Old 08-06-2012, 07:02 AM   #1
Dexter 9 vs Dexter 10
I have been reading some of the old discussions about axles for 13' trailers. It appears that many opt for either a Dexter #9 or a Dexter #10 Torflex axle.
Which is better?
What are the consequences of riding a #10 axle (rated for 2300 to 3500 lbs) if you trailer weighs in under 2300 lbs most of the time? I'm anticipating a stiffer ride (which many not be a good thing)?
If the brakes are rated for 2300lbs+ are you going to get more aggressive braking then you need?
Does anyone have any additional wisdom to offer?
Derek
glamourpets is offline   Reply With Quote
Old 08-06-2012, 07:25 AM   #2
Roy in TO's Avatar
Unless you have severly altered a 13' boler, the Dexter #9 is sufficient. I spoke with a Dexter engineer when I was doing mine. He suggested a # 9 a full rubbering (maximum weight) would be best. The ride is not harsh, the best analogy I can give is that a pick up rides a lot smoother with a part load in it, empty or at full load you know and feel it. There may be concerns over the spacing available in the wheel well on the curbside with a # 10.
OTOH I used a #10 on my Trillium 4500.
As to aggressive braking, that should be controlled with the proper setup and adjustment with your brake controller. I have to adjust mine between the two trailers.
Old 08-09-2012, 10:37 PM   #3
Robert Johans's Avatar
Trailer: 1974 Boler
Dexter will also build a "9H" that features 10" brake drums. I was told by the Dexter folks that my preferred 15" wheel/tire set-up could put too much load on the 7" brakes of the standard "9".
Old 08-10-2012, 10:17 AM   #4
I would list all the specifications of the camper in an email and ask Dexter for a recommendation.
Old 08-10-2012, 08:22 PM   #5
Whatever axle you decide is best for your application depends on several items: weight of the trailer (loaded for camping... with or without full water tanks (including hotwater heater, full gray and black water tanks and full freshwater tanks) and size of wheels/tires.) Every trailer (owner) that I've met tows something "different." There really is no "standard" or "better." Just don't fall into the trap, of "close enough." You'd be surprise how much your extra stuff weights.
"Honey, let's take our bicycles (or canoes this trip).
It's all about your needs and the needs of your trailer/tow.
Be safe, you're sharing the road with others.
Double Yolk
1988 16' Scamp Deluxe
Old 08-11-2012, 03:46 PM   #6
Trailer: Fiber Stream
Originally Posted by Roy in TO View Post
Unless you have severely altered a 13' boler, the Dexter #9 is sufficient.
I'm considering converting my Compact Jr. from leaf springs to a Dexter torsion axle. The first retailer I checked with says the Dexter #10 is the smallest he can order.
Old 08-11-2012, 04:12 PM   #7
Roy in TO's Avatar
Frederick, have you been hacked?
Old 08-11-2012, 10:34 PM   #8
Question
why do you say that?
Old 08-14-2012, 10:40 PM   #9
Trailer: 77 Scamp 13
In discussion with owner of local trailer shop of the options for Dexter axle while going through the Dexter specification book I recall there was a difference in wheel size/bolt pattern available. Above a certain axle # I could not get a configuration to match my existing 4 bolt 13 inch rim.
Was not ready to make that investment and just pricing out options so I don't have the details but do recall above a certain size I was going to have to replace rims and tires.
Trailer pro also advised to go with a certain "common" size brake to make replacement and repair parts easier to come by. Don't recall the size, but the smaller size he said to aviod was typically used only as stock on lite boat or snow mobile trailers (really small tires) and not going to be in stock at most trailer repair places. Might be worth checking around to see what sizes of pads and brake parts are in stock in your area.
Dexter Airflex!! floyd Towing, Hitching, Axles and Running Gear 6 08-30-2011 06:49 PM
Installing new Dexter brakes Carol H Care and Feeding of Molded Fiberglass Trailers 6 04-18-2011 01:59 PM
Dexter Axle Parts D Tharp Parts: Buy | Sell | Trade 3 04-14-2011 12:00 AM
Dexter axle question Kevin K Towing, Hitching, Axles and Running Gear 17 12-22-2007 10:30 PM
Dexter axle Don G Care and Feeding of Molded Fiberglass Trailers 19 12-13-2005 08:17 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
