Fold down Jack Stand - Fiberglass RV
Old 06-19-2014, 08:43 PM   #1
Trailer: Burro 13'. 1982
Montana
Hi all!
I would like to change out my current jack stand for one with a wheel at the button. Is it possible?
Lfoxmont is offline   Reply With Quote
Old 06-19-2014, 08:51 PM   #2
You just buy the wheel. Don't know what your tongue jack looks like, but should fit. Look it up at etrailer.com
Old 06-19-2014, 09:09 PM   #3
Bobbie Mayer's Avatar
No, I'd get a swing-up jack. I think I got mine at Harbor Freight. I initially just left the existing tongue jack on but later when I was having some mods done I took it off.
Old 06-19-2014, 09:12 PM   #4
Montana
Mine does swing up when towing......
Old 06-19-2014, 09:13 PM   #5
Trailer: Class A Motorhome
There are different diameter jack tubes as well. Measure yours first before buying a wheel.
Old 06-19-2014, 09:37 PM   #6
Montana
Took a hard look at my jack.......it's welded to the tongue so it's not going anywhere. And there isn't any type of cotter pin, etc. that would let me switch out the bottom. My only hope is that the next time I'm hitched up, I'll crank it all the way down while it's in it's swing away position and see if there is any type of release of the square stand that would allow me to switch in a wheel.
Name:	ImageUploadedByFiberglass RV1403235436.236033.jpg
Old 06-19-2014, 09:51 PM   #7
Borrego Dave's Avatar
Linda, you can change out the bottom of you jack. Measure the OD of the jack stem and buy the correct ID wheel you want that has the hitch pin. Your jack should have a spring clip to hold it on the jack stub. Take the jack off, cut the foot off above the weld, mark and drill holes for the hitch pin and your done, 30 minutes.
Old 06-19-2014, 10:33 PM   #8
Montana
The weld isn't on the tube that goes up and down, it's at the top where the jack is attached to the trailer.
Old 06-19-2014, 10:36 PM   #9
Montana
It's got the spring clip that let's me swing it into place after I'm hitched up.
Old 06-19-2014, 10:38 PM   #10
You are correct, that's what holds the jack to the stub on the frame and it stays in place. The swivel jack itself comes off with a spring clip. From your pic the flat foot is welded on, that is the only part that has to be changed for what you want to do. It seems that you are calling the latch pin that holds the jack in the up or down position a spring clip. Not what I'm talking about. Look at where the stub comes through from the frame just past the flat mounting plate for the jack and you will see a spring clip, it looks like a big "C". That's what lets you remove the jack itself.
Old 06-19-2014, 10:46 PM   #11
Roy in TO's Avatar
Look to see if there is a clip that holds the jack onto the round piece it swings around on. Remove the clip and the jack should pull off.
I lucked out and found a wheel jack with almost the same diameter opening and with a bit of McGuyvering got it to work. The hole was about 1/32" smaller, so I ground it out a bit. The metal was a little thinner than original so I made a shim from a margarine lid. The spring clip hole need enlarging.
Old 06-19-2014, 10:51 PM   #12
Roy in TO's Avatar
That is the clip I was talking about. Seems that Dave posted before I finished my reply. He did a better job of 'splaining things.
Old 06-20-2014, 06:39 AM   #13
But.... measure and be sure you can get the wheel/foot pad in the size you need before cutting off the old one.
As the old carpenter sez: "Measure Twice, Cut Once".....
Old 06-20-2014, 12:08 PM   #14
Montana
Yeh, I remember telling me on time. "No matter how many times you cut it, it's still too short!"
Old 06-20-2014, 12:08 PM   #15
Montana
Whoops....I added my Dad told me.....
Old 06-20-2014, 12:38 PM   #16
John Linck's Avatar
Trailer: 1990 Scamp 16 ft
I added a caster from my scrap box to the flat plate my trailer came with. Drilled 4 holes and secured with 4 bolts. Crude but effective.
John Linck is offline   Reply With Quote
Old 06-20-2014, 12:47 PM   #17
You may need to remove the wheel for travel, depending on your jack and your tow.
Mine has spent most of its life under the driver seat.
Old 06-20-2014, 12:52 PM   #18
Timber Wolf's Avatar
North Florida
I measured the circle in the wheel-foot jack I have on another trailer (jack is from Harbor Freight) and it appears to be the same size as the pad-foot jack on my Scamp. I have not swapped them over because I mounted a trailer tongue tool box that hangs over a little and the wheel would hit it when swiveled up. Eventually I would like to move the jack to the driver side from the passenger side also.
In the meantime, since I am a manly-man (at least for now), I just muscle the trailer around rarely cranking the jack and just pushing the trailer around the driveway and campsites. At least it impresses my 10 year old daughter, she said “Daddy we don’t even need the truck, you can just pull it”. It will be a sad day when my daughter realizes her Daddy is not Superman and really can’t “fix everything”.
Old 06-20-2014, 02:13 PM   #19
Roy in TO's Avatar
An old timer I used to work with would say. Don't worry about it, only one side is too short. Look this side is still OK.
Old 06-20-2014, 03:05 PM   #20
Montana
John,
What a great idea!! I'll have to break out the drill bit toolbox and see what I've got.
Jack Stand Beernink Towing, Hitching, Axles and Running Gear 3 07-14-2012 03:58 PM
looking for suggestions for fold down shelf secwind7 Problem Solving | Owners Helping Owners 11 01-05-2012 08:54 PM
Small fold down bedside shelf efawcett Modifications, Alterations and Updates 3 07-19-2009 08:42 PM
Solar Panel Stand Barbara Gardin Problem Solving | Owners Helping Owners 6 07-03-2009 07:30 PM
