Hitch height - Page 3 - Fiberglass RV
Old 04-06-2013, 08:27 PM   #29
Wallo's Avatar
Utah
Interesting posts on this thread which I think applies to questions running around loose in my head. But, it doesn't look like any hit on ones I have.
I bought a new tow vehicle a few months ago and had a u-haul hitch installed. It is the correct hitch for my vehicle, but it sits low back there. With the trailer sitting level in the garage, I measured up to the bottom of the coupler. Then went to the SUV and measured to the bottom of the ball. A good 6" lower on the SUV side. Would I be able to turn the "stinger?" upside down and reverse the ball to gain height? Or are the stingers made to be used in just one direction? It might give me the extra height instead of buying a new one.
Alice
Wallo is offline   Reply With Quote
Old 04-06-2013, 09:20 PM   #30
That is exactly what the Casita factory did to get my Casita with high lift axle level. My hitch was normal level but needed to come up about 5" to account for the axle and the 2" drop from the toungue weight mentioned before.
Dave Fish is offline   Reply With Quote
Old 04-06-2013, 09:30 PM   #31
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Sure, the one on the subaru is a 4" rise.
Old 04-06-2013, 10:15 PM   #32
Brian B-P's Avatar
Some are okay either way up, others are for only one orientation only. Most 2" mounts are reversible, especially those with moderate drop/rise. Many 1 1/4" mounts are not reversible. I would check the specific mount (a.k.a. stinger) on the manufacturer's website (e.g. Ball Mounts - Reese)... and of course on the mount itself.
With a 2" receiver and 3/4" thick platform for the ball, the rise will be the drop minus 1 1/4"; for example, a 4" drop ball mount becomes a 2 3/4" rise mount.
Old 04-06-2013, 10:36 PM   #33
Jared J's Avatar
Kansas
Good call, I forget about 1 1/4" stuff.
Old 04-07-2013, 01:31 PM   #34
Wallo's Avatar
Utah
I'll check to see if the stinger can be reversed and go from there. It may not make up the extra height I need, but it's worth a shot to save some $$ and not have extra "stuff" hanging out in the garage. Too much of that already.
Alice
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
Hitch and Trailer height Donna & Chris Towing, Hitching, Axles and Running Gear 7 06-16-2010 09:28 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
Ideal hitch height for Surfside Maui Gomez Towing, Hitching, Axles and Running Gear 2 09-14-2007 08:35 AM
Hitch height? Legacy Posts Towing, Hitching, Axles and Running Gear 3 02-11-2003 02:55 PM
