Finally - Shocks on our Scamp - Page 3 - Fiberglass RV
Old 01-22-2015, 08:56 PM   #29
Pineapple Man's Avatar
Trailer: Scamp 13'
Ohio
Being a Newbie, does anyone know if this kit would fit a Scamp 13' ?
I checked out the link to the Casita Club page and it looks like a valuable upgrade !
PineappleMan
Pineapple Man is offline   Reply With Quote
Old 01-23-2015, 01:27 AM   #30
Trailer: Avion 30P and 1979 Scamp 16
Would it make any sense to have them on smaller Scamps like the Scamp 16?
Dave
Dave Frazer is offline   Reply With Quote
Old 01-23-2015, 06:02 AM   #31
Timber Wolf's Avatar
North Florida
Originally Posted by Dave Frazer View Post
Would it make any sense to have them on smaller Scamps like the Scamp 16? Dave
I would think so, and plan on adding them (someday) to my Scamp 16. But then some people don't believe in even balancing their trailer's tires. I don't understand that one. If balanced tires are good for the tug, aren't the trailer's tires rolling down the exact same roads? It is OK to vibrate the trailer to pieces but not the tug? I feel the same way about the shocks although I don't have a real good grasp on how much they will help.
Old 01-23-2015, 06:40 AM   #32
Trailer:
There are various requirements in Germany to get your car-trailer combination speed limit raised from 80km/hr (50mph) to 100 km/hr (62mph) and having shocks fitted is one of them. No doubt that is why many European axles are designed to retrofit dampers easily.
Old 01-23-2015, 07:17 AM   #33
AL-KO has easily installed shock absorber systems for their European axles. I am planning to copy their system and use the Octagon red shocks on my Scamp 16' trailer.
This will include retro-fitting the existing AL-KO original 2500 lb (dead) axle with a Flexride. This is because I can remove the swing arms and either weld the brackets on or machine a keyed groove like the AL-KO (Euro) axle.
The US AL-KO does not have the provisions for the shock mounting or I would use them instead.
The Flexride also will allow me to select the ride height in 6 degree increments so I can fine tune the trailer.
The axle will have to be positioned differently since the arm length is different. Also the arm is shorter and this will affect the shock tuning, but I think that it will work out since the AL-KO reds are rated for slightly higher damping and the shorter arm will work in this direction.
youtube video of installation:
AL-KO Handbook:
http://www.al-ko.co.uk/edit/files/ha...s-handbook.pdf
I think that removing the Flexride swing arms will allow me to fabricate arms to match the supplied stamped AL-KO arms and Heliarc them in the proper position. Then the addition of the frame mount end will not be much of a problem.
Old 01-23-2015, 06:40 PM   #34
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
I asked my husband why put shocks on our 19' fifth wheel? Well, the dog would have felt better had we had them when she was riding back back there going "God, how long until they stop and discover I am covered in things.?"
Living and working in the Oil Patch but home is still Iowa.
Cyndi B. is offline   Reply With Quote
Old 01-23-2015, 11:08 PM   #35
John & BJ S.'s Avatar
Name: John & BJ
Trailer: 2010 Scamp D19
Mesa AZ
The simple answer, Cyndi, is because the TRUCK rides so much better when towing the trailer after the shock installation. Any 'chucking' from the trailer is essentially eliminated.
Sent from my XT1032 using Fiberglass RV mobile app
John & BJ
Mesa, AZ
"We're not lost. We're just finding our way."
www.justfinding.blogspot.com
John & BJ S. is offline   Reply With Quote
Old 01-25-2015, 08:40 AM   #36
Shock absorbers (more properly dampers) work with the springs and weight to control the oscillations (and also the tires). These oscillations contribute to the bucking from the trailer to the hitch on uneven road surfaces and also the sway when the wind blows or maneuvering.
The rubber suspension needs less damping than pure springs since the compliance of the rubber damps out some of the bounce and converts it to heat. This is not enough to take care of the problem completely.
AL-KO Europe has recognized this and offer the above shock absorber systems every where other than the US. The regulations in Europe encourage shock absorbers to provide better handling.
The shocks absorbers damp side to side tipping oscillations that contribute to swaying. Since the weight of the trailer is forward of the wheel contact point the oscillations from straight bounce excites an oscillation on the hitch that is reflected to the tow vehicle.
Dampers add to the stability of the overall system and add safety to the handling and comfort to the ride in the tow vehicle. This is a large part of the exceptional reputation of the Airstream trailers.
Just because you don't ride in the trailer and experience the ride directly does not mean that the shocks do not provide a benefit to the overall package.
My decision to use the AL-KO shocks is that they have developed 4 different damping values based on the weight of the trailer and axle. The amount of damping required varies with the spring rates and weight involved.
My guess is that that even though I am planning on using the Flexride axle since the arms can be removed to install the brackets etc. the red Octagon shocks from AL-KO Europe are probably closer tho the correct value than the single available Monroe trailer shock.
Of course this is based entirely on gut feeling and guesswork.
If you look at the video you can see that there are several top mounting positions for the shock and this allows for some tuning of the system. I don't know if these shocks are 50 - 50 % or any other ratio and neither have I found any specifications on the Monroe. The mounting on the pivot point of the trailing arm of the AL-KO mean that the compression and rebound are reverse from the Monroe mounted at the wheel hub.
I will post more information when I have the Flexride axle and the AL-KO shock absorber system.
Finally, Finally... Richard Hayes Hi, I am.... 11 06-16-2012 09:35 PM
bounce... could it be bad tug shocks? Scott S. Care and Feeding of Molded Fiberglass Trailers 15 10-07-2008 05:46 PM
air shocks sherry loving o Modifications, Alterations and Updates 12 09-14-2008 11:01 PM
New shocks, springs- What do I need? Denise K Towing, Hitching, Axles and Running Gear 3 02-08-2007 12:40 PM
bounce... could it be bad tug shocks? Scott S. Towing, Hitching, Axles and Running Gear 0 12-31-1969 07:00 PM
