Here is good description of towing a trailer and tongue weight - Fiberglass RV
Old 01-23-2017, 08:57 PM   #1
Trailer: G30 Elite Class C
stude is offline   Reply With Quote
Old 01-28-2017, 11:26 AM   #2
Name: Wayne & Barbara
Trailer: Parkliner
Trailer and TV weight distribution/weight Transfer
There has been a lot of discussion about tongue weights
One factor to keep in mind is the effect of hitch weight on the tow vehicle axle loads.
As long as the hitch ball is behind the rear axle, any weight applied there will cause a transfer of weight from your front axle to the rear axle.
Think back to high school physics and simple levers.
For example. My Highlander has a wheel base of 109.8 inches. The hitch ball is 42" behind the rear axle. Our trailer has a hitch weight of about 250 lb.
Multiply the hitch weight by the ball distance and divide by the wheel base.
That will be the weight transfered from the front axle to rear. Add it to the hitch weight to get the total added to rear axle. Subtract it from front axle for the reduced load on the fron tires/
(250 x 42)/109.8 = 95 lb 95 + 250 = 345 lb add to rear axle. subtract 95 lb from front axle load. Adjust tire pressures accordingly.
A fifth wheel or gooseneck trailer; with the hitch point over, or a bit ahead of the rear axle does not cause any waeight transfer.
Eggcamper Weight, Tongue Weight & Towing with Outback coastsignal Towing, Hitching, Axles and Running Gear 108 10-01-2015 07:20 PM
is my weight distribution hitch worth the tongue weight and effort. beachcamper54 Towing, Hitching, Axles and Running Gear 24 01-25-2014 11:41 AM
Towing package and tongue weight WaltP Towing, Hitching, Axles and Running Gear 4 04-01-2009 09:47 PM
Tongue-weight and level when towing Bobbie Mayer Problem Solving | Owners Helping Owners 7 09-08-2007 12:27 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 07:49 PM
» Virginia Campgrounds
