Hitch & brake controls for 2013 Honda odyssey - Fiberglass RV
Old 12-07-2013, 01:48 PM   #1
Virginia
We are picking up a 17' Spirit deluxe Casita in a few months. We have a 2013 Honda odyssey. Is there a specific weight distribution hitch kit and electric brake control that you recommend? Also, how's the towing with the Honda odyssey?
Thanks Jmw
Jmwachter is offline   Reply With Quote
Old 12-07-2013, 09:03 PM   #2
I recommend reading this article:
Common Weight Distribution and Sway Control Questions | etrailer.com
The key statements are:
Originally Posted by etrailer.com
The T(ongue)W(eight) rating is the most important factor in determining which size weight-distribution system you should use. If the bars of the system you choose are rated too high for your setup, they will create a rigid ride, which can result in a bouncing trailer. If, on the other hand, the bars are not rated high enough, the system will be unable to properly distribute the weight, rendering it virtually useless.
Choose a weight-distribution system with a T(ongue)W(eight) rating that is closest to your towing setup's T(ongue)W(eight) to ensure the best performance.
We have a weight guide here:
http://www.fiberglassrv.com/forums/f...rld-43010.html
According to the spreadsheet in that topic, 17' Casitas' Tongue Weights are all over the map, but most fall in the range of 300 to 500 pounds, with the majority above 400 pounds. The lightest standard Weight Distribution Hitch is a double spring arm version rated for up to 600 pounds.
For 400 pound tongue weights and below there is a light duty single spring arm version.
Old 12-07-2013, 09:08 PM   #3
Virginia
Thanks for response
I'll check out the e-trailer information.
Old 12-08-2013, 07:17 AM   #4
MC1
MC1's Avatar
Good day JMW
I'm am surprised more folks are not using the Oddy's as TV's. I keep reading many positive reports on how well they do.
Just this morning there was a very informative post about them. If you are interested check it out here. Post #72.... Fantasy Tow Vehicle - May the Forces Be With You - Page 6 - Airstream Forums
Can I tow with Honda Odyssey Jerry W. Problem Solving | Owners Helping Owners 22 09-20-2013 08:37 PM
Do you tow with a Honda Odyssey? Frederick L. Simson Modifications, Alterations and Updates 33 11-14-2011 02:59 PM
Honda Odyssey Van Tom B Towing, Hitching, Axles and Running Gear 12 04-20-2009 09:05 AM
99 Honda Odyssey as a tow vehicle? Cam A Problem Solving | Owners Helping Owners 6 03-01-2007 04:36 PM
