Do you have brakes on your 13' trailer? - Page 5 - Fiberglass RV
View Poll Results: Do you have brakes on your 13' trailer?
yes 29 32.95%
no 59 67.05%
Voters: 88. You may not vote on this poll
Old 01-21-2008, 09:58 PM   #57
Pete Dumbleton's Avatar
Some folks really don't have a choice about brakes because their tow vehicle's capacity is stated to be based on the trailer having brakes.
I'd rather have them than not have them because they increase my odds of dying of a disease
Old 01-22-2008, 12:09 AM   #58
Tracy & Gaenor Howe's Avatar
Trailer: 76 Boler
Sorry, this is a REALLY stupid question, but... Our 13 ft came with brakes, but they don't work, so I don't know how they do work when they do. I got the impression that you had to whack a red button on the dash or something to make them come on; that they weren't connected to the pedal to come on automatically. Is this so, or am I just making stuff up?
Tracy & Gaenor Howe is offline   Reply With Quote
Old 01-22-2008, 12:15 AM   #59
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Generally, the brakes are electric and come on automatically when you push your brake pedal. This happens via an adjusted brake controller mounted under the dash.
Some brake controllers come on based on the speed you are traveling. ie the faster you are traveling, the harder they apply.
I hope this helps.
Check out this one for “Inertia-Activated”
http://www.pplmotorhomes.com/parts/rv-hitc...controllers.htm
Old 01-22-2008, 12:32 AM   #60
Trailer: 76 Boler
I hope this helps.
Thanks, Mike!
Old 01-22-2008, 12:41 PM   #61
I hope this helps.
Check out this one for "Inertia-Activated"
I got a PM saying that technically, I miss spoke; it's not speed.
What I find is that when I am traveling fast and hit the brakes, the controller really brakes hard and the indicator light, lights up Bright RED. When I am going down my driveway, and hit the brakes just as hard, it doesn't light up RED, only orange. It's all about the internal pendulum thing, rate of decelleration.
So I percieve it as a speed thing. I hope this helps. I hate to miss lead.
Old 01-22-2008, 04:18 PM   #62
To get the brakes working, one needs a controller of some sort (search this group for lots of info), which must be installed and wired into the tow vehicle. Prices for the same unit vary, so do some homework -- EBay is a good source.
The brake wire needs to be extended to the trailer, so if you have only a four-pin connector (aka Flat-4), that will have to be changed out.
Most states require (and it's a good idea anyway) a break-away brake switch to apply the trailer brakes in the event it becomes separated from the tow vehicle while moving. This in turn requires a battery on the trailer, either the house battery or a special small battery if no house battery.
Finally, the brake power wire will need to be connected to the electric brakes.
If you are handy, there are lots of folks willing to pitch in with advice on doing it. If not, ask for recommendations as to where to get it done.
Old 01-22-2008, 04:41 PM   #63
I believe there's a Federal law about breakaway switches that if brakes are required so is a breakaway switch. My guess is that some states require breakaway switches if brakes are present even if the brakes aren't required. In Oregon the breakaway switch thing follows Federal law, required only if brakes are required.
Old 01-23-2008, 06:54 AM   #64
Trailer: 76 Boler
Here's an interesting site I found for Canadians (or folk coming here) on my BrakeQuest. It's got all the legal towing, braking and other safety requirements for the provinces and territories.
http://www.rvda.ca/regulations.asp
Old 02-11-2008, 09:40 PM   #65
Trailer: Trillium 13 ft 1976
I have a 76 13 ft trilly. i wouldn't even know if i could add brakes. could i? how much would it cost. i have a tacoma truck to tow it with. funny i used to have an older pathfinder and when i started this trailer hobby suddenly i needed a new truck...how does that happen???
Janet G is offline   Reply With Quote
brakes
Trailer Brakes Alexandra B Problem Solving | Owners Helping Owners 4 07-20-2009 11:53 AM
Trailer Brakes Pete Dumbleton Towing, Hitching, Axles and Running Gear 0 04-25-2008 07:57 PM
Trailer Brakes Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 4 01-02-2008 12:36 AM
Trailer Brakes Jen'nBarb General Chat 9 08-20-2006 11:53 PM
Trailer Brakes Pete Dumbleton Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
