Dexter McOops. - Page 2 - Fiberglass RV
Old 01-02-2013, 09:18 AM   #15
Trailer: 2014 Escape 21, Lil Joe
Derek
Did you order the bolt on bracket option for the axle? If you use the bolt on brackets they should more than make up for the 1/4" difference when the bracket is welded to the frame.
Eddie
Eddie Longest is online now   Reply With Quote
Old 01-02-2013, 11:00 AM   #16
Brian B-P's Avatar
Originally Posted by glamourpets View Post
My frame has a flat metal plate welded where the axle goes. The plate was equal in size to the bottom side of the old axle. From what I can see in the pictures in the other thread, the axle bracket overhangs the side of the frame. The overhang seems to be what makes these axle brackets fail. By matching these two metal pieces up against each other (like in my situation), has the problem been eliminated?
It has at least been reduced, although a simple flat plate is not a very effective structure for this purpose.
I also notice that this seems to be a problem on the 16' to 19' trailers. These rigs are heavier, and therefore put more forces against the axle brackets. Perhaps this is less a concern on a 13' trailer?
It was a problem on those trailers because those are the ones that Scamp messed up... but I agree that it is at least less of a concern with a lighter trailer, particularly if the brackets are all the same thicknesses and strength for every axle capacity range.
Eddie
How? The bolt-on brackets (also known as side hangers) are in addition to the welded-on brackets visible in the photos, so they would only shim the axle down a bit, which would not keep the axle's brackets from interfering with the dropped frame section between them.
The additional hangers would serve as additional reinforcement to reduce the problem with the overhanging brackets (like a better version of the plate described above because the wrap around the side of the axle brackets), but at the same time they would presumably prevent a change to brackets flipped around the right way, because the bolts need to be toward the outside to clear the dropped frame section.
Old 01-02-2013, 11:06 AM   #17
deryk's Avatar
New Jersey
I went with a different trailer...
Old 01-02-2013, 08:58 PM   #18
Good News!
I contacted the dealer. They reviewed their paperwork, and see that their measurements are indeed out by 1/4". They have agreed to replace the axle at their expense.
Looking at the error axle, and I am questioning their axle angle. Its possible they have this correct. How would they know if old the axle is sagging badly? If all they have is an old axle, what do they base their measurement on? What is the correct measurement?
22.5 Up
10 Up
0 Degree
10 Down
22.5 Down
45 Down
Derek
glamourpets is offline   Reply With Quote
Old 01-02-2013, 09:02 PM   #19
It sounds like this is really a frame problem, not an axle problem. The problem is that the frame needs to beefed up where the axle is attached. Or is there something the axle manufacturer should be doing here to eliminate the problem?
Derek
Eddie
The old axle was bolt on. When the axle was ordered, they put a bracket on the new axle that was supposed to line up with the old one. The plan was to bolt the new axle onto the old brackets. The new axle bracket was U shaped, and the space between the two brackets was smaller then the space between the two bars on the frame.
Derek
Old 01-02-2013, 09:27 PM   #20
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
If by "sagging" they mean it's bent:
Determining axle "sag" might be a matter of measurement- one would think they'd be able to tell if it's bent. I certainly can't tell you what correct measurements might be...maybe someone else will chime in.
I'm beginning to think that you'd have been better off hauling the whole trailer down there so they could have taken measurement etc while the axle was still on the trailer. That might have given them a more complete picture before ordering...
Hope this next one works!
Francesca
Old 01-02-2013, 09:34 PM   #21
To clarify, my trailer looked like a "low rider" because the trailer was sitting too low to the ground. Isn't this sag? It also bounced like crazy when towed. This is why the axle is being replaced.
Derek
Old 01-02-2013, 10:24 PM   #22
I thought you said that the axle guys had made the "bent axle" assessment, based on their evaluation of the axle.
I can't opine as to whether your trailer was bad-axle low since I'm unfamiliar with both your trailer and what an off-the-rack '73 Boler looked like, ground clearance-wise...
Francesca
Old 01-03-2013, 01:45 AM   #23
Brian B-P's Avatar
Someone who is familiar with Dexter Torflex axles can see the "start angle" in a few seconds by just looking at the pivot end of the arm - you can see the position of the arm relative to the square bar which goes through it. The Dexter Axle application guide shows this in drawings.
If the arm no longer sits near the start angle when not under load, the rubber is shot.
If the change from low-profile to high-profile brackets was not requested, then that's another error in the new axle. If more ground clearance is desired, then the higher brackets would be good.
Dexter 9 vs Dexter 10 glamourpets Towing, Hitching, Axles and Running Gear 8 08-14-2012 10:40 PM
Dexter Airflex!! floyd Towing, Hitching, Axles and Running Gear 6 08-30-2011 06:49 PM
Installing new Dexter brakes Carol H Care and Feeding of Molded Fiberglass Trailers 6 04-18-2011 01:59 PM
Dexter axle Don G Care and Feeding of Molded Fiberglass Trailers 19 12-13-2005 09:17 AM
Learn more about Dexter axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 11-11-2002 10:30 AM
