Electric Brakes for 13' Boler - Fiberglass RV
Old 02-09-2018, 05:11 PM   #1
Can electric brakes be added to existing and original Boler 13 axel - tire size 175/80R13.
Elvin
omache27 is offline   Reply With Quote
Old 02-09-2018, 05:25 PM   #2
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Look behind the wheel for a square plate with a hole at each corner. That is where brakes would mount. If no plate, you will need a new axle to add brakes.
Old 02-09-2018, 05:46 PM   #3
Thanks Mike. I'll check the backing plate.
Old 02-10-2018, 05:26 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
We added 7" electric brakes to our 1974 Boler 13 when replacing the axle. The original axle didn't have backing plates. YMMV
Old 02-10-2018, 06:56 AM   #5
If your Boler axle is indeed original, you're a decade or two overdue for a replacement. You will likely experience a noticeable improvement in ride quality along with the added safety of brakes.
Old 02-10-2018, 11:00 AM   #6
It looks like a new axle with brakes attached is the way to go. One question - 7" or 10" electric brakes?
Old 02-10-2018, 11:13 AM   #7
bullfrogeh's Avatar
Cool Adding brakes !
We did just as Jon did - - - on our 1973 13' Boler - We opted to change out the original 44 year old axle, with a new one; and, added the 7" brakes, just for the obvious potential safety factor. - let alone the improvement in ride quality. (Wish I could just as easily, renew my own physical conditions, that are approaching twice the age of our Boler, although I do seem to be 'slowing' fairly well at present !)
bullfrogeh is offline   Reply With Quote
Old 02-10-2018, 02:59 PM   #8
I think 7" is all that will fit with the stock axle and wheel size. Could be wrong, though...
Unless you're going to do this yourself, I'd look for a good utility trailer shop or axle specialty shop and discuss your options. If you can find a shop with Boler experience, even better, as the original Boler axle installation was non-standard (leading rather than trailing arm configuration).
This would be the time to give the frame a once-over as well.
boler, brakes
Boler drop axle with electric brakes - price? kroeker68 Towing, Hitching, Axles and Running Gear 2 07-24-2016 03:27 PM
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 06:24 PM
Electric Brakes on a 13' Boler Erik J Towing, Hitching, Axles and Running Gear 22 03-01-2009 01:57 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
