Hitch help! - Fiberglass RV
Old 09-14-2007, 10:34 AM   #1
Laura K.'s Avatar
Trailer: 16 ft Scamp
I really, really, really want to buy Manny's 16' Scamp. Problem is, the tongue weight is about 25lbs over the rating for my car.
A weight distributing hitch would be a good solution, as my car (2005 Subaru Forester) has plenty of towing capacity for the trailer weight (2000lbs). Tongue weight is the only limitation. I can find weight distributing hitches that are very light weight. But, I can't find any that fit my car's 1.25 hitch receiver.
The guy at the shop told me that a receiver adapter to change the 1.25" receiver to 2" would lengthen the hitch and negate the effect of the weight distributing hitch. Is this true?
Laura K. is offline   Reply With Quote
Old 09-14-2007, 10:49 AM   #2
The guy is wrong!
Extending the hitch ball further back lowers actual hitch weight load on your TV (although not by much), but has nothing to do with the effect of a WDH.
You are right to assume that a WDH will aleviate your hitch weight problem. If fact all hitch receivers are rated higher for a WDH than they are rated without WDH.
You didn't state what you Forester is rated to tow. You must also consider the GCWR (Gross Combined Weight Rating) of your Forester/Scamp configuration (look at the label on the driver's side door or door post).
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 09-14-2007, 11:20 AM   #3
Laura K.'s Avatar
My max tow rating is 2400 lbs
Trailer weight is ~2000 lbs
My max tongue weight is 200 lbs.
Trailer tongue weight ~ 225 lbs
My GVWR is 4500 lbs (there is no listed rating for combined weight)
Interior load capacity is 900 lbs.
Rear axle will carry 2040 lbs
Experiance tell me that the car engine has plenty of power and the trailer has electric brakes. I suspect that the suspension and steering control are the key issues. Would a weight limiting hitch address BOTH of these safely?
Old 09-14-2007, 11:35 AM   #4
Ed Felker's Avatar
Laura:
I too have a 05 Forester (XT) and will be doing the same thing -- adapting a 1.25" hitch receiver opening to a 2" hitch opening. Want to get a Scamp 16' & use a WDH.
Here's a web site that has adapter. Doing a Google search will show several other manuf. who make the adapter.
http://www.netshops.com/cart/shopper.cfm?a...ci_sku=CTM754-3
Ed
Ed Felker is offline   Reply With Quote
Old 09-14-2007, 11:40 AM   #5
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Laura, any time you change equipment from what the manufacturer supplies, and exceed the limits as set by the manufacturer, you're into uncharted territory. My only advice would be to send you to a frame and axle shop and take their advice as to what can safely be accomplished with your car. Sometimes what can be done and what should be done are completely separate issues.
Roger
Old 09-14-2007, 11:42 AM   #6
Roger H's Avatar
Iowa
Laura:
Ed
Ed... note this caveat from the manufacturer of these adapters:
Note: 1-1/4 inch to 2 inch adapters are not intended for towing. The most common uses for these adapters are for bicycle racks and cargo racks.
And a weight distributing hitch may put stresses on a Subaru Forester in vectors that the unibody was never designed to handle. I'd do a LOT of research before I tried one.
Roger
Old 09-14-2007, 12:04 PM   #7
Laura K.'s Avatar
I agree with you Roger. I already asked the shop to check about this with the manufacturer. They say the Forester is built on a truck frame (it's classed as a mini-SUV). They don't see any problems with a weight distributing hitch. Thier concern is only about the adapter PLUS the weight distributing hitch. They never heard of anyone needing an adapter for a weight distributing hitch.
I looked at putting a different hitch on the car in order to get the 2" receiver, but Subaru doesn't make one and the car is too new for many after market parts to be available. That doesn't indicate anything about the car's towing capacity. Subaru is notorious for making it hard to find parts.
Old 09-14-2007, 01:03 PM   #8
Ed Felker's Avatar
Don't want to get on a soap box -- but it absolutely drives me crazy asking the, "Can my Forester tow a ........?" question.
My 05 Forester is rated at 2400 lbs per the US owners manual. Reference the attached website. http://www.subaru.pl/sklep/akcesoria/05MYF...r_Accessory.pdf
That is a European Accessory catalog printed by Subaru. Page 4, Item 40 way down in the right hand corner -- blow up the PDF file and see what it says about the European Tow receiver.
Rated at 4000 Kg -- with 2.2046 lbs per Kg -- that equals 4409.2 Big Mac inducted US lbs.
