Double Blowout - Page 2 - Fiberglass RV
Old 04-20-2009, 07:21 PM   #15
Ami P's Avatar
Trailer: U-Haul VT16 1985
I was present at the installation. 50psi cold inflation, new metal stems, torqued lugs.
Ami P is offline   Reply With Quote
Old 04-23-2009, 12:16 AM   #16
Trailer: 1986 19 ft Bigfoot
Ami,
Glad you are alright.
Had a similar experience with my car (4 tires blew up in a week) 2 years ago with Michelin tires. I finally had to call DOT in order for the manufacturer to do something. This also initiated an investigation and according to DOT might turn into a recall if proven that enough tires were defectives.
Contact DOT, they might need your info.
Frederic
FredericL is offline   Reply With Quote
Old 04-27-2009, 02:38 PM   #17
Ami P's Avatar
Final update: Unable to find the original Uhaul wheel, I had a wheel transplant operation. Cut the inner wheel and weld it to a new outer rim. Looks to be precisely on spec. I hope someone finds a more reasonable replacement for this next-to-impossible-to-find wheel.
Ami
Rim Blowout thomas kaz Towing, Hitching, Axles and Running Gear 5 08-04-2009 05:35 PM
where do I find a new blowout plug? Christi V. Problem Solving | Owners Helping Owners 2 10-17-2006 02:06 PM
Sorry Double Post John D. General Chat 5 04-04-2006 07:19 PM
swing down double bed Legacy Posts Problem Solving | Owners Helping Owners 6 07-17-2003 06:09 AM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
