Defining Dexter TorFlex Axle Brackets - Fiberglass RV
Old 08-01-2008, 09:42 PM   #1
rudock1's Avatar
Trailer: Perris Pacer 13 ft 1985 / Mazda B3000 Dual Sport 2002
Hi Axle Guys,
I have a question about TorFlex brackets. To get oriented, please see this Dexter PDF: http://i.b5z.net/i/u/1080235/f/Axle_Measurement.pdf
Dexter offers a few bracket options:
Side Mount Hanger
Low or High Profile
Standard or Reverse Orientation (I've seen this called Inboard Outboard elsewhere)
Now my problematic Perris Pacer has something a little different. While it is of the Reverse Orientation, it has a completely different Offset in the bracket. See how the arm extends out past the right edge? Does anybody know how this is called?
Compare back to the PDF above to see the axle offset is "leftward" normally. I can imagine the "rightward" offset is possible by how you assemble the pieces, but do they do that?
thx,
Billy
rudock1 is offline   Reply With Quote
Old 08-01-2008, 11:14 PM   #2
Roy in TO's Avatar
I don't know what it is called, but it appears as if they have installed the brackets backwards from standard when the axle was fabricated. Or the arms were installed backwards. Or someone has cut the brackets short.
what you have is possible to do using a Flexride axle because they use a cartridge system, all you would have to do is switch the L for R cartridges then install the axle backwards.
axle
Failure of Axle Brackets on Scamp 5W Trailers Pete Dumbleton Towing, Hitching, Axles and Running Gear 43 04-03-2017 06:14 PM
Dexter Axle Parts D Tharp Classified Archives 3 04-14-2011 12:00 AM
Dexter axle question Kevin K Towing, Hitching, Axles and Running Gear 17 12-22-2007 10:30 PM
Dexter axle Don G Care and Feeding of Molded Fiberglass Trailers 19 12-13-2005 08:17 AM
Replacing Torflex Axle on 13 ft Scamp General Chat 0 12-31-1969 07:00 PM
