Has anyone tried 15X7 rims on an egg? - Fiberglass RV
Old 10-02-2006, 01:36 PM   #1
Trailer: 1982 13 ft Burro
Just picked up a set (3) of 15X7 rims for my '82 13-foot Burro. I've wanted to go bigger than the 13's that came with the trailer, although 15x7 may be too much of a good thing. They didn't cost much, so no great loss, but it would be nice if they worked out.
I put a new 20-degree down axle on a month ago that gives me about 12 or 13 inches of clearance - about 4 inches more than it had with the old axle. We drive a lot of rough roads and scraped the heck out the bumper and the tongue jack a bunch of times before I put the new axle on.
The current wheelset is about 23 inches in diameter with tires. If my math is right, the 15's would be about 26 inches if I put 195/70/r15's on, or just over 26 with 205/70r15's. 26 inches is likely cutting it pretty close.
The current width is a little more than 4 inches and the new width would be about 8 inches, which seems possible, albeit tight.
I think something like a 175/75/r14 might be a smarter choice, but I saw these on craigslist and thought why not?
AndyW is offline   Reply With Quote
Old 10-02-2006, 01:50 PM   #2
Andy, my Scamp runs 205 75R 15s, but I also put a 45 degree down axle on. So far, so good I like it because now I have a REAL step...one that slides in and out welded to the frame and there isn't any damming caused by the Scamp being lower than the tug.
Old 10-02-2006, 07:44 PM   #3
Kent's Avatar
Trailer: X Casita Owner
I have 2004 Casita Liberty Deluxe with high lift option from the factory. This amounts to about 1.5" to 2" increased height from the standard axle. The wheels are 15x7 aluminum.
Kent is offline   Reply With Quote
Old 10-05-2006, 09:41 PM   #4
Trailer: Scamp 13 ft
Andy,
I changed to 14 in. mag type wheels on my 13 ft. Scamp. With 195-70 tires. They stuck out about 1 1/2 in. more than the stock 13 in. set-up. But all I had to do was trim about 1 in. off the fiberglass for clearance. Took off the rivets holding the rubber molding, cut with a saber saw, sanded, then put the molding back on. Looks and works fine. Don't know if that applies to your trailer. My suggestion: just keep in mind the diameter of the orig. when you are going up in wheel size. Good luck, Garret
Garret Walther is offline   Reply With Quote
eggcamper
Rims on a Trillium Randy Bishop Modifications, Alterations and Updates 32 04-11-2016 10:46 AM
Surfside rims? kentj Problem Solving | Owners Helping Owners 5 12-27-2007 06:26 AM
New Rims Lainey Problem Solving | Owners Helping Owners 8 08-16-2007 01:40 PM
tires n rims Tom Stewart Care and Feeding of Molded Fiberglass Trailers 45 11-06-2006 03:01 PM
13" Tires on Rims Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 11-03-2002 04:03 PM
