01-29-2011, 08:07 AM
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Emergency Jack
My 03 Casita came with an 08 Carlisle tire on the curb side, an 06 Maxxis on the road side, and an 02 Marathon on the spare.
Pulled off the Carlisle and the Marathon and replaced them with two new Maxxis, which are on the ground and the older Maxxis is now the spare.
Used a 2 ton floor jack to replace the Carlisle. Then went to the street side and decided to try the sizzor jack, as that is what I had planned for our "Emergency" Jack.
The jack handle that comes with those jacks worked fine to push up against the frame. Then WHOA! It ain't gona turn any farther. The head on the jack screw has a hole in the middle for it's handle, and the outside of the head is hexagon. Used the 4 way lug wrench but it was terribly slow as it would only turn a 1/4 turn or so before hitting the ground. Went to a 1/2" drive ratchet and socket which worked OK but still not much of a turn as one hand stablized the 10" extention while the other hand cranked. Got it up and changed the tire. Jacking down was almost as much work as going up. Can't even imagine lifting the heavier curb side.
I have a 2 ton hydraulic bottle jack that would have made the job much easier, but the head of the screw/shaft that pushes up against the load is so small, 3/4" or so, and the trailer frame so narrow, it seems unsafe.
Does someone sell bottle jacks with an enlarged base and shaft head, that will fit under the frame when the tire is flat, yet jack up high enough to change the tire?
What jack are you folks using for emergency tire changes?
Thanks,
Kip
01-29-2011, 11:04 AM
I have always used a 12 Vdc sissors jack.
Like this Harbor Freight 12V Scissor Jack from Harbor Freight.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
01-29-2011, 12:06 PM
Quick jack.
For changing a wheel I use the quick jack which goes under an axle and by pulling forward you lift the axle. I used it a few times on my 21RB Bigfoot. It is quick and stable but it is very helpful to be told when to stop.
George.
Quick Change Trailer Jack
01-29-2011, 03:57 PM
Trailer: Bigfoot 17, 1988
Wisconsin
Personally, I think the only kind of jack that is worth owning is a real floor jack. Other types of jack just seem like toys, and when I have a flat tire, the last thing I want is to mess around with a toy masquerading as a tool. They are easy to use, work on uneven surfaces, have an inherently wide base, and even self-center due to the wheels. They make small ones that can easily be stored in a vehicle or storage compartment, like this one:
Amazon.com: 'Jack-in-a-Box' 2-Ton 4000 Lb Lift Capacity Easy-Carry Hydraulic Jack with Storage Case: Home Improvement
01-29-2011, 03:58 PM
Wisconsin
01-29-2011, 05:22 PM
Trailer: 1992 Scamp 13
Maryland
This thread seems to have evolved into a thread about jacking tow vehicles not trailers. I assume you have jacking the tow vehicle covered, so back to the trailer... On my Scamp I can lower the tongue to get as much height in the rear as possible, lower the rear stabilizer jacks and then raise the tongue until the wheels are of the ground. Would this work for you?
01-29-2011, 05:41 PM
NOT a good idea. The frame isn't built to use the stabilizers on the rear to hold the weight like this. You're liable to end up with cracks, breaks or tweaks to the frame. You want to jack the trailer as close to the axle as possible, without being on the axle.
01-29-2011, 06:01 PM
Wisconsin
Also, I think most tongue jacks on these trailers are only 2000# capacity, unless you or someone upgraded to the 5000# model. If the jack failed while your trailer was suspended in air, the consequences could be even more damaging to the trailer and possibly even life-threatening... same goes for the possibility of it tipping or falling, as you'd have a pretty narrow triangular base overall and stabilizing jacks generally aren't omni-directionally stable.
I'd say the safe way is to double-chock the opposite wheel, jack it up with a real, stable jack near the wheel (i.e. not a bottle jack, side ratchet jack or puny scissor jack). Then, stabilize the lifted side with a couple of stabilizer jacks before you put any body parts or tools under the side.
01-29-2011, 06:32 PM
Trailer: 72 Boler American
Indiana
I'm confused, why couldn't you use the scissor jack? was the handle missing? Iv'e never had trouble with one.
