Fold down Jack Stand - Page 2 - Fiberglass RV
Old 06-20-2014, 04:18 PM   #21
Roy in TO's Avatar
I've considered welding some metal onto a caster wheel so it will slide over the footplate then use a drop in pin to keep it from coming off.
Old 06-20-2014, 04:48 PM   #22
The Minimalist's Avatar
Louisiana
I just installed this, The Ultimate Jack.
It will take either the flat foot or the dolly wheel. I'm going to carry both.
We have been in several situations where the swivel jack had to pivoted up onto the dolly and off of the trailer ball. That's not too hard with the Little Joe, but getting it back on the ball to travel can be a trick.
After pulling the clevis on the locking pin, you rotate the pin and the jack drops down. Reset the pin and pull it up and it locks back in position. You only have to jack down until it, or the foot/dolly make contact, then level.
After hooking up the trailer to the TV, pull rotate the locking pin and lift the column up as far as you need, then relock. In rough terrain, you can drop the foot/dolly off and bring the column all the way up if you want.
As substantial as it is, 3000 lb lift, 2000 lb static, I was concerned it might add too much weight to the tongue, but it is actually somewhat lighter than the Fulton swivel jack it replaced.
Here is the website if you are interested.
Ultimate Trailer Jack Website
The demo video is a bit cheesey, but the quality of the jack construction is great. If you look close at the part where the husband is still jacking and not getting it off the ball, you will notice he didn't unhitch. The truck is going up too.
By the way, you may want to check a local trailer supplier to see if they have put them in. I got mine from Trailers of Louisiana, owned by a friend of mine. It was a new addition to his offering.
Clif
Old 06-20-2014, 05:44 PM   #23
Trailer: Class A Motorhome
Looks like a winner of an idea for those that have to have maximum clearance when under way. They are selling on eBay for about $50, looks like a good buy.
Here's a link:
The Ultimate Trailer Jack Trailer Jack | eBay
Old 06-20-2014, 07:19 PM   #24
Louisiana
Clearance on the Little Joe is 11 inches level. Are you guys running with less than that? The Unit can be run up to zero clearance if need be.
Sent from my SAMSUNG-SM-G730A using Fiberglass RV mobile app
Clif
Old 06-20-2014, 07:25 PM   #25
Louisiana
Sorry Bob. Misread your previous post as, "have maximum clearance", rather than, "have to have". Old eyes, smart phone.............out smarted.
Old 06-20-2014, 08:49 PM   #26
Roy in TO's Avatar
I didn't see either described on the web site, nor could I get the operating instructions to open.
Does anybody have links that work?
Is it available in side crank? On second thought that might create problems if you had to drop it low. But it might solve the problem for people that wanted to drop their tailgate and did not have enough room. Just drop the jack.
Old 06-20-2014, 09:25 PM   #27
Louisiana
Per the site,
Pre-drilled for optional foot pad or
wheel
Yeah, I just tried the instruction link and it didn't work. If it's not working soon, I could scan and post the instructions.
In any case the video pretty well covers operation. Installation is straight forward bolt on or welded A-Frame mount.
I'm towing with a Subaru Outback, but I could hook it up to my 07 Chevy Silverado and check for tail gate clearance.
Jack Stand Beernink Towing, Hitching, Axles and Running Gear 3 07-14-2012 03:58 PM
looking for suggestions for fold down shelf secwind7 Problem Solving | Owners Helping Owners 11 01-05-2012 08:54 PM
Small fold down bedside shelf efawcett Modifications, Alterations and Updates 3 07-19-2009 08:42 PM
Solar Panel Stand Barbara Gardin Problem Solving | Owners Helping Owners 6 07-03-2009 07:30 PM
