Disk brakes or drum for trailer. - Fiberglass RV
Old 03-15-2015, 09:13 AM   #1
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Can you identify me if there is advantage with one or the other one?
I possess Trillium 15 '.
Thank you,
and have a good day.
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 03-15-2015, 09:22 AM   #2
I didn't know that there was a choice for electric brakes on FGRV's. What do you know about disc brakes being available?
Old 03-15-2015, 09:27 AM   #3
Drum works on magnetism and friction. How does disk work?
Old 03-15-2015, 09:31 AM   #4
Gilles's Avatar
Quebec
When I read a new mail this morning in this site, a member identified this web page and it is from there my question...
http://www.trailerparts.com/index.ph...er+Disc+Brakes
Gilles
Bigfoot 15B17G.
Old 03-15-2015, 09:35 AM   #5
Gilles's Avatar
Quebec
Excuse me, I corrected the web page.
Gilles
Bigfoot 15B17G.
Old 03-15-2015, 09:40 AM   #6
Gilles's Avatar
Quebec
I have ends too quickly, electric brakes seem to exist with drum only.
Gilles
Bigfoot 15B17G.
Old 03-15-2015, 09:50 AM   #7
cpaharley2008's Avatar
With disc brakes you would typically need a surge type brake system which are used by some non-rv type trailers for hauling animals or construction. Your early U-Haul trailers had surge brakes since most vehicles do not have a brake controller. Most rv's use drum brakes with electric brakes activated by a brake controller. So I guess if you wanted, you could replace you axle with disc brakes. I'm not sure but some larger Airstreams may have electric disc brakes.
Jim
Never in doubt, often wrong
Old 03-15-2015, 10:08 AM   #8
Gilles's Avatar
Quebec
I eventually found, but I wonder if there are trailers which use?
Parts Needed to Add Electric Over Hydraulic Disc Brakes to a Trailer | etrailer.com
Gilles
Bigfoot 15B17G.
Old 03-15-2015, 11:01 AM   #9
MC1
MC1's Avatar
Yes they do but the problem was the delayed action of getting them to actually engage. Not sure if the problem has been fixed or not.
Old 03-15-2015, 11:11 AM   #10
Raz
Raz's Avatar
Vermont
I believe the Lil Snoozy originally came with surge disc brakes.
Old 03-15-2015, 11:30 AM   #11
Surge brakes are more common on boat trailers and I believe that a boat trailer builder is/was building frames for Lil'Snoozy.
I once looked for a surge brake tongue assy for a "V" frame but could only find than for single beam frames.
Old 03-15-2015, 08:58 PM   #12
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Drum surge brakes are standard on the LIL Snoozy. Some people have ordered them with the disk surge. we ordered ours with drum electric.
Old 03-15-2015, 10:43 PM   #13
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I ordered our Lil Snoozy with the surge hydraulic disc brake set-up with the idea of retro fitting it with the electric over hydraulic. After using it, it works soooo much better than our last four electric drum brake trailers I feel no need to change over now.
Dave & Paula
Old 03-16-2015, 07:29 AM   #14
Gilles's Avatar
Quebec
I found different web page on disc brake for trailer :
Titan Disc Brake Kit and BrakeRite II SD Electric-Hydraulic Actuator - Tandem, 3,500-lb Axle Titan Trailer Brakes T4843700
Gilles
Bigfoot 15B17G.
brakes
Help needed removing a firmly stuck brake drum! Kevin A Towing, Hitching, Axles and Running Gear 15 09-17-2009 09:13 PM
How to remove drum trap on sink? Kevin Dyck Problem Solving | Owners Helping Owners 3 06-25-2009 10:03 PM
Drum size on a UHaul VT? Kevin A Problem Solving | Owners Helping Owners 7 02-21-2008 07:26 PM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
Washing Machine drum fire pit Taylor Kissinger Modifications, Alterations and Updates 3 03-12-2006 08:45 AM
