Dead tounge lift. - Fiberglass RV
Old 09-16-2013, 07:46 PM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Dead tounge lift.
I had just dropped the hitch on the ball and hit the UP switch to pull up the base. Dead. Very, very, dead. So I took it all apart and pulled it off the tongue. Tomorrow I replace it with a manual crank. *sigh*
fusedlight is offline   Reply With Quote
Old 09-18-2013, 08:27 AM   #2
fusedlight's Avatar
But wait... there's more. The trailer place found that are brakes are falling apart. Oh well. Better to find out now than half way down to New Orleans in a couple of weeks, eh? Waiting to find out what other wonderful things are discovered.
Old 09-18-2013, 09:41 AM   #3
It may be to late, but did you verify that there was 12VDC at the motor wire?????
Old 09-18-2013, 09:48 AM   #4
fusedlight's Avatar
Yup. I did "due diligence" before I yanked the beast. I checked voltages at all appropriate points, and then bypassed the switch and did a direct connection. On further thought, even if the motor WAS good having a mission-critical part rely on something that might fail in the middle of nowhere (ie. battery) is not a good idea. I suppose that if I was somewhere and it all had crapped out I could have done just what I did...pull the unit. I've now eliminated that source of possible error.
I guess what I've learned after a year and a couple of months is what to worry about, and what not to worry about.
Old 09-18-2013, 11:09 AM   #5
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I have a hand crank top winder on our Scamp. I removed the crank handle and welded a 3/4" nut to the top. I use my electric drill to raise/lower the tongue, and if the drill should fail, I can use a ratchet or a hand crank to manually do the job.
Old 09-18-2013, 12:19 PM   #6
fusedlight's Avatar
I was thinking of doing something similar.
Old 09-18-2013, 04:23 PM   #7
Brian B-P's Avatar
I thought that even in unmodified form, all of these power jacks had a hand crank just for this purpose... no need to pull the unit for any kind of power or motor failure.
Even the cheapest power A-frame jack at eTrailer (MaxxTow Electric Trailer Jack - A-Frame - 18" Lift - 3,500 lbs MaxxTow Trailer Jack MT70147) lists
Manual override handle included in case of power failure
Old 09-18-2013, 05:30 PM   #8
fusedlight's Avatar
Nope. No auxiliary crank. Bummer.
Old 09-18-2013, 06:07 PM   #9
Brian B-P's Avatar
Well, at least you do have the option of replacing it with a power jack which does have a manual override, so you can have both power and reliability... if the power feature is of value to you.
Old 09-18-2013, 06:45 PM   #10
Gina D.'s Avatar
West Coast USA
My trailer came with a power jack..that works! I never thought I would go out of my way to install one before..but if this one shuffles off this mortal coil, I most certainly will replace it. I never want to Crank Crank Crank again..
Mine is ancient, but it has an emergency hand crank on it. I have the manufacturers tool, but it looks like a good socket and bar would work just as well.
Old 09-19-2013, 09:46 AM   #11
fusedlight's Avatar
Just used the crank. No Big Deal. Hey, my sweetie says I need to exercise!
Axle winterizing... To lift or not to lift??? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 22 12-12-2015 05:47 PM
High Lift Axle Daniel W Care and Feeding of Molded Fiberglass Trailers 6 03-24-2010 06:46 AM
Front lift wheel on a 17 Herb P Problem Solving | Owners Helping Owners 9 05-12-2007 09:42 PM
When do drooping axles need a lift? Isaac M Towing, Hitching, Axles and Running Gear 7 05-09-2007 10:59 AM
Casita Hi Lift axle Legacy Posts General Chat 6 06-08-2003 04:06 PM
