Electric brakes - Fiberglass RV
Old 05-31-2015, 08:23 PM   #1
dleverton's Avatar
Trailer: Trillium 1300 1973
Electric brakes
Well I just installed electric brakes on my Trillium 1300. They went on nicely. When it came to wiring, I decided to run the wires through the frame rails as the rear of the rail is open right at the axil and the wires come out just aft of the hitch. They are protected from the elements with only inches at each end exposed. Anybody see a downside?
Doug L
Doug
dleverton is offline   Reply With Quote
Old 05-31-2015, 08:37 PM   #2
As long as the wire is secure and doesn't move around and rub through. Had that problem a lot on freight trailers. And when wiring was run through that corrugated wire loom stuff I've seen many times where grooves were worn into the wire insulation from loom. I like to use jacketed wire secured with loop clamps
Old 05-31-2015, 09:20 PM   #3
dleverton's Avatar
Good advice, thank you
Doug L
Doug
Old 05-31-2015, 10:12 PM   #4
This all depends on the wire's insulation. In this case I would recommend SAE SXL wire. Its heavily insulated with Cross Link (Teflon) which is quite abrasive resistant also it won't sustain fire.
Old 05-31-2015, 10:55 PM   #5
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Almost 25 years ago I built a utility trailer and ran the basic 4 wires for the lights through the frame. I was also a little worried about rub through from vibration so I ran them in an old garden hose.
The trailer has been used a TON!, I've replaced the plug end many times but have never had a wire issue in the frame.
Fred
FRED SMAILES is offline   Reply With Quote
Old 05-31-2015, 11:19 PM   #6
Fred
I've walked back and forth across the street thousands of times and haven't been hit by car. I don't even bother to look both ways any more, think I'll be OK?
Old 06-01-2015, 02:01 AM   #7
Borrego Dave's Avatar
Trailer: Casita SD17 2006
You may be OK, but if you do get hit by a car, mmmmm, could that be called chafing and a short? Running wires in a sleeve and looking both ways are both preventative actions. I've run a lot of wire through conduit. The next time I do a trailer I'm going to remember the hose idea as I've got some hungry rabbits around here that love wire
Borrego Dave is online now   Reply With Quote
Old 06-01-2015, 02:48 AM   #8
Trailer: Bigfoot B-17 CB
Fred
PEX plumbing pipe also works well in a similar fashion.
Jack L is online now   Reply With Quote
Old 06-01-2015, 12:30 PM   #9
dleverton's Avatar
Hey I like the pex idea.
Thanks all for the great suggestions
Doug L
Doug
Old 06-01-2015, 12:34 PM   #10
dleverton's Avatar
Electric brakes
Rabbit resistance is a tough one. Squirrels are bad too. On my Subaru the protective sleeve on the output stud on the alternator keeps getting chewed by some critter. It is a strange rubbery plastic and clearly quite tasty. Hey everyone's gotta eat.
I have a large roll of Tefzel 14 gauge aviation wire that has been collecting dust for decades and I chose to use it. It is used in aviation applications and has the huge advantage that I already have it. If it gets chewed I will try something less tasty. The Tefzel seems to spec abrasion resistance similar to Teflon, but does not handle cold as well as Teflon. Hey, it doesn't get too cold here on Vancouver Island, and if it's cold the Trillium stays parked.
Doug L
Doug
Old 06-01-2015, 12:43 PM   #11
The Book of Odds say your chances of being hit by a car this year while walking are 1 in 40,000. It also say that "Almost one-third of urban motor vehicle-related deaths are pedestrians."
Unfortunately it does not say what the adjusted odd rates would be for those who don't look before crossing the street
brakes
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 05:24 PM
Trillium 1300 - electric brakes Lloyd S. Towing, Hitching, Axles and Running Gear 4 07-05-2009 08:40 PM
Approx How much $$ for Electric brakes? Jaclyn W Towing, Hitching, Axles and Running Gear 11 05-11-2009 10:09 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
