E-Trailer sale on Sherlind Scale - Fiberglass RV
Old 06-01-2015, 07:35 AM   #1
Trailer: 1999 Casita 17' SD
Ohio
I received a e-mail from E-Trailer announcing a what sound like a one day sale on a Sherline tongue weitht scale for $139.95 and free shipping. this is about half the normal price. It has a 2000# capacity and could be used to weigh the weight on each wheel of a under 4000# trailer.
Sherline Trailer Tongue Weight Scale - 2,000-lb Capacity Sherline Tools 5780
Joe
Old 06-01-2015, 08:03 AM   #2
It is for weighing the tongue, not the wheels.
Also, it is most accurate in the middle of the scale ( 1,000 lb. on a 2,000 lb. scale ). I replaced my gauge with a 1000 lb. which places my 320 lb tongue weight at about the 1/3 mark on the gauge.
Trying to read a 250 lb. tongue weight on a 2,000 lb. gauge is not easy, nor perfectly accurate.
Old 06-01-2015, 08:27 AM   #3
Ohio
It's got a capacity of 2000# so it could easily be put under each side of the axle to weigh what should be around 1500# on each side.
If it goes over 2000# per wheel I'm in trouble for not only the scale but axle capacity too.
Old 06-01-2015, 08:35 AM   #4
Ice-breaker's Avatar
As Glen mentioned, the Sherline scale is for measuring tongue weight, and is not suitable for measuring axle weights. The scale looks like this:
and gets used like this
I suppose that you could jack up your axles and somehow set them on top of the Sherline scale, but that would be a real PITA. I would also suggest that for measuring axle weights, you will need to use a different scale or go to a commercial scale.
Ice-breaker is offline   Reply With Quote
Old 06-01-2015, 09:00 AM   #5
Ohio
Dave.
The round part sticking up is an extension that unscrews leaving a round flat area in which to put under the axle or in my case the bracket for my OMW shock mount.
I have seen them used and know what I'm getting.
Like I mentioned if I go over the 2000# rating per side I'm too heavy to begin with for one wheel. My Casita has a 3500# axle.
thanks
Joe
Old 06-01-2015, 09:14 AM   #6
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Great deal and free shipping, too. I'd thought of buying one earlier, but hesitated at the price. I jumped on this offer.
Walt
Old 06-01-2015, 09:23 AM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
LOOK HERE ALSO US$ 106.95 + $12.95 shipping =$119.90 TOTAL
LM-2000 Dual-ring Gage Ranges: 0-2000 lb/0-900 kg Limited time promotion <font color="#FF0000" size="4">ON SALE</font>
Old 06-01-2015, 10:49 AM   #8
Ohio
Originally Posted by Kevin K View Post
For whatever the difference E-Trailer has the 5780 and it has both # and KG scales.
Old 06-01-2015, 07:54 PM   #9
I bought one this afternoon to weigh both the tongue and I think I can build a fixture to weigh the individual wheels as well.
I am thinking not jcaking up thr axle, but rather a fixture to hook into the wheel and jack the tire until it is off the ground , but not lifted very high. This makes the geometry work out better and better numbers to calculate total weight and center of gravity and side to side weight too.
Since I am restoring and building to suit my needs I will have to locate the parts to balance side to side and fore and aft.
I am shooting for ~2800 lbs or less with 200 lbs on the hitch. The tongue has been extended to aid in hitch weight reduction. This will put 7% on the hitch. I would rather have 8% or more so the trick is to try to keep the weight lower!
redbarron55 is online now   Reply With Quote
Old 06-01-2015, 08:16 PM   #10
Mike Magee's Avatar
Trailer: Li'l Hauley
This site also offers the LM-5000 for the same price, $106.95. Maybe some Bigfoot or Oliver owners would want this size.
How to prepare Tofu
Step 2: grill some meat
Weigh Trailer Using 2x4/Bathroom Scale??? Francesca Knowles Problem Solving | Owners Helping Owners 50 12-01-2012 04:59 PM
Wheel Weights with Bathroom Scale Pete Dumbleton Towing, Hitching, Axles and Running Gear 6 05-20-2009 12:18 PM
Propane tank scale Nancy General Chat 10 05-19-2008 11:34 AM
Expanded Scale Voltmeter Jeanne and Steve Problem Solving | Owners Helping Owners 9 05-17-2008 02:40 PM
U-Haul Scamp Burro Style 1/25 scale camp trailer Karalyn General Chat 6 01-02-2006 06:49 PM
