Dry weight and GVWR? - Fiberglass RV
Old 02-02-2013, 12:02 PM   #1
Trailer: Casita 17' SD
My '04 Toyota Tundra Access Cab 4.7L A/T 4x4 Factory Tow Pkg is not considered a full size pick up truck. It is called a 7/8 instead of a 1/2 ton. My owners manual states only 7000 lbs towing ability. The Big Foot 25B21FB model [21'front bed room] has a GVWR of 7500 lbs. The dry weight of this trailer is about 4500 lbs. The weight of my truck with camper shell is 5900 lbs with all my camping stuff. Can I successfully tow this trailer if I don't load her up with liquids? I'm a Snowbird and travel from Oregon to Arizona every year. The 6% grades are already killers with me towing my 17' Casita on I5 hwy. I don't want to ruin my automatic transmission towing something too heavy and I have a hard time understanding GVWR?
Rattlesnake Joe is offline   Reply With Quote
Old 02-02-2013, 12:50 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You might find this of interest. You need to be concerned with
GVWR: Gross Vehicle Weight Rating
Gross Vehicle Weight Rating (GVWR) is the maximum number that the GVW or GTW should never exceed. GVWR is applied to trailers as well as vehicles, but you may see this rating referred to as the Maximum Loaded Trailer Weight.
Understanding RV Weights
Old 02-02-2013, 01:13 PM   #3
Trailer: 13' burro, 13' casita, 20' nomad f/w
You might check with your Insurance Agent, some if not all have a clause of cancellation, In case of a accident, as you are exceeding, vehicle: GVWR.
gcssr39 is offline   Reply With Quote
Old 02-02-2013, 03:19 PM   #4
charliej's Avatar
Trailer: 2010 Casita 17 'Spirit Deluxe
Not only is the trailer much heavier, you will also have a much larger frontal area with the Bigfoot, further taxing your truck.
charliej is offline   Reply With Quote
Old 02-02-2013, 03:34 PM   #5
Take a look at the Trailer Weights in the Real World for listing of trailers weighed in on arrival at fiberglass trailer meets loaded for camping. Most were done at a location with water and electrical hook ups so dont know why anyone would have towed their trailer there with liquids in in it.
Sadly only one Bigfoot 21 has been weighed so far and it came in at 6360 lbs with 1160lbs of that on the tongue.
Old 02-02-2013, 03:43 PM   #6
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'm a little confused by the "not considered a full size pick up truck. It is called a 7/8 instead of a 1/2 ton. " statement...isn't 7/8's more than 1/2?
At any rate:
You don't state the gross weight limit of the truck itself- that important starting info should be on the doorpost, and the total load including passengers, cap, cargo, and trailer tongue must not exceed that number.
The total towed weight of the trailer is the next consideration, assuming the first set of numbers comes in satisfactorily.
In my opinion, a Bigfoot 25 is likely to exceed your stated tow limit- there's one listed in the "Trailer weights" thread that weighs almost 8,000 pounds, and has a tongue weight of over a thousand pounds. Since that tongue number must come right off the top of your truck's allowed total, I think you're likely to exceed your truck's gross weight before you even need consider the trailer's!
You might find the "Tow limit Calculator" link in my signature below to be useful while you're considering all these options...
Good luck!
Francesca
Old 02-02-2013, 03:54 PM   #7
Brian B-P's Avatar
Joe hasn't even listed the truck's GVWR, let alone exceeded it. He has not suggested exceeding the trailer's GVWR, which is 3000 pounds above the dry weight. The GVWR values of the truck and trailer are, of course, not the only limits to be watched, but there is no GVWR problem apparent yet.
The truck's maximum trailer weight is a limit on the actual gross weight of the trailer, which will be something greater than 4500 pounds; it has nothing to do with the trailer's gross weight rating (GVWR), because the truck doesn't care what the trailer's sticker says, only what it actually weighs.
Old 02-02-2013, 04:09 PM   #8
Francesca
Francesca the OP has a 25B21FB model which as he correctly stated is "[21'front bed room]".
weight
trillium 5500 dry weight ? mmaclean Problem Solving | Owners Helping Owners 11 08-20-2014 11:24 PM
Need Dry Weight of the 1972 Amerigo FG-16 April Wilcox Problem Solving | Owners Helping Owners 7 09-16-2008 09:45 AM
Dry Weight Required Dallas, B Problem Solving | Owners Helping Owners 3 06-05-2008 09:02 PM
Dry Weight?? Donald L Problem Solving | Owners Helping Owners 2 05-21-2008 08:32 PM
trillium dry weight franklin hammond General Chat 8 07-08-2007 08:53 PM
