Fix for tire wear and positive camber - Page 3 - Fiberglass RV
Old 07-27-2016, 04:48 PM   #29
The Minimalist's Avatar
Louisiana
Originally Posted by Johnny M View Post
Thanks for the info, good to know. But this brings up another question regarding the positive camber that corrects when the trailer is loaded...I am pretty sure everyone has different loaded weights depending on their style of camping so how do you adjust for a trailer loaded on the lighter side vs one loaded on the heavy side so that you don't get bad tire wear (I understand about balancing the load evenly not talking about that)?
For a given trailer, the axle is chosen to support the weight of the trailer and the average load a reasonable person would load for the intended use (In our case loaded for camping, not hauling all your household goods cross country). It's based on averages. It's not a one to one correlation. If you had a 2200 lb axle and you replace with the same, you should have no problems.
Usually there is a tag on the axle giving it's design load. On a torsion axle you need to get one with the same down angle as the original. Paul, the Boler guy, should be able to help you there.
Clif
Old 07-28-2016, 05:21 AM   #30
CampyTime's Avatar
Trailer: Scamp 13' Standard
Johnny, the Minimalist provided a great response to your question. I believe a new axle will sol e your problem. Starting angle on my Scamp 13 was 22 degrees up. 2200 # torsion axle. I ordered mine to replace origi al, which has 7 inch electric brakes. To give you an idea of cost, I paid $840 installed. Will be cheaper without brakes
Sent from my VS985 4G using Fiberglass RV mobile app
Old 07-29-2016, 09:39 PM   #31
Johnny M's Avatar
Deep South
Thanks Fred, Clif and others for the additional info. After talking with Paul Neumeister he recommended I check the previous owners job of repacking the wheel bearings which he done a few days before we bought it and man am I glad I did. While you could tell the bearings were repacked (overly so with grease in the entire hub and castle nut), he failed to properly tighten the castle nut! That nut holds the hub in place but also is responsible for putting the right amount of pressure on the bearings. He had the nut too loose allowing slop in the hub thus allowing the wheels to lean in...I did one side first and compared it to the other side, repacked side now looks straight up and down and other side still leans in, fixing to do it now and will look at it again in the morning with better light but I think the problem is solved. If this is the original axle it probably does have some wear as I think the trailer sits a tad lower than it should but nothing I think that will cause any problems for the foreseeable future but I will probably have to replace those new tires we put on last fall sooner than expected due to the inside shoulder wear...
Old 07-30-2016, 03:41 PM   #32
Johnny M's Avatar
Deep South
After doing the bearings on the drivers side (it too has the nut too loose) the tires don't lean in as much, very slightly now. Not sure if that is from 45 years of axle wear or a slight bend? Going to monitor the tires and see how they wear for a little while before I move forward with a new axle.
Old 07-30-2016, 04:08 PM   #33
Johnny M's Avatar
Deep South
Okay after reading some of Ian Giles axle info, it appears my axle may not be original as it is trailing arm and not leading arm, and the axle tube is under the lower floor and not under the dinette. So if it has been replaced could it need to be aligned/bent on a hydraulic press to accommodate for the wear on the inside of the tires? The ground clearance of the lower floor at the door is 9 3/8" to bottom/underside of the floor. According to Ian's info the normal step up is 7 to 8"
Old 07-30-2016, 04:41 PM   #34
Johnny M's Avatar
Deep South
Found the plate on the axle, it is indeed an Ingersol Rub R Rid axle, 1200 lb capacity, under patent by Neiohart. I spent a few minutes examining the welds on the axle and the brackets due to the fact that the axle manufacturers plate is on the curb side as opposed to the drivers side, is upside down and is also facing the tongue. It looks like the axle may have been cut off the frame due to evidence of uneven/cut metal on bottom of the brackets leading me to believe it was flipped over at some point and re-welded under the lower floor as opposed to under the dinette area. Can't believe I did not catch this when I had the body off the frame. The tires were badly worn but seemed worn pretty evenly so I didn't think to further examine the axle as the lower floor ground clearance seemed good. I guess that is one more thing Ian Giles could add to his buyers guide is looking for a "flipped axle". Anything to save a buck I guess...now it looks like I have got to start looking for a new axle.
1972 Hunter Compact Negative Camber Issue luckycharm Towing, Hitching, Axles and Running Gear 5 07-21-2014 07:25 PM
1985 U Haul with wheels w bad camber Susanne Problem Solving | Owners Helping Owners 2 05-27-2012 07:17 AM
tire wear Chris Z Towing, Hitching, Axles and Running Gear 6 06-27-2006 02:21 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 27 04-16-2003 10:02 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 1 04-14-2003 11:32 PM
