finding a rim for a Boler tire - Fiberglass RV
Old 05-22-2007, 12:08 PM   #1
Does anyone know where a person can find a rim that fits onto a Boler. The tires are easy enough to find, but I can't find rims that are compatable with the amont of space there is, also there are 5 holes. If you have any suggestions, I would appreciate hearing from you.
Doug
Doug Burke is offline   Reply With Quote
Old 05-22-2007, 12:48 PM   #2
Chester Taje's Avatar
Doug
I have one BUT i am in Alberta.
Old 05-22-2007, 08:53 PM   #3
Trailer: 1976 Boler
Hi Doug
Just went to Walmart last week. They had 13" hubcaps on sale..4 for $10.00 Cdn (thats about $1.50 US exchange Lol). They work and look great. Used 3 for the trailer including spare and have one left over.
Here's a pic of them
Cheers
Al
al gilliland is offline   Reply With Quote
Old 05-23-2007, 09:32 AM   #4
Brian B-P's Avatar
In previous discussions, it seems that the consensus was that our Bolers use the most common "trailer" wheel sold, so just about anyone who sells wheels (including WalMart, Canadian Tire, tire stores, Princess Auto, etc.) has the right ones. The wheel is really determined by the axle, and it seems that most Boler axles are Dexters.
The key specifications for any wheel, with typical Boler specs in [brackets], include:
  • bolt pattern (number x bolt circle diameter) [5 x 4.5"]
  • offset (distance hub is outboard of wheel centre plane) [1/2"]
  • centre hole size [I don't know offhand, but large compared to most cars]
  • hub or bolt centric (located by a close fit of the centre hole to the hub, or just by the bolts) [bolt centric]
  • diameter (nominal diameter at tire bead) [13" in this case; the B1700 normally has 14"]
  • width (nominal width at tire bead; must be in range suitable for tire) [I don't know]
It would also be nice if the shape of the wheel fit any hubcaps which you might want to use, such as the common baby moons, but there's no real spec for that. Full wheel covers mount right out at the edge, and are essentially a universal fit.
Old 06-01-2007, 11:43 AM   #5
Doug
Rim on its way .
Ches
boler
Can you show me how the spare tire is mounted on your Boler, or Trilli jenniferm Problem Solving | Owners Helping Owners 12 01-01-2015 12:30 PM
Neonex Boler wheelwell tire clearance PHOTOS kevin61 Problem Solving | Owners Helping Owners 2 07-23-2008 10:43 PM
Boler tire size? Cory K Problem Solving | Owners Helping Owners 5 05-13-2007 11:49 AM
Need help finding an LA campspot Linda R002 Camping, Campout Reports 11 12-08-2006 10:02 PM
We need help finding a Microwave!!! Legacy Posts Problem Solving | Owners Helping Owners 6 02-05-2003 04:45 AM
