Electronic Sway Control - Fiberglass RV
Old 12-23-2013, 06:15 AM   #1
Massachusetts
Hi All,
Just watched this video on the RV101 Youtube channel. It uses the electric brakes to handle sway control by applying different loads to each wheel depending on needs.
Rick
No affiliation with the company.
kb1flr is offline   Reply With Quote
Old 12-23-2013, 10:25 AM   #2
IllAnnoy
Several questions occur to me...
What is the power source?
Is it the TV brake signal?
That would be the simplest and IMHO best approach.
Of course this would require separate wiring to each side presumably after the box.
When the box fails will it default to stock braking mode or to no brakes?
Old 12-23-2013, 11:21 AM   #3
Massachusetts
Found a test of the thing:
Trailer Sway Control Revealed: Tuson trailer mounted system tested | TFLTruck.com: Truck News, Views & Reviews | The Fast Lane TruckTFLTruck.com: Truck News, Views & Reviews | The Fast Lane Truck
Looks like you keep the standard brake controller and wire this between the controller and drum brakes. It detects sway and attempts to compensate.
Rick
Need Photo -- Casita Sway control Jane D. Towing, Hitching, Axles and Running Gear 2 11-26-2012 12:28 PM
EU sway control GeorgeR Towing, Hitching, Axles and Running Gear 3 09-16-2010 12:48 AM
Sway control Legacy Posts Problem Solving | Owners Helping Owners 4 05-04-2003 07:34 AM
Sway control General Chat 0 12-31-1969 07:00 PM
