 PM
Cushioned trailer ball mounts??? Legacy Posts Towing, Hitching, Axles and Running Gear 14 02-09-2003 12:34 PM