What caused my car to drop half its tow capacity? It boggles my mind -- and yes it is probably driven by US liability requirements.
Old 09-14-2007, 01:47 PM   #9
Roger H's Avatar
Iowa
I dunno, Laura. The Subaru website is mute on the issue, and every other source I've found on the web shows the Forester with a unibody rather than a ladder frame. There may be a very good reason they don't use a 2" receiver. I don't seem to find anyone who builds a Class III 2" receiver hitch for the Forester either.
If you're convinced that you can use a weight distributing hitch, you could always have a draw bar fabricated with a 1 1/4" draw bar, and a 2" shank for mounting a hitch head. I just had a huge one fabricated to use with a special hitch on my motorhome. The whole drawbar cost me $140 and that included the custom drilling and welding. Only $40 of that was labor, the rest was steel. I'd think that you could probably have one fabricated for around $30 at a reputable custom welding shop.
Roger
Old 09-14-2007, 02:02 PM   #10
If it were me, the first thing i I would do is to actually weigh the tongue weight then play with distributing things inside the egg until I got it where it should be then I would remove the lower class receiver and install a class III 2inch receiver.
25 Pounds is really nothing and you may be able to offset that by putting some weight in the rear of the egg. GoodSam Highways magazine just had an article in the last edition concerning toung weight, trailer packing and distribution of weight, etc.
I would make sure I had electric brakes on the egg.
Old 09-14-2007, 02:07 PM   #11
Trailer: small
State
The guy is wrong!
I'm not sure I understand the logic here. A hitch is a lever which applies pressure against the suspension of the tow vehicle. The vehicle will then pivot correspondingly on the fulcrum of the suspension, which may or may not be the rear axle.
A longer lever (ie, a towbar extension/adapter) will server to increase the mechanical advantage of the tongue weight over the suspension.
Picture a nut in a nutcracker. If the nutcracker has really short handles, you have to squeeze fairly hard, but if the nutcracker has really long handles, the nut will disintegrate with very little squeeze.
So, unless I'm mistaken, an adapter will indeed increase the effective load on the hitch, not to mention the side-to-side leverage will increase as well, giving more opportunity for the tail to wag the dog.
Am I wrong?
My point, by the way, is that I think there is a good reason that the adapter manufacturer says "not for towing", and when you have a marginal tow vehicle for the application, I don't think it is a good idea to push any of the design intentions to find a workaround. Physics has a nasty tendency to rear it's head at the most inopportune moments!
Mr. W. is offline   Reply With Quote
Old 09-14-2007, 02:11 PM   #12
Of course you can do what you want to do, but I think you'd be playing with fire. You're bouncing right up against the Subaru's limits. I did some checking looking for a 2" receiver hitch for your Subaru, As far as I can tell there isn't one made, not even a Class 2.5 hitch. I also looked for a WD hitch for 1.25" hitch, again the big guys don't make one. Must be a reason for that.
One has ask one's self if it's worth the risk to Tow Vehicle, Trailer, and life to attempt to tow outside published limits.
Old 09-14-2007, 02:36 PM   #13
pjanits's Avatar
Trailer: 17 ft 1986 Burro
This may shed some light: I did a google on carvan tow weights
http://www.gocaravanning.com/caravan...wing_guide.htm
Sample:
Subaru - Forester (02 on) - 2.0 AWD S - Turbo - 5 door
Power: 174 bhp Length: 4460mm
Transmission: Manual Width: 1735 mm
Weights & Towing Information:
Kerbweight 1420 kgs Unbraked tow weight: 500
85% of kerbweight: 1207 kgs Braked tow weight: 500 kgs Manufacturers website:
n/a
95% of Kerbweight: 1349 kgs
They talk about 85% of the tow vehicle being the normal trailer weight.
I think your brochure may have had a slight typo in it.
Old 09-14-2007, 02:38 PM   #14
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Personally, I doubt the Scamp 16' weighs 2000 lb in any kind of travel configuration. Closer to 2900-3000 pounds unless it's a stripped Scamp.
http://www.fiberglassrv.com/board/index.ph...c=13488&hl=
Quando omni flunkus, moritati
Steve L. is online now   Reply With Quote
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
How Not To Use Your Hitch Patrick M. Jokes, Stories & Tall Tales 4 04-20-2008 02:32 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
hitch problem Legacy Posts Problem Solving | Owners Helping Owners 25 03-17-2003 06:43 AM
Buying a hitch Legacy Posts Care and Feeding of Molded Fiberglass Trailers 20 03-14-2003 08:34 AM
