Diesel Exhaust Fluid - FYI - Fiberglass RV
Old 03-10-2012, 01:51 AM   #1
Roger C H's Avatar
Red face Diesel Exhaust Fluid - FYI
Something I never saw before. When we stopped at a truck stop near Lodi, CA is a station for trucks labeled 'Diesel Exhaust Fluid". Upon asking a trucker, he stated that it is a new EPA Reg that newer diesels use. I found this on the internet:
BlueDef Exhaust Fluid for Diesel Emission Reduction Requirements
What not all. Although I do admit to having seen trucks spewing out clouds of black exhaust gas...
Old 03-10-2012, 05:20 AM   #2
Trailer: 2014 Escape 21
Virginia
Another measure to move the big rigs to Natural Gas as the primary fuel I guess.
Eddie
Eddie Longest is online now   Reply With Quote
Old 03-10-2012, 06:29 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I think it is urea.
Old 03-10-2012, 06:39 AM   #4
A couple years before I retired from working on big trucks , the new ones came equipped with a catalytic converter type muffler. Like any new technology they could be a nightmare. If they started to plug up, the driver had to stop and put it into a regenerate mode, during which the engine would go to full RPM and inject fuel or air into the exhaust to clean out the muffler. Now can you imagine a driver who is on a tight schedule or getting paid by the mile, stopping and sitting for 30 minutes or so for his truck to go through this regen cycle, NO WAY. We had problems where it was put off so long that the truck wouldn't go into regen, and we had to send them to the dealer to get it done. There are machines you put the muffler in, to clean it out. Diesel fuel was refined to be low sulphur too. Now the new trucks have a separate small tank to hold this new fluid that somehow further reduces emmissions. I retired just before that system came out, so I never worked on it. Diesel engines are now all computer controlled, with electronic fuel injectors, and even the horsepower is controlled by the computer. OK when all works right, but when something goes wrong it's an electronic nightmare. You shouldn't see black exhaust from any of the new trucks. I don't miss that work at all!!! Bob Tom is correct, it is urea
Old 03-10-2012, 09:44 AM   #5
Greg H's Avatar
Trailer: 72 Boler American
Indiana
As an ex truck driver, hopefully the blue stuff is a long way off for light duty Diesels. The catalytic type filter is already here, it's called a particulate filter and the two of them on my '07 Dodge ram were $1,300.00 to replace.
Old 03-10-2012, 10:11 AM   #6
This is why my pickup is a '76
Old 03-10-2012, 10:38 AM   #7
Gina D.'s Avatar
West Coast USA
I just transported an 06 40ft motorhome from an auction that only had 3000 miles on it.
It would not go over 20 miles an hour because the DPF was so plugged it's fail safe kicked in and basically shut the system down to prevent it from kicking in the turbo and moving faster. (EPA~California thing)
I had a "Mechanic" come out and do a regeneration on the filter. The mechanics only tool was a laptop computer. It told everything about the engines lifetime use as well as performing the regeneration.
It showed that 87% of the engines life run time had been at idle. It never got hot enough for the system to burn itself off and the particulate just laid there..collecting and clogging. The regeneration process, fortunately, worked. It was basically a software program that ran the engine through some paces to burn it off. It took 40 mins and cost.. 600 bucks!
ouch.
Normally, this process happens when underway. Eventually, the filters will need to be replaced though.
Old 03-10-2012, 11:39 AM   #8
Trailer:
Only if you drive on highways. A lot of folk in Europe are getting caught out by these filters - for example, if a passenger car is driven entirely in cities, it may never work hard enough and long enough for the regeneration process to take place and then problems and big bills can arise.
It is almost like the old "Italian tune-up" - you take the car to a highway and drive at over 3000rpm for 20-30 minutes and that does it.
Old 03-10-2012, 12:41 PM   #9
SilverGhost's Avatar
Trailer: Egg Camper
Sorry, already in the trucks. The DPF were causing the flame out the exhaust on some models (Ford) before they changed the ECM software. We already have DEF bottles. And the DOC and DPF are NOT the same. Sometimes combined in the same housing for simplicity of packaging.
First a quick primmer - DPF is Diesel Particulate Filter and it's job is to collect particulate matter (soot, the black clouds). After the ECM senses back pressure has reached a preset level it starts the regeneration cycle. Or during a long enough highway drive the DPF will get hot enough to light off with no extra input. Depending on the vehicle this is usually diesel fuel injected during the exhaust stroke or an extra injector in the exhaust. A small amount of diesel is vaporized and when it hit the DPF it ignites the particulate matter and it burns off. The VWs and GMs both will turn on a warning lamp when you haven't driven highway enough - go drive it above 45 MPH for 20 minutes and the light should turn itself off. If you ignore you'll have to bring it in for a tech to try a regen. And if wait too long for that, then you have to replace the DPF.
The DEF (sometimes sold under brand name AdBlu) is urea and is injected into exhaust before SCR catalyst. It's job is to fix NOx emissions. I believe NOx is generally responsible for ozone formation at ground level and acid rain. Some small cars use a different style NOx trap catalyst that does the job without the pee. BUT they use more fuel and get less MPG.
Jason
SilverGhost is offline   Reply With Quote
Old 03-10-2012, 01:56 PM   #10
Most trucks have a "regen" warning light and a switch to start the regen process. The truck had to be parked, parking brake on, and it would run at full rpm for about half an hour. A laptop computer became a tool we couldn't live without, and it could give us all kinds of info, some of it the drivers didn't want us to know, like if the engine had been over-revved, panic stops, over the set speed. Amazing technology!!
Old 03-10-2012, 05:54 PM   #11
It lubricates the muffler bearings.
Old 03-10-2012, 06:09 PM   #12
Mike Magee's Avatar
Trailer: Li'l Hauley
And, I might add, it does so without getting wrapped around the exhaust camshaft, which is quite a feat!
How to prepare Tofu
Step 2: grill some meat
Old 03-11-2012, 05:40 AM   #13
Trailer:
Jason, thanks for a useful write-up.
And Darwin would clearly like this stuff, as recommended by Joseph Lucas, Prince of Darkness (for those who have ever had a Brit car with Lucas electrics):
Old 03-11-2012, 09:55 AM   #14
Andrew, I think you are attempting to play a joke on us because that clearly is a jar of prop wash.
Mahindra diesel pickup Craig D. Thompson Towing, Hitching, Axles and Running Gear 225 07-28-2015 03:02 PM
Subaru Forester Diesel? Bobbie Mayer General Chat 11 03-07-2009 06:23 PM
Automatic Transmission Fluid Temperatures Pete Dumbleton General Chat 1 03-04-2008 03:53 PM
Fluid, Battery Levels & Solar Charge Controller? peterh Electrical | Charging, Systems, Solar and Generators 9 04-27-2007 04:45 PM
