Front rear, rear wheel, all/four wheel for towing? - Page 2 - Fiberglass RV
Old 04-22-2018, 10:46 AM   #21
I think that the minivans are a good choice for TVs and each has its good and bad points.
The Honda gets better mileage than my T&C and has more power but not a great deal better and the 283 hp with the Pentastar V6 is adequate.
Transmissions might be a topic as the T&C has never been noted for extreme long term reliability.
But the Stow & Go seating was the deciding factor for me.
You can have all the seats up, drop them under the floor and slide a 4 X 8 sheet of plywood flat on the floor.
You pays your money and takes your choice.
Old 04-22-2018, 01:10 PM   #22
Trailer: 2015 Escape
I would never be without 4wd or awd. I ‘ve had times when I’d have been stuck on wet grass and only inch deep mud of I didnt have 4wd. Would never again be without it. As mentioned before get enough tow vehicle to handle a larger heavier trailer. Cheaper to get it up front than to have to replace the tow vehicle when/if you’re you replace the trailer.
Old 04-22-2018, 04:33 PM   #23
carl 5 strange stuff happening in automotive today.
sort of crazy
bob
Old 04-22-2018, 04:34 PM   #24
that is fantastic milage pulling a 16 I barely get 20 towing our 13f scamper with a ford edge eco
bob
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
Four Wheel Drive versus Two Wheel with Posi Rear End Lyndon Laney Towing, Hitching, Axles and Running Gear 8 04-16-2010 09:38 PM
Camping after an interval of four months Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 9 05-03-2003 08:13 PM
