Have brake controller and wiring harness but...
Hi all,
I am sure the new Ford Flex has many features that I still need to familiarize myself with. Most are intuitive.
I received the brake controlled from eTrailer yesterday and was easy to install under the dash on the left.
However, there is a "dummy" plug on the Class III tow package connector under the dash. Almost no room for arms or hands under there, but it would seem to be an easy push on connection once the dummy is removed.
I have not been able to remove this dummy plug. It has a small black tab that seems like if pried away the plug shoudl slide off. Not happeing. This black tab appears to be like a zip tie to keep the plug snug on the wiring under the dash.
Wondering if I can just cut this off and add a new zip tie to secure it in place. The fancy "Ford" tie has a retangular protrubrance on one side that the plug slides onto.
Nothing found on-line about how to remove this dummy connector, nor anything related to this connection in the new user's manual.
Any ideas/suggestions from more experainced Ford folks?
Bat Dude
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