01-29-2011, 07:31 PM
Trailer: 16 ft Casita Spirit Deluxe
Greg.... I'm not sure about the others but when i have a flat tire and the scissor jack has to be fully down to get it under a jacking point it is at it's worst position to crank it up and is downright rough to get it up.....now a tire that has air in it and the scissor jack is cranked up some to meet the jacking point it will lift a lot easier. Many scissor jack instructions show the maximum strength when it is elevated a few inches first, then put under a load.
Joe
01-29-2011, 07:34 PM
Indiana
Joe
Yes I can see that could be a problem.
01-30-2011, 05:49 AM
Greg,
The handle that came with the sizzor jack works OK for a light load,.like jacking it up to meet the trailer frame. And maybe lift it a couple of inches. From that point on the offset in the handle just doesn't offer enough of a mechanical advantage to lift much weight.
Apparently the jack maker relized the problem and welded a lug on the end of the screw. One of the 4 way's "sockets" fits that lug. Probably by design. But being so close to the ground the 4 way allows very little motion, about 1/4 turn. So I went to the ratchet with an extention that would reach the jack and the ratchet itself being where I could turn it. This increased the range of motion to about 1 o'clock to 5 o'clock. Used the right hand to crank and the left to stabilize the ratchet and keep the jack from twisting around on the ground. It was still a tough crank.
Probably an extention bar on the ratchet would have helped.
Keeping in mind I was dealing with fully inflated tires. If the tire had been flat, the jack would have started out even lower and harder to screw, as Joe pointed out. Also I was working on the lighter side of the trailer.
Then after wrestling with the tire change, the thing had to be screwed back down. There was more time and energy consumed with the jacking part than with the tire changing.
Thanks,
Kip
01-30-2011, 06:11 AM
I use a hydraulic scissor jack that seems like the best of both to me.
It clears the spots under the trailer where I need it to fit but then it jacks uo with the hydraulic action and advantage.
Trouble is I can not seem to find these anymore?
I hope there is no good reason I should know about and don't.
Got ot at Walmart but now they don't seem to have them.
01-30-2011, 06:50 AM
Too many times I've thought I was prepared for an emergency but discovered I really wasn't. Glad I did this at home and realized the sizzor jack I had decided to use is not adequate as it comes.
True that we don't need to use a jack every day, hopefully never.
But when we do need a jack, we likely won't be in the best of moods and don't need any more aggrevation.
The trailer not likely to roll during a tire change, because it either is or can be attached to the TV. Also the front jack can be lowered to the ground.
When lifting the side, the angle is changing a little.
I like simplicity. That leaves 3 basic choices.
A floor jack is stable and quick and first chioce for operation, IF it can roll. On soft or rough ground, rolling can be a problem. It is also fairly large and heavy for something that may never be used while on a camping trip.
Sizzor jack is a real hassle for something this heavy.
Bottle jack is quick and fairly easy, with a reasonable weight and size, but the top of the plunger screw is small and could slip off the narrow frame as it tilts.This could result in injury or the jack plunger going through the floor of the camper.
How about a piece of steel channel or cup be bolted or welded to the frame to recieve the plunger and hold it more steady, so it can't slip.
Thoughts or Ideas?
Thanks,
Kip
01-30-2011, 08:59 AM
Trailer: 1980 Burro
Originally Posted by Kip in Ga.
Greg,
Thanks,
Kip
I have used scissor jacks many times and never had a problem and the vehicles they are designed to lift usually weigh more than fiberglass trailers. You might want to lubricate the scissor jack screw, that can make a huge difference!
Even with a flat, the rim is still on the wheel so there should still be space for the jack just like with a car. If you compare weight, storage size, jacking range and price the scissor jack comes out on top. That is why most cars have them. If it is not a lubrication problem, then it sounds to me like you have a poorly designed scissor jack. Why not just get a better scissor jack instead of switching types. Other types of jacks will have some models that are poorly designed too.
Andy
01-30-2011, 12:15 PM
Indiana
Greg,
Thanks,
Kip
I understand now, A lightweight low profile floor jack is the ticket.
01-30-2011, 02:20 PM
I like simplicity.
How about a piece of steel channel or cup be bolted or welded to the frame to receive the plunger and hold it more steady, so it can't slip.
Thoughts or Ideas?
Don't European car manufacturers do some version of this idea? My 1979 VW Beetle Convertible had a little square tube welded to the frame on each side that the jack head fit into.
01-30-2011, 03:27 PM
Indiana
An old guy down the road has two old Mercedes Benz cars and they four short round tubes on the frame for the one legged jack, they work pretty good.
