Dodge Ram 1500 V6 Diesel - Fiberglass RV
Old 06-29-2013, 12:35 PM   #1
MC1
MC1's Avatar
I have never needed or owned a pick up but for those who like and need one this new Dodge V6 D is interesting. Thinking it would be a good match up to the Ford Eco boost.
Ram to offer V6 diesel as $2,850 option in light pickups
Old 06-29-2013, 01:56 PM   #2
Briantb's Avatar
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
tow ratings will be interesting to see
Briantb is offline   Reply With Quote
Old 06-29-2013, 02:31 PM   #3
Brian B-P's Avatar
It does look like a good option for many people, but I think it will be a slug compared to an F-150 EcoBoost.
Ford 3.5L EcoBoost: 365 hp / 420 lb-ft of torque
Dodge Ram 3.0L EcoDiesel (by VM Motori): 240 hp / 420 lb-ft of torque (in Grand Cherokee)
Old 07-08-2013, 11:48 PM   #4
Trailer: Bigfoot 2500 truck camper
I am excited about observing the new 1500 Diesel in action. Plan to possibly buy one second hand in about 10 years. Without RPM specs for peak torque and peak horsepower the numbers above don't tell the whole story.
My 5.9l cummins is less than 200 hp stock but peak torque is 420 ft lbs. at 1600 RPM. Towing performance is legendary.
The ecoboost may have 365 hp but its way up there at 5500 RPM where you cant reach in higher gear. Peak torque is at 2500 RPM . Although the towing performance is adequate for many, especially for a V6, it gets only average fuel economy of 15 MPG while towing. Solo the ecoboost is very efficient but nothing like a diesel.
The new 1500 D has a higher stock hp than my cummins and equal torque. Peak torque is at 2000 RPM while peak hp is at 4000. No way your going to get to peak hp with the mated 8 speed transmission! So its all about the torque and with peak torque at 2000 rpm with higher gearing you are going to be moving!
Check out the potential of this engine here:
Inside The Banks VM Motori 3.0L 630T V6 Diesel Engine - Diesel Power Magazine
Rene is offline   Reply With Quote
Old 07-09-2013, 07:09 PM   #5
Brian B-P's Avatar
At the risk of being obvious... that's why you can shift the transmission. You can have the 365 hp whenever you need it by changing to the gear that gets you 5500 RPM... the automatic transmission even does that for you.
Again, the transmission gets you to whatever engine speed you need. More speeds in the transmission means the ability to more closely match engine speed to the current conditions.
I expect that the 3.0L V6 EcoDiesel will be a fine engine for the Dodge/Ram 1500, and will serve well in towing duty as well as other uses. For those who don't believe that the much more powerful Ford 3.5L EcoBoost engine will give a similarly configured F150 better performance (but poorer fuel economy), consider the same two engines in comparable SUVs:
2014 Jeep Grand Cherokee EcoDiesel V-6
VEHICLE TYPE: front-engine, rear- or 4-wheel-drive, 5-passenger, 5-door wagon
BASE PRICE: Limited, $41,290; Overland, $48,490; Summit, $53,490
ENGINE TYPE: DOHC 24-valve diesel V-6, iron block and aluminum heads, direct fuel injection
Displacement: 182 cu in, 2987 cc
Power: 240 hp @ 3600 rpm
Torque: 420 lb-ft @ 2000 rpm
TRANSMISSION: 8-speed automatic with manual shifting mode
DIMENSIONS:
Wheelbase: 114.8 in
Length: 189.8 in
Width: 76.5 in Height: 69.3 in
Curb weight (C/D est): 5200–5500 lb
PERFORMANCE (C/D EST):
Zero to 60 mph: 7.3–7.4 sec
Standing ¼-mile: 16.0 sec
2013 Ford Flex Limited AWD EcoBoost
VEHICLE TYPE: front-engine, 4-wheel-drive, 7-passenger, 5-door wagon
PRICE AS TESTED: $48,345 (base price: $45,470)
ENGINE TYPE: twin-turbocharged and intercooled DOHC 24-valve V-6, aluminum block and heads, direct fuel injection
Displacement: 213 cu in, 3496 cc
Power: 365 hp @ 5500 rpm
Torque: 350 lb-ft @ 3500 rpm
TRANSMISSION: 6-speed automatic with manual shifting mode
DIMENSIONS:
Wheelbase: 117.9 in
Length: 201.8 in
Width: 75.9 in Height: 68.0 in
Curb weight: 4909 lb
C/D TEST RESULTS:
Zero to 60 mph: 5.7 sec
Standing ¼-mile: 14.2 sec @ 100 mph
Performance really is about available power, not all about torque. I suggest keeping expectations realistic, rather than expecting miracles due to torque.
Old 07-09-2013, 08:11 PM   #6
I agree it is obvious you could gear down but how many people have you seen towing on the highways that like to gear down? When you gear down, you slow down of course. How many people like to do that? I wish I could slow down but its like your a criminal if you follow the speed limit!
With these diesel engines the peak torque is in the right place in high gear. You usually do not have to drop a bunch of gears to get to peak torque. You can always drop a gear if needed to get the power you need but then fuel economy suffers like in my 1500 chevy V6 gasser that had to tow in 4 th gear and delivered poor performance and poor mileage.
Old 07-09-2013, 08:12 PM   #7
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Who wants to run at 5500 rpms to get the power they need? I'll take low rpm grunt any day. I'm hoping nissan comes out with the diesel titan soon.
Yeah, the flex gasser beats the higher torque diesel on a drag strip. Who cares? Put a trailer behind then and see what happens.
Old 07-09-2013, 08:24 PM   #8
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Plus (at least for now) diesel is cheaper than gas. I hope this trend sticks.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-09-2013, 08:49 PM   #9
US
A closer look inside
Old 07-11-2013, 01:41 AM   #10
Night Sailor's Avatar
Connecticut
Well said.
Old 07-11-2013, 01:42 AM   #11
Connecticut
Didn't we cover this whole topic a few months back?
Old 07-11-2013, 07:53 AM   #12
cpaharley2008's Avatar
that is the nice thing about growing old, you can repeat yourself and get the same enjoyment as the first time you said it
Jim
Never in doubt, often wrong
Old 07-11-2013, 08:26 AM   #13
Brian B-P's Avatar
Yes... and before then, and since then...
Old 07-14-2013, 10:30 AM   #14
Trailer: 21' Escape - former owner of 17' "other brand."
It looks like Chevy is also in line to add this engine.
New Chevrolet 1/2T diesels on the way - iRV2 Forums
Say, just what is it that makes diesel engines such high-torque powerhouses, anyway. (Just kidding, I don't want to open that mess again.)
2013 Dodge Ram, 25mpg Eddie Longest Towing, Hitching, Axles and Running Gear 38 02-18-2017 08:47 PM
Diesel SUVs for TV - experiences? barring Towing, Hitching, Axles and Running Gear 37 07-28-2013 10:17 PM
Dodge Ram 2500 4x2 CTD Regular Cab, Long Box Rene Towing, Hitching, Axles and Running Gear 2 03-03-2013 09:27 AM
Dodge Dakota Greg A Towing, Hitching, Axles and Running Gear 11 10-29-2008 03:32 PM
