Dexter self adjusting electric brakes on 17' Escape - Fiberglass RV
Old 06-24-2013, 06:29 PM   #1
Trailer: Escape 17' Plan A
Hello, I am buying a 17' Escape Plan A trailer...does anyone have experience with Dexter self-adjusting electric brakes on this, or any other rv trailer? Any pros or cons....? Am also getting easy lub bearing set up...any pros or cons on this? Any help would be appreciated. Thanks, Ian
Ian Hall is offline   Reply With Quote
Old 06-24-2013, 06:39 PM   #2
Brian B-P's Avatar
No experience, but I don't know why I would want brakes that need manual slack adjustment if I could have brakes that do it for me... like the brakes in every car.
Just a note if anyone is confused: this is a feature to adjust slack only; it has nothing to do with the need to adjust the brake controller.
I don't have a boat trailer, so I have no use for E-Z Lube. I would't object to its presence, but wouldn't pay any premium for it. I suggest a search of this forum for many previous discussions of this somewhat controversial feature.
Old 06-24-2013, 07:14 PM   #3
Ian, are you getting the true Dexter E-Z lubes or just sticking on the Bearing Buddies as Brian alluded to in his Boat Trailer statement.
E-Z lubes are NOT Bearing Buddies. I have the E-Z lube system on the axle on my Scamp and like it very much. However, I also changed the axle to get it.
Old 06-24-2013, 07:25 PM   #4
cpaharley2008's Avatar
I know Escape now offers EZ Lube as an $75 option, it is an entirely different axle, not sure if the self adjusting brakes is an option.
Jim
Never in doubt, often wrong
Old 06-24-2013, 07:35 PM   #5
Easy Lub
Yes I am getting the axle with easy lub, not bearing buddies. Thanks, Ian
Old 06-24-2013, 08:04 PM   #6
good for you Ian. Like all things, it still requires maintenance, but not as much and not as "greasy" as often without...
Old 06-24-2013, 10:40 PM   #7
Brian B-P's Avatar
Originally Posted by Donna D. View Post
... Bearing Buddies as Brian alluded to in his Boat Trailer statement.
I did not refer to Bearing Buddies, and intended no allusion to them.
True; I understand that. My comment was specifically about Dexter's E-Z Lube - my apologies for mis-punctuating it the first time - although it would apply equally well to similar grease-injection schemes from other axle manufacturers.
Old 06-25-2013, 04:17 AM   #8
Ian,
Has Escape told you that self NV-R-Adjust brake axles are now available? I know airstream uses some on some models.
Jim
Old 06-25-2013, 02:06 PM   #9
Self adjusting brakes
Yes, Reese has said they can be ordered with the e-z lub axle... he wasn't too keen on them; said they were fairly new and there might be problems. But I'm inclined to get them unless others nix them enough. Ian
Old 06-25-2013, 03:28 PM   #10
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Ian,
What's the difference between "self adjust" and "Nev-R-Adjust"?
I ask because Dexter's promo vid for the latter on Youtube actually uses the words "never adjust self adjusting brakes again!".
Does that mean that "self-adjusting brakes" actually do need adjustments of some kind????
Francesca
Old 06-25-2013, 03:38 PM   #11
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I have Dexter Nev-R-Adjust brakes on the Burro. They are $37 in the box price per wheel for 10" from Eastern Marine. I think that's reasonable for an after-market brake carrier but pricing as an option package on a new trailer may make them appear a bit more dear, as would buying for a dual axle, as in the case of the larger Escapes. I have had no trouble with mine on two short (200+mi.) camping trips.
jack
Old 06-25-2013, 04:46 PM   #12
Brian B-P's Avatar
No, there's no difference, it's just poor scriptwriting. Nev-R-Adjust brakes adjust themselves, so you should never need to adjust them... just like cars with drum brakes.
Old 06-25-2013, 04:50 PM   #13
Don't you mean disc brakes, Brian? Drums brakes needed adjusting.
Jim
Old 06-25-2013, 04:55 PM   #14
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Cars with drum brakes are self adjusting - at least for about the last 40 years.
brakes, escape
Great Deal on 10" Dexter Electric Brakes Thomas G. Towing, Hitching, Axles and Running Gear 2 01-05-2012 10:02 AM
For Sale: Dexter 7" Hydraulic Brakes Spanke Parts: Buy | Sell | Trade 0 12-13-2011 09:45 AM
Installing new Dexter brakes Carol H Care and Feeding of Molded Fiberglass Trailers 6 04-18-2011 01:59 PM
Dexter 10X2.25 inch brakes. Perry J Care and Feeding of Molded Fiberglass Trailers 1 07-16-2010 08:19 AM
Electric brakes Greg Janke Towing, Hitching, Axles and Running Gear 11 03-31-2008 11:45 PM
